S5560S-SI IPV6与电信光猫对接问题
2024-02-23提问
  • 0收藏,289浏览
设备:
电信光猫
华三S5560S-SI Release 6351P03
网络环境:
电信企业光猫拨号获得公网IPV4\IPV6,光猫有wifi+lan口(属于同网段)。其中光猫lan1口下挂H3C S5560S-SI的g1/0/24。
光猫有写回程IPV4路由,故现网IPV4网络正常。
光猫WIFI下终端IPV4/IPV6可正常访问互联网
问题:
S5560S-SI Release 6351P03下VLAN160的终端IPV6异常,无法通过IPV6访问互联网。
S5560S-SI配置(精简):
interface Vlan-interface160  (IPV4可访问互联网,IPV6无法访问互联网)
 description IPV4/IPV6-test
 ip address 10.18.16.1 255.255.255.0
 dhcp select relay
 dhcp relay server-address 10.18.12.230
 ipv6 dhcp select server
 ipv6 address 2 240E:35C:A0D:FD00:1600::1000/80
 ipv6 nd autoconfig other-flag
 undo ipv6 nd ra halt
 ipv6 nd ra dns server 240C::6666 infinite sequence 1
interface GigabitEthernet1/0/24 (接光猫LAN1口)
 port link-mode route
 description to_WAN_chinatelecom_internet_192.168.1.1
 ip address 192.168.1.3 255.255.255.0
 ipv6 address auto
说明:
1.IPV4静态路由省略,因IPV4网络正常。
2.IPV6静态路由未配置。
3.在H3C S5560S-SI上执行dis ipv6 int brief,结果如下
[asca]dis ipv6 int brief
*down: administratively down
(s): spoofing
Interface                                 Physical Protocol IPv6 Address
GigabitEthernet1/0/24                     up       up       240E:35C:A0D:FD00:7257:BFFF:FEE1:5F0
Vlan-interface160                         up       up       240E:35C:A0D:FD00:1600::1000
4.在H3C S5560S-SI上执行ping ipv6 240c::6666网络可达,结果如下
[asca]ping ipv6 240c::6666
Ping6(56 data bytes) 240E:35C:A0D:FD00:7257:BFFF:FEE1:5F0 --> 240C::6666, press CTRL+C to break
56 bytes from 240C::6666, icmp_seq=0 hlim=53 time=18.513 ms
56 bytes from 240C::6666, icmp_seq=1 hlim=53 time=17.761 ms
56 bytes from 240C::6666, icmp_seq=2 hlim=53 time=18.015 ms
56 bytes from 240C::6666, icmp_seq=3 hlim=53 time=23.046 ms
56 bytes from 240C::6666, icmp_seq=4 hlim=53 time=17.918 ms
--- Ping6 statistics for 240c::6666 ---
round-trip min/avg/max/std-dev = 17.761/19.051/23.046/2.013 ms
5.在H3C S5560S-SI上执行dis ipv6 routing-table
[asca]dis ipv6 routing-table
Destinations : 16       Routes : 16
Destination: ::/0                                        Protocol  : Direct
NextHop    : FE80::1                                     Preference: 80
Interface  : GE1/0/24                                    Cost      : 0
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 240E:35C:A0D:FD00::/64                      Protocol  : Direct
NextHop    : ::                                          Preference: 0
Destination: 240E:35C:A0D:FD00:1600::/80                 Protocol  : Direct
Interface  : Vlan160                                     Cost      : 0
Destination: 240E:35C:A0D:FD00:1600::1000/128            Protocol  : Direct
Destination: 240E:35C:A0D:FD00:7257:BFFF:FEE1:5F0/128    Protocol  : Direct
经测试:
1.终端获得了IPV6地址,与vlan160网关通,但依然无法访问IPV6互联网
粉丝:2人 关注:0人
这个还是有点问题,光猫从运营商那里拿到的前缀是动态的。如果前缀变了,那vlan 160的ipv6地址就失效了。
但是我这边是公网IPV4/IPV6,我观察IPV6不变的,都是64位固定前缀
zhiliao_al3NR 发表时间:2024-02-23
大潘 知了小白
H3C MSR V7路由器 PPPOE IPv6的问题 - 知了社区
可以参考下,另外vlan160接口下 mtu也改下
ipv6 mtu 1280
