PC-CE-PE-P-PE-CE-PC组网环境下,路由可以学习到,但是无法ping通
2024-02-22提问
  • 0收藏,363浏览
需求:VPN1内的PC_6 ping PC_8,但是不通,在PE上查看路由已经通过MPBGP学习到了,请各位大神帮忙看下配置是否有遗漏,组网以及配置在附件里,多谢
<H3C>ping  8.0.0.2
Ping 8.0.0.2 (8.0.0.2): 56 data bytes, press CTRL_C to break
Request time out
Request time out
[6850_3_PE]display ip routing-table vpn-instance vpn1
1.0.0.0/24         O_ASE2  150 1           3.0.0.1         GE1/0/1
6.0.0.0/24         BGP     255 0           15.15.15.15     GE1/0/3
8.0.0.0/24         BGP     255 2           15.15.15.15     GE1/0/3
PE上关键配置如下:
ip vpn-instance vpn1
 route-distinguisher 100:1
 vpn-target 110:1 import-extcommunity
 vpn-target 110:1 export-extcommunity
ip vpn-instance vpn2
 route-distinguisher 200:1
 vpn-target 210:1 import-extcommunity
 vpn-target 220:1 export-extcommunity
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
ospf 1 vpn-instance vpn1
 import-route direct
 import-route bgp 100
 domain-id 0.0.0.1
 vpn-instance-capability simple
 area 0.0.0.0
  network 3.0.0.0 0.0.0.255
ospf 2 vpn-instance vpn2
 area 0.0.0.0
  network 2.0.0.0 0.0.0.255
rip 1
 network 4.0.0.0 0.0.0.255
 network 13.13.13.13 0.0.0.0
 mpls lsr-id 13.13.13.13
mpls ldp
interface LoopBack0
 ip address 13.13.13.13 255.255.255.255
 rip 1 enable
 port link-mode route
 combo enable fiber
 ip binding vpn-instance vpn1
 ip address 3.0.0.2 255.255.255.0
 combo enable fiber
 shutdown
 ip binding vpn-instance vpn2
 ip address 2.0.0.2 255.255.255.0
 combo enable fiber
 ip address 4.0.0.1 255.255.255.0
 rip 1 enable
 mpls enable
 mpls ldp enable
bgp 100
 peer 15.15.15.15 as-number 100
 peer 15.15.15.15 connect-interface LoopBack0
 address-family ipv4 unicast
  import-route rip 1
  peer 15.15.15.15 enable
 address-family vpnv4
   import-route ospf 1
   network 3.0.0.0 255.255.255.0
检查下s6850_9有没有PC6的路由,检查下P设备间的ldp邻居起来没用,检查下P设备间环回口的标签学习是否正常
ce设备确实没有到对端PC的路由,CE设备上就配置了个OSPF,还需要配置啥吗? # ospf 1 import-route direct area 0.0.0.0 network 3.0.0.0 0.0.0.255 # interface GigabitEthernet1/0/2 port link-mode route combo enable fiber ip address 1.0.0.1 255.255.255.0 # interface GigabitEthernet1/0/3 port link-mode route combo enable fiber ip address 3.0.0.1 255.255.255.0 #
zhiliao_vpmPO9 发表时间:2024-02-22
bgp发布路由了吗?
甄姬拔菜 发表时间:2024-02-22
回复甄姬拔菜:
OSPF和BGP里都互引了
配置能导一份出来吗?
甄姬拔菜 发表时间:2024-02-23
粉丝:43人 关注:1人
加上vpn1 实例去ping
ping -vpn-instance  vpn1 8.0.0.2
是两个PC之间去ping,所以不需要去带vpn去ping
粉丝:0人 关注:7人
把hcl文件导出来
HCL文件在附件里
导出的有问题 打开是没配置的
雨下整夜 发表时间:2024-02-22
