路由器MSR2600+CPU过高如何解决
2024-02-20提问
  • 0收藏,236浏览
不清楚哪里引起路由器cpu报错,Cpu usage threshold has been exceeded,以下为配置:
version 7.1.064, Release 0809P33
sysname H3C
security-zone intra-zone default permit
ip load-sharing mode per-flow src-ip global
nat static inbound 117.159.229.25 10.7.168.200 description hik
nat static outbound 10.7.168.200 117.159.229.25 description hik
dhcp enable
dhcp server always-broadcast
dns proxy enable
password-recovery enable
vlan 1
controller Cellular0/0
interface Aux0
interface Dialer0
mtu 1492
interface Dialer1
mtu 1492
interface NULL0
interface Vlan-interface1
description LAN-interface
ip address 10.7.168.1 255.255.255.0
tcp mss 1280
undo dhcp select server
ip subscriber l2-connected enable
ip subscriber initiator dhcp enable
ip subscriber initiator unclassified-ip enable
ip subscriber dhcp domain ipoeenabledomain
ip subscriber unclassified-ip domain ipoeenabledomain
interface GigabitEthernet0/0
port link-mode route
description Double_Line1
speed 1000
ip address 39.164.83.144 255.255.255.128
dns server 211.138.24.66
dns server 211.138.30.66
tcp mss 1280
ip last-hop hold
packet-filter name WebPing2 inbound
packet-filter name WebHttpHttps2 inbound
nat outbound
nat server protocol tcp global current-interface 53 inside 10.7.168.13 56666
nat server protocol tcp global current-interface 76 inside 10.7.168.16 80
nat server protocol tcp global current-interface 78 inside 10.7.168.15 80
nat server protocol tcp global current-interface 81 inside 10.7.168.10 80
nat server protocol tcp global current-interface 83 inside 10.7.168.14 83
nat server protocol tcp global current-interface 84 inside 10.7.168.13 23
nat server protocol tcp global current-interface 85 inside 10.7.168.14 55554
nat server protocol tcp global current-interface 86 inside 10.7.168.12 222
nat server protocol tcp global current-interface 123 inside 10.7.168.14 123
nat server protocol tcp global current-interface 552 inside 10.7.168.15 555
nat server protocol tcp global current-interface 553 inside 10.7.168.15 555
nat server protocol tcp global current-interface 554 inside 10.7.168.14 554
nat server protocol tcp global current-interface 559 inside 10.7.168.14 559
nat server protocol tcp global current-interface 655 inside 10.7.168.14 655
nat server protocol tcp global current-interface 1443 inside 10.7.168.14 443
nat server protocol tcp global current-interface 1935 inside 10.7.168.14 1935
nat server protocol tcp global current-interface 5010 inside 10.7.168.14 5010
nat server protocol tcp global current-interface 6009 inside 10.7.168.14 6009
nat server protocol tcp global current-interface 6014 inside 10.7.168.14 6015
nat server protocol tcp global current-interface 6633 inside 192.168.2.1 6633
nat server protocol tcp global current-interface 7010 inside 10.7.168.14 7010
nat server protocol tcp global current-interface 7031 inside 10.7.168.14 7031
nat server protocol tcp global current-interface 7033 inside 10.7.168.14 7033
nat server protocol tcp global current-interface 7087 inside 10.7.168.14 7087
nat server protocol tcp global current-interface 7099 inside 10.7.168.14 7199
nat server protocol tcp global current-interface 7100 inside 10.7.168.14 7100
nat server protocol tcp global current-interface 7302 inside 10.7.168.14 7303
nat server protocol tcp global current-interface 7304 inside 10.7.168.14 7304
nat server protocol tcp global current-interface 7307 inside 10.7.168.14 7307
nat server protocol tcp global current-interface 7314 inside 10.7.168.14 7314
nat server protocol tcp global current-interface 7660 inside 10.7.168.14 7660
nat server protocol tcp global current-interface 8000 inside 10.7.168.10 8001
nat server protocol tcp global current-interface 8001 inside 10.7.168.14 8001
nat server protocol tcp global current-interface 8002 inside 10.7.168.16 8001
nat server protocol tcp global current-interface 8003 inside 10.7.168.15 8001
nat server protocol tcp global current-interface 8098 inside 10.7.168.1 8098
