S5130-HI系列交换机忘记console密码
2024-03-02提问
  • 0收藏,315浏览
不知道该选择哪个
Starting......
Press Ctrl+D to access BASIC BOOT MENU
Press Ctrl+T to start heavy memory test
*                          BASIC BOOTROM, Version 126                          *
   BASIC BOOT MENU
1. Update full BootRom
2. Update extended BootRom
3. Update basic BootRom
4. Boot extended BootRom
0. Reboot
Ctrl+U: Access BASIC ASSISTANT MENU
Ctrl+C: Display Copyright
Enter your choice(0-4):
1. RAM Test
0. Return to boot menu
Enter your choice(0-1): 0
   BASIC BOOT MENU
0. Reboot
For copyright information, access the Extended Boot menu and press Ctrl+C.
   BASIC BOOT MENU
0. Reboot
粉丝:6人 关注:0人
这个是基础boot不能恢复密码
参考下面方法
配置步骤
3.1 进入bootroom菜单清除Console密码
通过console线和crt软件连接并登陆设备,然后把设备断电重启。控制台上会打印如下信息,当出现“press Ctrl+B”的时候快速按住“Ctrl+B” 进入botroom菜单
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BotWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
      按住“Ctrl+B”进入如下菜单。选择“<6> Skip Current System Configuration”跳过当前配置启动,不同设备可能不是数字6,
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 6
Flag Set Success.
然后输入0重启设备
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
Press ENTER to get started.
3.2 如果不需要之前的配置信息的话
操作步骤:跳过启动文件后直接保存当前配置,再重启。
save
The current configuration will be written to the device. Are you sure? [Y/N]:y
Please input the file name(*.cfg)[flash:/startup.cfg]
(To leave the existing filename unchanged, press the enter key):(输入回车)
flash:/startup.cfg exists, overwrite? [Y/N]:y
Validating file. Please wait...
Configuration is saved to device successfully.
reboot
Start to check configuration with next startup configuration file, please wait.........DONE!
Current configuration may be lost after the reboot, save current configuration? [Y/N]:y
This command will reboot the device. Continue? [Y/N]:y
3.3 如果需要之前的配置信息的话
#Apr 26 12:02:07:166 2000 H3C SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1: login from Console
%Apr 26 12:02:07:306 2000 H3C SHELL/5/SHELL_LOGIN: Console logged in from aux0.
dir  %查看设备配置文件
Directory of flash:/
   1     drw-         -  Apr 26 2000 12:00:20   logfile
   2     -rw-      1666  Apr 26 2000 12:05:39   startup.cfg
   3     -rw-      1556  Apr 26 2000 12:05:33   _startup_bak.cfg
   4     -rw-       151  Apr 26 2000 12:05:30   system.xml
29106 KB total (16876 KB free)
给设备和电脑配置成同网段IP地址(举例:WAC配置成192.168.100.1,电脑配置成192.168.100.2),在电脑上通过3CD软件搭建tftp服务器。
sys
System View: return to User View with Ctrl+Z.
[H3C]interface Vlan-interface 1
[H3C-Vlan-interface1]ip address 192.168.100.1 24
[H3C-Vlan-interface1]quit
[H3C]ping 192.168.100.2
  PING 192.168.100.2: 56  data bytes, press CTRL_C to break
    Reply from 192.168.100.2: bytes=56 Sequence=1 ttl=128 time=7 ms
    Reply from 192.168.100.2: bytes=56 Sequence=2 ttl=128 time=2 ms
tftp 192.168.100.2 put startup.cfg
  File will be transferred in binary mode
  Sending file to remote TFTP server. Please wait... |
  TFTP:     1666 bytes sent in 0 second(s).
  File uploaded successfully.
下载成功:
可以到本地相关路径(此例子中是E盘)查看到相关文件。
需要恢复之前配置
解决方法:删除密码恢复之前配置文件
使用记事本打开startup.cfg文件
删除aux0口下的认证方式和密码并保存文件
覆盖当前配置文件
tftp 192.168.100.20 get startup.cfg
The file startup.cfg exists. Overwrite it? [Y/N]:y
  Verifying server file...
  Deleting the old file, please wait...
  Downloading file from remote TFTP server, please wait....
  TFTP:     1166 bytes received in 0 second(s)
  File downloaded successfully.
reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:n 不保存配置
This command will reboot the device. Continue? [Y/N]:y 确定继续重启
粉丝:6人 关注:43人
有Ctrl+B吗
感谢家人们,解决了,我的情况有点特殊,无线cosole线的问题,键盘按冒烟了,才出来评论区大佬给的那个视图
