poe交换机问题
2024-01-31提问
  • 0收藏,288浏览
1、AP掉线了,检查交换机发现有接口是  Power-deny的
===============display poe device===============
Slot  1:
 PSE ID    Slot No.  SSlot No. PortNum   MaxPower(W)    State   Model
 4         1         0         24        0.0            On      LSPPSE24B
  ===============display poe interface===============
 Interface    PoE       Priority  CurPower  Oper      IEEE  Detection
                                  (W)                 Class Status
 GE1/0/1      Enabled   Low       0.0       Off       0     Searching
 GE1/0/2      Enabled   Low       0.0       Power-deny0     PD Disconnected
 GE1/0/3      Enabled   Low       0.0       Power-deny0     PD Disconnected
 GE1/0/4      Enabled   Low       0.0       Off       0     Searching
 GE1/0/5      Enabled   Low       0.0       Power-deny0     PD Disconnected
2、交换机电源状态如下:
  ===============display power===================
 Slot 1:
 PowerID State    Mode   Current(A)  Voltage(V)  Power(W)
 1       Fault    DC        --          --          --
 2       Fault    AC        --          --          --
3、交换机日志如下:
%Jan 30 00:31:23:101 2013 AGRJ-96.79 DEV/5/POWER_RECOVERED: Power 2 recovered.
%Jan 30 00:31:23:896 2013 AGRJ-96.79 DEV/2/POWER_FAILED: Power 2 failed.
%Jan 30 00:31:25:496 2013 AGRJ-96.79 DEV/5/POWER_RECOVERED: Power 2 recovered.
%Jan 30 00:31:31:901 2013 AGRJ-96.79 DEV/2/POWER_FAILED: Power 2 failed.
%Jan 30 00:31:34:301 2013 AGRJ-96.79 DEV/5/POWER_RECOVERED: Power 2 recovered.
%Jan 30 00:31:35:096 2013 AGRJ-96.79 DEV/2/POWER_FAILED: Power 2 failed.
%Jan 30 00:31:39:096 2013 AGRJ-96.79 DEV/5/POWER_RECOVERED: Power 2 recovered.
%Jan 30 00:31:43:098 2013 AGRJ-96.79 DEV/2/POWER_FAILED: Power 2 failed.
%Jan 30 00:31:43:896 2013 AGRJ-96.79 DEV/5/POWER_RECOVERED: Power 2 recovered.
%Jan 30 00:31:45:496 2013 AGRJ-96.79 DEV/2/POWER_FAILED: Power 2 failed.
%Jan 30 00:31:53:497 2013 AGRJ-96.79 DEV/5/POWER_RECOVERED: Power 2 recovered.
%Jan 30 00:31:59:896 2013 AGRJ-96.79 DEV/2/POWER_FAILED: Power 2 failed.
%Jan 30 00:32:04:701 2013 AGRJ-96.79 DEV/5/POWER_RECOVERED: Power 2 recovered.
%Jan 30 00:32:05:496 2013 AGRJ-96.79 DEV/2/POWER_FAILED: Power 2 failed.
%Jan 30 00:32:08:697 2013 AGRJ-96.79 DEV/5/POWER_RECOVERED: Power 2 recovered.
%Jan 30 00:32:09:496 2013 AGRJ-96.79 DEV/2/POWER_FAILED: Power 2 failed.
问题:从上面的内容可以看出是交换机电源供电不足的问题吗?或者是其他的问题?
佚名 九段
粉丝:22人 关注:0人
交换机电源故障了,无法供电了,交叉测试看看是电源模块问题还是电源槽位问题
4 个回答
粉丝:112人 关注:8人
 power-deny:拒绝供电,PD要求功率大于配置功率
交换机日志是电源故障,拔插一下试试,还不行400保修
poe 故障排查故障:
1、、检测受电PD设备供电方式
检测对端受电的PD设备是空闲线供电还是信号线供电。目前我司交换机设备仅支持信号线供电方式。
2、检测供电设备与受电PD设备之间的网线距离
建议供电设备与受电PD设备之前使用超5类及以上规格的双绞线,同时距离小于100米。
3、使能非标准PD检测功能
PD设备分为标准PD和非标准PD,标准PD是指符合IEEE 802.3af标准的PD设备。默认情况下,我司设备只能检测到标准PD,并为其供电。只有在我司设备上时能检测非标准PD功能后,设备才能检测到非标准PD,并为其供电。
命令:poe legacy enable pse pse-id
例如:通过命令使能设备非标准PD检测功能。
4、检测设备故障PoE接口的工作状态
查看POE接口工作状态,检测是否由于PD要求功率过大或供电设备剩余功率不足导致无法POE供电。
命令:display poe interface gigabitethernet
例如:通过命令查看POE接口工作状态
Port Operating Status
? off:供电功能禁用
? on:正在正常供电
? power-lack:PSE剩余保证功率不够,导致无法对优先级为Critical的PoE接口供电
? power-deny:拒绝供电,PD要求功率大于配置功率
? power-itself:外接设备正在自己供电
? power-limit:正在受限供电,PD要求功率大于配置功率,PSE仍按配置功率供电
Port Detection Status
? disabled:PoE接口供电禁止
? searching:正在搜索PD
? delivering-power:正在向PD供电
? fault:错误
? test:测试状态
? other-fault:其他错误状态
? pd-disconnect:PD未连接
5、接口使能poe enable是否提示错误
设备接口使能poe enable时是否提示错误。
以上还不能解决:
7、采集反馈设备相关POE故障信息
如果接口使能POE功能时没有提示错误,请收集如下信息后,反馈给400售后工程师。
(1)收集故障时设备上poe状态信息
<H3C>display power
<H3C>display poe pse
<H3C>display poe interface
<H3C>display poe interface power
进入调试视图收集
联系售后400 协助处理;
粉丝:6人 关注:0人
两个电源都是FAULT的,电源坏了
重新插拔或者互换一下看看
粉丝:119人 关注:1人
<Sysname> display poe pse
这个命令可以看总功率、剩余功率、用了多少功率
粉丝:8人 关注:0人
根据您提供的信息,我认为可能的原因有以下几种:
1. 交换机的电源模块故障,导致交换机无法正常供电,从而影响了poe接口的供电能力。您可以检查交换机的电源模块是否有损坏或松动,或者更换其他正常的电源模块,看是否能恢复poe接口的供电状态。
2. 交换机的poe控制芯片故障,导致交换机无法正确检测和管理poe接口的供电情况,从而导致poe接口出现power-deny的状态。您可以检查交换机的poe控制芯片是否有损坏或过热,或者重启交换机,看是否能恢复poe接口的供电状态。
3. 交换机的poe供电功率不足,导致交换机无法为所有的poe接口提供足够的功率,从而导致poe接口出现power-deny的状态。您可以检查交换机的poe供电功率是否达到标准,或者减少poe接口的负载,看是否能恢复poe接口的供电状态。
4. 交换机的poe供电配置错误,导致交换机无法为某些poe接口提供正确的供电方式,从而导致poe接口出现power-deny的状态。您可以检查交换机的poe供电配置是否正确,或者使用默认的poe供电配置,看是否能恢复poe接口的供电状态。