nat server protocol tcp global current-interface 8201 8202 inside 10.7.168.13 8201 8202
nat server protocol tcp global current-interface 8204 inside 10.7.168.13 8204
nat server protocol tcp global current-interface 8208 8220 inside 10.7.168.13 8208 8220
nat server protocol tcp global current-interface 8222 8400 inside 10.7.168.13 8222 8400
nat server protocol tcp global current-interface 8603 inside 10.7.168.14 10000
nat server protocol tcp global current-interface 8800 8999 inside 10.7.168.14 8800 8999
nat server protocol tcp global current-interface 9017 inside 10.7.168.14 10000
nat server protocol tcp global current-interface 9018 inside 10.7.168.14 9017
nat server protocol tcp global current-interface 14998 14999 inside 10.7.168.200 14998 14999
nat server protocol tcp global current-interface 15000 16999 inside 10.7.168.14 15000 16999
nat server protocol tcp global current-interface 17000 inside 10.7.168.14 17000
nat server protocol tcp global current-interface 55555 inside 10.7.168.14 55554
nat server protocol udp global current-interface 53 inside 10.7.168.13 56666
nat static enable
interface GigabitEthernet0/1
description Double_Line2
duplex full
speed 1000
ip address 117.159.229.25 255.255.255.192
dns server 114.114.114.114
dns server 8.8.8.8
tcp mss 1280
ip last-hop hold
packet-filter name WebPing3 inbound
packet-filter name WebHttpHttps3 inbound
nat outbound
nat server protocol tcp global current-interface 55555 inside 192.168.100.2 55554
nat static enable
interface GigabitEthernet0/2
port link-mode bridge
port link-type trunk
port trunk permit vlan 1
speed 1000
interface GigabitEthernet0/3
speed 1000
duplex full
interface GigabitEthernet0/4
speed 1000
duplex full
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
security-zone name Local
security-zone name Trust
security-zone name DMZ
security-zone name Untrust
security-zone name Management
scheduler logfile size 16
line class aux
user-role network-admin
line class tty
user-role network-operator
line class usb
line class vty
line aux 0
line vty 0 63
authentication-mode scheme
ip route-static 0.0.0.0 0 GigabitEthernet0/0 39.164.83.129
ip route-static 0.0.0.0 0 GigabitEthernet0/1 117.159.229.1
acl advanced name WebHttpHttps2
rule 0 permit tcp source 59.41.46.147 0 destination-port eq www
rule 1 permit tcp source 59.41.46.147 0 destination-port eq 8098
rule 2 permit tcp source 59.41.46.148 0 destination-port eq www
rule 3 permit tcp source 59.41.46.148 0 destination-port eq 8098
rule 4 permit tcp source 59.41.46.145 0 destination-port eq www
rule 5 permit tcp source 59.41.46.145 0 destination-port eq 8098
rule 6 permit tcp source 14.116.207.97 0 destination-port eq www
acl advanced name WebHttpHttps3
rule 65533 deny tcp destination-port eq www
rule 65534 deny tcp destination-port eq 8098
acl advanced name WebPing2
rule 1 deny icmp icmp-type echo
acl advanced name WebPing3
password-control enable
undo password-control aging enable
undo password-control history enable
password-control length 6
password-control login-attempt 3 exceed lock-time 10
password-control update-interval 0
password-control login idle-time 0
authentication ipoe none
authorization ipoe none
accounting ipoe none
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
service-type telnet http https
session statistics enable
l2tp enable
ip https port 8098
ip http enable
ip https enable
web new-style
wlan global-configuration
wlan ap-group default-group
vlan 1
uapp-control
policy name AuditLog audit
  source-zone trust
  destination-zone untrust
  rule 1 any behavior any bhcontent any keyword equal any action permit audit-logging
dac storage service audit limit hold-time 1
dac storage service traffic limit hold-time 1
return
粉丝:137人 关注:8人
检查下什么进程高吧
dis process cpu
kdrvfwdd0的程序占用96%
zhiliao_T3Abh 发表时间:2024-02-20
转发进程高,网关没在路由器上吧?
zhiliao_sEUyB 发表时间:2024-02-20
粉丝:119人 关注:1人
参考这个文档:
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Home/Routers/00-Public/Maintenance/Troubleshooting/H3C_MSR_V7_R6728-4883/
