通过RADIUS认证HTTPS登录网页不成功
2024-01-25提问
  • 0收藏,286浏览
SecBlade FW Enhanced Module和无线AC都遇到这个问题,通过普通用户可以登录网页,通过RADIUS认证就不行了。
通过 https://www.h3c.com/cn/Service/Document_Software/Document_Center/Home/Security/00-Public/Configure/Radius_Attribute_List/H3C_RADIUS_V7-5273/#_Toc145427820 查询到 Login-Service = 54为HTTPS,从debug也可以看出从RADIUS服务器得到了属性,但网页就是无法登录,可能“The login-service type that server assigned does not match with the access type.”就是问题,不知道RADIUS下发什么属性可以让用户登录网页,试过Login-Service=SSH可以让用户从SSH登录的。
Decoded reply packet successfully.
*Jan 25 13:23:42:742 2024 h3c_fw RADIUS/7/PACKET: -COntext=1;
    Login-Service=54
    Service-Type=Login-User
    Login-Service=Terminal
    Login-Service=SSH
    H3c-Exec-Privilege=3
    H3c-User-Roles="shell:roles="network-admin""
 02 3e 00 5b 71 b6 a1 84 e0 f9 b7 40 90 88 10 cd
 c7 64 2f 55 0f 06 00 00 00 36 06 06 00 00 00 01
 0f 06 00 00 00 34 0f 06 00 00 00 32 1a 0c 00 00
 63 a2 1d 06 00 00 00 03 1a 23 00 00 63 a2 9b 1d
 73 68 65 6c 6c 3a 72 6f 6c 65 73 3d 22 6e 65 74
 77 6f 72 6b 2d 61 64 6d 69 6e 22
*Jan 25 13:23:42:742 2024 h3c_fw RADIUS/7/ERROR: -COntext=1;
*Jan 25 13:23:42:742 2024 h3c_fw RADIUS/7/EVENT: -COntext=1;
Sent reply message successfully.
PAM_RADIUS: Processing RADIUS authentication.
PAM_RADIUS: Fetched authentication reply-data successfully, resultCode: 1
%Jan 25 13:23:42:743 2024 h3c_fw WEB/5/LOGIN_FAILED: -COntext=1; h3c-administrator@home.lan 从 x.x.x.x 登录失败.
配置信息:
radius scheme freeradius
 primary authentication x.x.x.x
 primary accounting x.x.x.x
 accounting-on enable
 key authentication cipher $c$3$XOOT/JeB3PGLkhBRol5pEdYPvd0V0PJB2jrqOFV88GrN4cp8fYRDjSaHCOOHKulq0w==
 key accounting cipher $c$3$oleEMd/bnexygvv8ajyqBCRUkJUbioNqg7kJDy0SmkF2eQixgz8pVEeUr9qAslTiPw==
 timer response-timeout 5
 user-name-format without-domain
 nas-ip x.x.x.x
 data-flow-format data kilo-byte
domain home.lan
 authentication login radius-scheme freeradius local
 authorization login radius-scheme freeradius local
 accounting login radius-scheme freeradius local
 authentication super radius-scheme freeradius
4 个回答
粉丝:171人 关注:8人
用http试试
粉丝:147人 关注:0人
您好,我记得不支持,只能使用http
ip http enable后,浏览器通过http打开网页,然后把RADIUS属性改成了53(HTTP)试了还是不行。 Decoded reply packet successfully. *Jan 25 14:24:28:245 2024 h3c_fw RADIUS/7/PACKET: -COntext=1; Service-Type=Login-User Login-Service=Terminal Login-Service=SSH Login-Service=53 H3c-Exec-Privilege=3 H3c-User-Roles="shell:roles="network-admin"" *Jan 25 14:24:28:245 2024 h3c_fw RADIUS/7/PACKET: -COntext=1; 02 bc 00 5b 6b 75 86 c1 ee da cb b3 b0 65 2f e2 3f 13 eb bf 06 06 00 00 00 01 0f 06 00 00 00 34 0f 06 00 00 00 32 0f 06 00 00 00 35 1a 0c 00 00 63 a2 1d 06 00 00 00 03 1a 23 00 00 63 a2 9b 1d 73 68 65 6c 6c 3a 72 6f 6c 65 73 3d 22 6e 65 74 77 6f 72 6b 2d 61 64 6d 69 6e 22 *Jan 25 14:24:28:245 2024 h3c_fw RADIUS/7/ERROR: -COntext=1; The login-service type that server assigned does not match with the access type. *Jan 25 14:24:28:245 2024 h3c_fw RADIUS/7/EVENT: -COntext=1; Sent reply message successfully. *Jan 25 14:24:28:245 2024 h3c_fw RADIUS/7/EVENT: -COntext=1; PAM_RADIUS: Processing RADIUS authentication. *Jan 25 14:24:28:245 2024 h3c_fw RADIUS/7/EVENT: -COntext=1; PAM_RADIUS: Fetched authentication reply-data successfully, resultCode: 1 %Jan 25 14:24:28:246 2024 h3c_fw WEB/5/LOGIN_FAILED: -COntext=1; h3c-administrator@hajyw.lan 从 x.x.x.x 登录失败.
zhiliao_VIJc1u 发表时间:2024-01-25
粉丝:17人 关注:9人
如果要实现弹出网页认证,建议使用portal认证。
另外可以尝试使用http看下是否能认证。
zhiliao_VIJc1u 知了小白
Login-Service=SSH
Login-Service=53
不是要实现Portal,是登录防火墙/无线AC设备的管理网页,RADIUS对接了LDAP,这样以后一个地方改密码就行了,不需要每个设备都改一次密码。
SSH已经可以了,就是HTTPS网页登录不了管理页面。
