H3C S5500V2如何通VLAN?最好有相关视频,谢谢
与海康威视解码器联网,需要通VLAN解码上墙
(0)
当傻瓜交换机的话不配置就可以,如果需要指定vlan
sys
vlan 10
interface G1/0/1
port accent vlan 10
(0)
以下是VLAN划分的方法,请参考:
方法一举例:
[H3C]vlan 10 //创建VLAN
[H3C-vlan10]port gi 1/0/1 to gi 1/0/10 //直接划分到1口到10口
[H3C-vlan10]quit
[H3C]dis vlan 10 //查看VLAN的信息
VLAN ID: 10
VLAN type: Static
Description: VLAN 0010
Tagged ports: None
Untagged ports:
GigabitEthernet1/0/1 GigabitEthernet1/0/2
GigabitEthernet1/0/3 GigabitEthernet1/0/4
GigabitEthernet1/0/5 GigabitEthernet1/0/6
GigabitEthernet1/0/7 GigabitEthernet1/0/8
GigabitEthernet1/0/9 GigabitEthernet1/0/10
方法二举例:
[H3C]vlan 20 //创建VLAN 20
[H3C-vlan20]quit
[H3C]int range gi 1/0/20 to gi 1/0/30 //批量进入20口到30口
[H3C-if-range]port link-type access //将端口配置为access模式
[H3C-if-range]port access vlan 20 //将VLAN 20划分到20口到30口
[H3C-if-range]quit
[H3C]dis vlan 20 //查看VLAN信息
VLAN ID: 20
VLAN type: Static
Description: VLAN 0020
Tagged ports: None
Untagged ports:
GigabitEthernet1/0/20 GigabitEthernet1/0/21
GigabitEthernet1/0/22 GigabitEthernet1/0/23
GigabitEthernet1/0/24 GigabitEthernet1/0/25
GigabitEthernet1/0/26 GigabitEthernet1/0/27
GigabitEthernet1/0/28 GigabitEthernet1/0/29
GigabitEthernet1/0/30
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
