H3C LS-12500R-48Y8C升级出错
2024-02-28提问
  • 0收藏,199浏览
交换机进不了系统,在boot里操作2-5-4用TFTP传完文件还需要做什么,没有自动安装版本。
粉丝:112人 关注:8人
3.2  重启后按Ctrl+B进入bootrom界面
  重启的时候按住Ctrl+B进入设备的bootroom菜单,以下标黑部分为设备自动打印部分,标红加粗的命令是需要手动操作
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing..........................Done!
*                 H3C S5500V2-24P-SI BOOTROM, Version 147                        *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Creation Date       : Apr  5 2017, 12:55:45
CPU Clock Speed     : 1000MHz
Memory Size         : 1024MB
Flash Size          : 512MB
CPLD Version        : 002
PCB Version         : Ver.B
Mac Address         : 9c061b804338
 BootWare Validating...
Press Ctrl+B to enter extended boot menu...  //Ctrl+B
BootWare password: Not required. Please press Enter to continue.  //ENTER
1. Download image to flash
2. Select image to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set switch startup mode
0. Reboot
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format file system
Ctrl+P: Change authentication for console login
Ctrl+R: Download image to SDRAM and run
Ctrl+C: Display Copyright
Enter your choice(0-8): 1  //选择1下载镜像文件到flash
1. Set TFTP protocol parameters
2. Set FTP protocol parameters
3. Set XMODEM protocol parameters
0. Return to boot menu
Enter your choice(0-3): 3     //选择3修改改串口参数
Please select your download baudrate:
1.* 9600
2.  19200
3.  38400
4.  57600
5.  115200
Enter your choice(0-5): 5     //选择5修改波特率为115200
Download baudrate is 115200 bps
Please change the terminal"s baudrate to 115200 bps and select XMODEM protocol
Press enter key when ready
3.3  修改管理软件波特率
 修改管理软件波特率波特率为115200,保持设备和管理软件波特率一致,点击“选项”—“会话选项”
回车重新进入到bootrom界面
Are you sure to download file to flash? Yes or No (Y/N):Y
Now please start transfer file with XMODEM protocol
If you want to exit, Press <Ctrl+X>
Loading ...CCCCCC
点击管理软件中的“传输-“发送Xmodem”,选中版本存放路径
等待版本传输完成,按“0” 退回上级目录
0. Reboot
Enter your choice(0-8): 0  //0重启设置
实验结果验证
重启后进入命令行,输入dis version查看升级后版本
<H3C>dis version
H3C Comware Software, Version 7.1.070, Release 3208P03
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. All rights reserved.
H3C S5500V2-24P-SI uptime is 0 weeks, 0 days, 0 hours, 2 minutes
Last reboot reason : Cold reboot
