支持硬盘的防火墙怎么查看存储空间呢
2024-01-27提问
  • 0收藏,272浏览
支持硬盘的防火墙怎么查看存储空间呢
粉丝:29人 关注:2人
可以参考如下
RBM_S<F1090_S>cd h
RBM_S<F1090_S>cd hd
The file or directory doesn't exist.
RBM_S<F1090_S>dir
Directory of flash: (VFAT)
0 -rw- 15138816 Nov 23 2023 14:08:48 F1090FW-CMW710-BOOT-F8690P07.bin
1 -rw- 23916544 Nov 24 2023 10:16:28 F1090FW-CMW710-BOOT-R8601P2415.bin
2 -rw- 25333760 Jan 17 2024 22:18:22 F1090FW-CMW710-BOOT-R8660P33.bin
3 -rw- 25344000 Jan 28 2024 02:35:36 F1090FW-CMW710-BOOT-R8660P40.bin
4 -rw- 20124672 Dec 26 2023 08:53:34 F1090FW-CMW710-BOOT-R8660P41.bin
5 -rw- 18570240 Jan 17 2024 14:18:32 F1090FW-CMW710-SECESCAN-R8660P33.bin
6 -rw- 18570240 Oct 09 2023 22:14:58 F1090FW-CMW710-SECESCAN-R8660P37.bin
7 -rw- 18570240 Nov 19 2023 09:53:34 F1090FW-CMW710-SECESCAN-R8660P40.bin
8 -rw- 181064704 Nov 23 2023 14:09:20 F1090FW-CMW710-SYSTEM-F8690P07.bin
9 -rw- 155838464 Nov 24 2023 10:16:30 F1090FW-CMW710-SYSTEM-R8601P2415.bin
10 -rw- 145844224 Jan 17 2024 22:18:32 F1090FW-CMW710-SYSTEM-R8660P33.bin
11 -rw- 150490112 Oct 10 2023 14:14:58 F1090FW-CMW710-SYSTEM-R8660P37.bin
12 -rw- 150423552 Jan 28 2024 02:37:46 F1090FW-CMW710-SYSTEM-R8660P40.bin
13 -rw- 102501376 Dec 26 2023 08:53:34 F1090FW-CMW710-SYSTEM-R8660P41.bin
14 drw- - Dec 27 2023 02:41:06 SecpCount
15 drw- - Feb 22 2024 16:57:50 WEB
16 -rw- 3360117 Feb 25 2024 09:46:03 a.txt
17 drw- - Feb 18 2022 13:11:06 appproxy
18 drw- - Jan 17 2024 14:39:04 context
19 drw- - Feb 09 2022 20:26:34 core
20 -rw- 513751 Feb 22 2024 16:17:10 defaultfile.zip
21 -rw- 220095 Apr 20 2023 18:24:54 diag_F1090_S_20230420-182439.tar.gz
22 drw- - May 18 2021 18:31:52 diagfile
23 drw- - Sep 01 2022 16:29:32 dpi
24 -rw- 735 Oct 08 2022 09:04:56 hostkey
25 -rw- 735 Sep 22 2022 00:03:08 hostkey2
26 -rw- 13684 Nov 17 2023 16:41:28 iccrunning.cfg
27 -rw- 782664 Nov 17 2023 16:41:28 iccrunning.mdb
28 drw- - Sep 10 2021 11:36:36 lb
29 -rw- 111720 Feb 22 2024 16:17:51 lbispinfo_v1.5.tp
30 drw- - May 23 2021 22:35:26 license
31 -rw- 22484 Nov 16 2023 09:56:08 llysb.cfg
32 -rw- 865582 Nov 16 2023 09:56:08 llysb.mdb
33 drw- - Jan 31 2023 18:46:32 logfile
34 drw- - Feb 22 2024 15:51:04 pcap
35 drw- - Dec 23 2021 01:21:26 pkey
36 drw- - Dec 23 2021 01:21:26 pki
37 -rw- 33 Dec 27 2023 02:39:58 raid_manager.log
38 -rw- 804 Feb 24 2024 22:44:31 rbmSwitchInfoFile.dat
39 drw- - Feb 09 2021 18:57:08 seclog
40 -rw- 591 Oct 08 2022 09:04:56 serverkey
41 drw- - Dec 06 2021 15:34:30 sslvpn
42 -rw- 13789 Feb 23 2024 13:47:49 startup.cfg
43 -rw- 805327 Feb 23 2024 13:47:50 startup.mdb
44 -rw- 10 Nov 23 2023 06:13:56 userloginInfo.dat
45 drw- - Dec 06 2021 15:29:06 versionInfo
46 drw- - Dec 06 2021 15:29:22 webtmp
47 -rw- 22384 Jan 24 2024 21:50:56 zjhtest.cfg
48 -rw- 841436 Jan 24 2024 21:50:56 zjhtest.mdb
7456500 KB total (6236940 KB free)
lilili 九段
粉丝:15人 关注:1人
<  >视图 dir指定硬盘
Xcheng 九段
粉丝:121人 关注:3人
dir
dir命令用来显示当前文件夹或文件信息。
dir [ /all ] [ file | directory | /all-filesystems ]
context-admin
/all:显示当前文件夹下所有的文件及文件夹信息,包括非隐藏文件、非隐藏文件夹、隐藏文件和隐藏文件夹。不指定该参数时,只显示非隐藏文件和非隐藏文件夹。
file:显示指定的文件的信息。file参数支持通配符“*”,例如dir *.txt可以显示当前文件夹下所有以txt为扩展名的文件。
directory:显示指定的文件夹的信息。
/all-filesystems:显示设备上所有文件系统根目录下的文件及文件夹信息。
不使用任何参数时,用来显示当前文件夹下所有可见文件及文件夹的信息。
回收站的文件夹名称为“.trash”,如需查看回收站内的文件,请用dir /all .trash,或者cd .trash进入回收站文件夹后,再用dir命令查看。
对于EXT4类型的文件系统,1%的空间为系统保留空间,通过dir命令查看到的可用空间不包含保留空间。
多用户同时执行文件操作时,比如同时创建或删除文件或文件夹,可能导致该命令显示结果不准确。
# 显示当前文件夹下所有的文件及文件夹信息。
<Sysname> dir /all
Directory of flash: (YAFFS2)
……略……
# 显示设备上所有文件系统根目录下的文件及文件夹信息。
<Sysname> dir /all-filesystems
……略……
表1-2 dir命令显示信息描述表
Directory of XX: (xx)
当前显示的目录:
·     XX表示当前目录名
·     xx表示当前目录所在文件系统的类型
0     -rwh      3144  Apr 26 2014 13:45:28  xx.xx
文件或文件夹的信息:
·     0表示编号,由系统自动分配
·     -rwh表示属性。第一个字符如果是d表示文件夹,如果显示为“-”,则表示它是文件;第二个字符是r,表示本文件或文件夹是可读的;第三个字符是w,表示本文件或文件夹是可写的;第四个字符如果是h,表示本文件或文件夹是隐藏的,如果显示为“-”,则表示它是非隐藏的(请不要修改或删除隐藏文件或文件夹,以免影响对应功能)
·     3144表示文件大小,单位为B。如果显示为“-”,则表示它是文件夹
·     Apr 26 2014 13:45:28表示最近一次修改的时间
·     xx.xx表示名称
