S7003交换机恢复出厂设置的命令是那个?命令行操作的
2024-01-22提问
  • 0收藏,217浏览
Telnet登录后 没有 reset saved-configuration  命令
粉丝:3人 关注:0人
要在尖括号的视图下
是的,没有这个命令
zhiliao_upMqar 发表时间:2024-01-22
telnet 权限不够
VLAN划分49块9一次 发表时间:2024-01-22
<H3C>reset ? acl Clear acl information arp Reset ARP entry arp-snooping Reset ARP snooping entry bfd Bidirectional Forwarding Detection bgp Border Gateway Protocol (BGP) cfd Connectivity fault detection (IEEE 802.1ag) counters Statistics information about the interface dhcp DHCP configuration subcommands dhcp-snooping DHCP Snooping dldp DLDP module dns DNS status and configuration information dot1x Reset 802.1X statistics information garp Generic Attribute Registration Protocol hwtacacs Specify HWTACACS server igmp Specify parameters for IGMP igmp-snooping Configure IGMP snooping characteristic ip IP protocol ipc Interprocess communication ipsec Clear IPSec information ipv6 Specify IPv6(Internet Protocol Version 6) configuration information isis Clear ISIS lacp Configure LACP Protocol mac-address MAC address information mac-authentication Reset mac-authentication statistics information mld Specify parameters for MLD mld-snooping Configure MLD snooping characteristic mpls Configure MPLS (Multiprotocol Label Switching) msdp MSDP module multicast Multicast information mvrp Multiple VLAN Registration Protocol ndp Neighbor discovery protocol oam OAM protocol ospf Open Shortest Path First (OSPF) packet Packet commands packet-drop Packet dropping information pim PIM module pim-snooping PIM snooping status information portal Portal protocol qos Command of QoS(Quality of Service) radius Reset RADIUS statistics information rip RIP (Routing information protocol) ripng RIPng (Routing information protocol for IPv6) rrpp Rapid Ring Protection Protocol smart-link Smart link module stop-accounting-buffer No response acct-stop packet buffered in local memory stp Spanning tree protocol tcp TCP module udp UDP module udp-helper UDP HELPER module unused Free unused port tag resource vrrp VRRP status and configuration information 这个是reset ? 后的
除了用console线 ,用telnet不可以吗
粉丝:17人 关注:9人
从反馈的信息来看,应该是权限不够。
建议console线登录重置。
