7003X堆叠MAD检测,关闭主机后备机所有端口MAD Down状态
2024-01-15提问
  • 0收藏,253浏览
两台7003X做堆叠和BFD MAD检测,关闭主机后备机所有端口(包括聚合口,interface vlan接口,物理端口)都处于MAD Down状态,端口灯都不亮,正常来说只有堆叠分裂的时候才会出现这个情况,但关闭主机后备机出现这个情况导致业务无法在备机正常转发,版本如下:
display version
H3C Comware Software, Version 7.1.070, Release 7743P05
Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.
H3C S7003X uptime is 0 weeks, 1 day, 7 hours, 47 minutes
Last reboot reason : Cold reboot
Boot image: flash:/S7000X-CMW710-BOOT-R7743P05.bin
Boot image version: 7.1.070, Release 7743P05
  Compiled Jul 15 2021 11:00:00
System image: flash:/S7000X-CMW710-SYSTEM-R7743P05.bin
System image version: 7.1.070, Release 7743P05
Feature image(s) list:
  flash:/S7000X-CMW710-FREERADIUS-R7743P05.bin, version: 7.1.070, Release 7743P05
MPU(M) Chassis 1 Slot 0:
Uptime is 0 weeks,1 day,7 hours,47 minutes
BOARD TYPE:         LSCM2CGT24TSSC8
DRAM:               2048M bytes
FLASH:              3768M bytes
NVRAM:              1M bytes
PCB Version:        VER.A
Bootrom Version:    104
CPLD 1 Version:     001
PowChip 1 Version:  001
Release Version:    S7000X-7743P05
Patch Version:      None
Reboot Cause:       ColdReboot
LPU Chassis 1 Slot 2:
Uptime is 0 weeks,1 day,7 hours,44 minutes
BOARD TYPE:         LSCM1TGS48SC8
NVRAM:              0K bytes
PCB Version:        VER.A
CPLD 1 Version:     001
CPLD 2 Version:     001
CPLD 3 Version:     001
Power CPLD Version: 001
CpuCard
    BuckleType:              LSC1CPCL
    BuckleDRAM Size:         2048M bytes
    BuckleFLASH Size:        0M bytes
    BucklePcb Version:       VER.B
    BuckleCPLD 1 Version:    004
    BuckleBootrom Version:   108
    BucklePowChip 1 Version: 002
Patch Version:      None
MPU(S) Chassis 2 Slot 0:
DRAM:               2048M bytes
FLASH:              3720M bytes
NVRAM:              1M bytes
PCB Version:        VER.A
CPLD 1 Version:     001
Patch Version:      None
LPU Chassis 2 Slot 2:
NVRAM:              0K bytes
PCB Version:        VER.A
CPLD 1 Version:     001
CPLD 2 Version:     001
CPLD 3 Version:     001
CpuCard
Patch Version:      None
部分配置如下:
interface Vlan-interface1024
 mad bfd enable
 mad ip address 10.0.1.1 255.255.255.0 member 1
 mad ip address 10.0.1.2 255.255.255.0 member 2
irf-port 1/1
 port group interface Ten-GigabitEthernet1/0/0/27 mode enhanced
 port group interface Ten-GigabitEthernet1/0/0/28 mode enhanced
irf-port 2/2
 port group interface Ten-GigabitEthernet2/0/0/27 mode enhanced
 port group interface Ten-GigabitEthernet2/0/0/28 mode enhanced
 irf mac-address persistent always
 irf auto-update enable
 irf auto-merge enable
 undo irf link-delay
 irf member 1 priority 20
 irf member 2 priority 10
Xcheng 九段
粉丝:121人 关注:3人
信息太少了,无法判断
建议确认下具体组网和完整配置信息以及log日志文件情况吧
目前故障信息无法复现,但是主机掉电备机所有端口全部mad down肯定是不正常的
zhiliao_7sq4J 发表时间:2024-01-15
回复zhiliao_7sq4J:
那就联系400热线由原厂专家确认下吧
Xcheng 发表时间:2024-01-15
