交换机日志经常显示接口跑满最大的速率,但zabbix 监控到才100M左右,接口是1000M通道的,请问怎么回事
2024-02-21提问
  • 0收藏,283浏览
粉丝:0人 关注:4人
%May 20 23:59:52:425 2013 CW-18F-core-8.1 DRVPLAT/4/SOFTCAR DROP: -Slot=2;
 PktType= MSDP , srcMAC=ccd3-9d90-f4bc, Drop From Interface=XGE2/0/14    at Stage=63, StageCnt=157 TotalCnt=236155, Max Rate Interface=XGE2/0/14    !!
佚名 九段
粉丝:22人 关注:0人
这个日志不是表示接口速率,是设备cpu对这个协议报文处理的能力超速率了,为了保护cpu,设备对每种协议报文都设定了一定的处理速率,一般是几百几千pps,超过就会打印这个
4 个回答
粉丝:232人 关注:0人
您好,用以下命令看一下速率
dis inter g1/0/1
[CW-18F-core-8.1]dis interface Ten-GigabitEthernet 2/0/14 Ten-GigabitEthernet2/0/14 Current state: UP Line protocol state: UP IP packet frame type: Ethernet II, hardware address: 0c3a-fa32-145e Description: Ten-GigabitEthernet2/0/14 Interface Bandwidth: 1000000 kbps Loopback is not set Media type is twisted pair, Port hardware type is 1000_BASE_T_AN_SFP 1000Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 10000 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 150 MDI type: Automdix Port link-type: Access Tagged VLANs: None Untagged VLANs: 150 Port priority: 0 Last link flapping: 10 weeks 2 days 1 hours 20 minutes Last clearing of counters: Never Current system time:2013-05-21 00:22:42 beijing+08:00:00 Last time when physical state changed to up:2013-03-09 23:02:36 beijing+08:00:00 Last time when physical state changed to down:2013-03-09 23:02:32 beijing+08:00:00 Peak input rate: 119816045 bytes/sec, at 2013-05-06 01:05:27 Peak output rate: 114140302 bytes/sec, at 2013-04-08 01:08:02 Last 300 seconds input: 10347 packets/sec 9143308 bytes/sec 7% Last 300 seconds output: 11268 packets/sec 3243369 bytes/sec 3% Input (total): 57963252671 packets, 49751064986900 bytes 57954555658 unicasts, 29003 broadcasts, 1241 multicasts, 8666769 pauses Input (normal): 57954585897 packets, - bytes 57954555657 unicasts, 29003 broadcasts, 1241 multicasts, 8666769 pauses Input: 0 input errors, 0 runts, 0 giants, 0 throttles 0 CRC, 0 frame, - overruns, 0 aborts - ignored, - parity errors Output (total): 65847574012 packets, 34947962336700 bytes 65841100964 unicasts, 29674 broadcasts, 6443374 multicasts, 0 pauses Output (normal): 65847574012 packets, - bytes 65841100964 unicasts, 29674 broadcasts, 6443374 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions 0 lost carrier, - no carrier
zhiliao_lOzMum 发表时间:2024-02-21
粉丝:112人 关注:8人
这个日志并不是提示跑满最大的速率
z6Kl9 九段
粉丝:66人 关注:2人
MSDP概述
MSDPMulticast Source Discovery Protocol(组播源发现协议)的简称,是为了解决多个PIM-SMProtocol Independent Multicast Sparse Mode,协议无关组播—稀疏模式)域之间的互连而开发的一种域间组播解决方案,用来发现其它PIM-SM域内的组播源信息。
MSDP包过多,MSDP包超限速了,超过CPU的处理能力l
交换机的性能不够了吗
粉丝:119人 关注:1人
MSDP是组播
因为这个接口配置策略路由,会有大量流量经过,所以导致组播流量超负载吗
