S5560,irf成员编号怎么删除
2024-01-24提问
  • 0收藏,249浏览
两台S5560做堆叠,本来只要一台设备irf member 2 renumber 1就行,现在两台设备都编号了,用命令行把其中一台设备配置全部删除,重启之后还是会出现irf member 2 priority 1,interface GigabitEthernet2/0/1这个怎么才能恢复出厂设置,一定要reset键吗?
<H3C>reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:y
Configuration file in flash: is being cleared.
Please wait ...
MainBoard:
Configuration file is cleared.
<H3C>reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:n
<H3C>dis cu
 sysname  H3C
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 port link-mode bridge
 combo enable fiber
Xcheng 九段
粉丝:122人 关注:3人
参考
sys
irf me 2 re 1
y
sa f
rebo
y
粉丝:144人 关注:0人
您好,以下是参考命令:
粉丝:119人 关注:1人
重新renumber回去就行了
