WAC380-60本地Portal MAC-Trigger+LDAP认证无感知重认证问题
2024-01-26提问
  • 0收藏,253浏览
WAC380-60配置本地Portal MAC-Trigger快速认证,采用LDAP账号认证登录,现在问题是如果每天连接同一个wifi,不用重认证,隔一天再次连接WiFi就会弹出界面需要认证,认证后不能上网,需要下线重新再次认证才可以上网。
配置如下:
dhcp server ip-pool vlan1033
 gateway-list 192.100.33.254
 network 192.100.33.0 mask 255.255.255.0
 dns-list 114.114.114.114 223.5.5.5
 expired day 0 hour 8
interface Vlan-interface1033
 ip address 192.100.33.254 255.255.255.0
 dhcp server apply ip-pool vlan1033
ldap server ldap
 login-dn cn=acadmin,cn=users,dc=gwdg,dc=com,dc=cn
 search-base-dn dc=gwdg,dc=com,dc=cn
 ip 192.100.4.53
 login-password cipher $c$3$Ko8C9FkYIL4QCWta4S2HIgPZdtPVjB2ZCyUWDYaw
 user-parameters user-name-attribute samaccountname
ldap scheme ldap
 authentication-server ldap
domain ldap
 authorization-attribute idle-cut 43200 1024
 authentication portal ldap-scheme ldap
 authorization portal none
 accounting portal none
domain local
 authorization-attribute idle-cut 43200 10240
 authentication portal local
 portal free-rule 10 destination ip any tcp 53
 portal free-rule 20 destination ip any udp 53
portal web-server portal
 url http://192.100.33.254/portal
portal local-web-server http
 default-logon-page abc2.zip
portal mac-trigger-server portal
 ip 192.100.33.254
 local-binding aging-time 43200
 local-binding enable
 portal roaming enable
 undo portal refresh arp enable
wlan service-template portal
 ssid portal
 vlan 1033
 portal enable method direct
 portal domain ldap
 portal apply web-server portal
 portal apply mac-trigger-server portal
 service-template enable
粉丝:158人 关注:8人
认证服务器上把无感知时间调整长一些
43200分钟了
zhiliao_9UE8k9 发表时间:2024-01-26
