AR18-63-1怎么恢复出厂设置
2017-09-12提问
  • 1收藏,1366浏览
Boot Menu:
     1:  Download application program with XMODEM
     2:  Download application program with NET
     3:  Display file in flash
     4:  Delete file from flash
     5:  Start up and ignore configuration
     6:  Enter debugging environment
     7:  Boot ROM Operation Menu
     8:  Do not check the version of the software
     9:  Exit and reboot
     Enter your choice(1-9):
出现这个界面后选什么
知了小白
粉丝: 关注:
出现这个界面之后选3,显示系统的文件,之后找到一个start.cfg的文件,然后删除,删除之后重启就恢复到出厂设置了。
zhiliao_81491 知了小白
Enter your choice(1-9):3
File Number       File Size(bytes)     File Name
1.                151                  private-data.txt
2.                1615                 config1.cfg
Free Space : 15990784 bytes
选择4,然后把config1.cfg这个文件删除
