GRE over IPsec VPN配置
2024-02-07提问
  • 0收藏,335浏览
求一份GRE over IPsec VPN配置,在上面找了几个配置了都不得行
粉丝:29人 关注:2人
主要配置如下:
FW1日志源主要配置
路由配置:
ip route-static 0.0.0.0 0 202.0.0.2
 ip route-static 2.2.2.0 24 Tunnel0
快速日志配置:
customlog format packet-filter
 customlog host 2.2.2.1 export packet-filter
 customlog host source LoopBack10
接口配置:
interface LoopBack0
 ip address 11.11.11.11 255.255.255.255
interface LoopBack10
 ip address 1.1.1.1 255.255.255.255
 port link-mode route
 combo enable copper
 ip address 202.0.0.1 255.255.255.0
 ipsec apply policy vpn
安全域与安全策略配置
security-zone name Trust
 import interface GigabitEthernet1/0/1
 import interface Tunnel0
security-policy ip(日志记录功能要打开)
 rule 0 name 0
  action pass
  logging enable
GRE主要配置
一定不要配置探测
interface Tunnel0 mode gre
 ip address 10.0.0.1 255.255.255.252
 source LoopBack0
 destination 22.22.22.22
 gre key 123
IPSSEC主要配置
acl advanced 3000
 rule 0 permit gre source 11.11.11.11 0 destination 22.22.22.22 0
ipsec transform-set tran1
 esp encryption-algorithm aes-cbc-256
 esp authentication-algorithm sha1
ipsec policy vpn 1 isakmp
 transform-set tran1
 security acl 3000
 remote-address 202.0.0.2
 ike-profile profile1
 ike identity fqdn vpn1
ike profile profile1
 keychain keychain1
 local-identity address 202.0.0.1
 match remote identity address 202.0.0.2 255.255.255.0
 proposal 1
ike proposal 1
 dh group2
ike keychain keychain1
 pre-shared-key address 202.0.0.2 255.255.255.255 key simple 123
FW2主要配置如下:
路由配置:
ip route-static 0.0.0.0 0 202.0.0.1
 ip route-static 1.1.1.0 24 Tunnel0
接口配置:
interface LoopBack0
 ip address 22.22.22.22 255.255.255.255
interface GigabitEthernet1/0/0
 combo enable copper
 ip address 2.2.2.2 255.255.255.0
 combo enable copper
 ip address 202.0.0.2 255.255.255.0
安全域与安全策略配置
 import interface GigabitEthernet1/0/0
security-policy ip
 rule 0 name 0
  action pass
GRE主要配置
一定不要配置探测
 ip address 10.0.0.2 255.255.255.252
 source LoopBack0
 destination 11.11.11.11
 gre key 123
IPSSEC主要配置
acl advanced 3000
 rule 0 permit gre source 22.22.22.22 0 destination 11.11.11.11 0
 transform-set tran1
 security acl 3000
 remote-address 202.0.0.1
 ike identity fqdn vpn2
 keychain keychain1
 local-identity address 202.0.0.2
 match remote identity address 202.0.0.1 255.255.255.0
 proposal 1
ike proposal 1
 dh group2
 pre-shared-key address 202.0.0.1 255.255.255.255 key simple 123
日志服务器配置:
ip route-static 1.1.1.0 24 2.2.2.2
interface GigabitEthernet0/0
 combo enable copper
 ip address 2.2.2.1 255.255.255.0
配置完成之后测试结果如下:
FW1上以1.1.1.1为源地址ping2.2.2.1,可以看到FW1IKE SAIPSEC SA均已建立
[FW1]ping -a 1.1.1.1 2.2.2.1
Ping 2.2.2.1 (2.2.2.1) from 1.1.1.1: 56 data bytes, press CTRL+C to break
56 bytes from 2.2.2.1: icmp_seq=0 ttl=254 time=2.000 ms
56 bytes from 2.2.2.1: icmp_seq=1 ttl=254 time=1.000 ms
56 bytes from 2.2.2.1: icmp_seq=2 ttl=254 time=1.000 ms
56 bytes from 2.2.2.1: icmp_seq=3 ttl=254 time=3.000 ms
56 bytes from 2.2.2.1: icmp_seq=4 ttl=254 time=1.000 ms
--- Ping statistics for 2.2.2.1 ---
round-trip min/avg/max/std-dev = 1.000/1.600/3.000/0.800 ms
[FW1]
[FW1]
[FW1]%Jul 16 14:20:41:836 2022 FW1 PING/6/PING_STATISTICS: -COntext=1; Ping statistics for 2.2.2.1: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.000/1.600/3.000/0.800 ms.
dis ike sa
    Connection-ID   Remote                Flag         DOI
    1               202.0.0.2/500         RD           IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
[FW1]dis
[FW1]display ips
[FW1]display ipsec sa
  IPsec policy: vpn
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Transmitting entity: Initiator
    Path MTU: 1428
    Tunnel:
        local  address: 202.0.0.1
        remote address: 202.0.0.2
    Flow:
        sour addr: 11.11.11.11/255.255.255.255  port: 0  protocol: gre
        dest addr: 22.22.22.22/255.255.255.255  port: 0  protocol: gre
    [Inbound ESP SAs]
      SPI: 1902679672 (0x71689678)
      Connection ID: 4294967296
      Transform set: ESP-ENCRYPT-AES-CBC-256 ESP-AUTH-SHA1
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843195/1989
      Max received sequence-number: 34
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 4170074684 (0xf88e4a3c)
      Connection ID: 4294967297
      SA remaining duration (kilobytes/sec): 1843190/1989
      Max sent sequence-number: 47
      Status: Active
在日志服务器上抓包,可以看到FW1产生的syslog日志
配置关键点:
1.      配置快速日志的源目要走tunnel
2.      快速日志必须以GRE OVER IPSEC的方式加密,因为快速日志如果以IPSEC加密方式发送,将不走安全策略业务点
3.      安全策略中将log enable打开
4.      安全策略日志模块为packet-filter
粉丝:119人 关注:1人
H3C GRE over IPsec VPN是一种在不安全的网络上建立安全的隧道的技术,它可以实现不同地域的网络之间的互联和数据传输。GRE over IPsec VPN的配置步骤大致如下:
  • 在两端的设备上配置公网接口和内网接口,并将它们加入到不同的安全区域。
  • 在两端的设备上配置环回接口,作为建立GRE隧道的源地址和目的地址。
  • 在两端的设备上配置GRE隧道接口,并将它们加入到安全区域。
  • 在两端的设备上配置IPSec策略,包括定义需要保护的数据流、配置IPSec安全提议、创建IKE安全提议、配置IKE对等体。
  • 在两端的设备上的公网接口上应用IPSec策略。
  • 在两端的设备上配置策略路由,将GRE over IPsec的流量导向正确的出口。
  • 在两端的设备上配置域间策略,放通GRE over IPsec的流量和业务网段的流量。
  • 在两端的设备上配置静态路由,指定业务网段的下一跳和GRE over IPsec的目的地址。
如果您想查看具体的配置举例,您可以参考以下的网页:
