ACG1000-E死机,开机配置口界面报错
2024-01-16提问
  • 0收藏,239浏览
Error reading file 'vmlinux.64' vmlinux.64 not found! argv[2]: quiet argv[3]: cOnsole=ttyS0,9600 argv[4]: numcores=8 argv[5]: mtdparts=octeon_nand0:1024m(system) Allocating memory for ELF segment: addr: 0xffffffff80100000 (adjusted to: 0x100000), size 0x5220400 ## Loading big-endian Linux kernel with entry point: 0xffffffff80721da0 ... Bootloader: Done loading app on coremask: 0xff Starting cores 0xff 0 Creating 1 MTD partitions on "nand0": 0x000000000000-0x000040000000 : "mtd=0" UBI: attaching mtd2 to ubi0 UBI: physical eraseblock size: 524288 bytes (512 KiB) UBI: logical eraseblock size: 520192 bytes UBI: smallest flash I/O unit: 4096 UBI: sub-page size: 1024 UBI: VID header offset: 1024 (aligned 1024) UBI: data offset: 4096 UBI: fixable bit-flip detected at PEB 973 UBI error: ubi_io_read: error -77 while reading 520192 bytes from PEB 393:4096, read 520192 bytes UBI warning: ubi_eba_copy_leb: error -77 while reading data from PEB 393 UBI error: wear_leveling_worker: error -77 while moving PEB 393 to PEB 2014 UBI warning: ubi_ro_mode: switch to read-only mode UBI error: do_work: work failed with error code -77 UBI: attached mtd2 to ubi0 UBI: MTD device name: "mtd=0" UBI: MTD device size: 1024 MiB UBI: number of good PEBs: 2048 UBI: number of bad PEBs: 0 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 140 UBI: total number of reserved PEBs: 1908 UBI: number of PEBs reserved for bad PEB handling: 20 UBI: max/mean erase counter: 14089/9443 UBIFS: read-only UBI device UBI: fixable bit-flip detected at PEB 1023 UBI: schedule PEB 1023 for scrubbing UBI: fixable bit-flip detected at PEB
4 个回答
粉丝:35人 关注:3人
是不是版本比较老,参考版本说明书通过menuboot升级到最新版本看看
粉丝:8人 关注:0人
根据您的报错信息,您的设备可能出现了以下问题:
1. 设备无法找到启动文件 "vmlinux.64",导致无法加载 Linux 内核。
2. 设备的 NAND 闪存出现了坏块或者位翻转,导致 UBI 和 UBIFS 无法正常工作,进入只读模式。
您可以尝试以下方法来解决您的设备故障:
1. 通过串口线连接设备,使用 CTRL+C 进入 Bootrom 菜单,检查启动文件的路径和名称是否正确,如果不正确,可以使用 set bootfile 命令修改。
2. 如果启动文件的路径和名称正确,但仍然无法找到,可能是设备的 NAND 闪存损坏,需要重新烧写固件。
3. 如果设备能够正常启动,但仍然出现 UBI 和 UBIFS 的错误,可能是设备的 NAND 闪存有坏块或者位翻转,需要进行修复或者更换。
z6Kl9 九段
粉丝:67人 关注:2人
在保找400吧换
粉丝:0人 关注:2人
软件版本都下不到了[污]
