监控平台接入核心交换机7500的问题
2024-03-03提问
  • 0收藏,203浏览
大家好!
监控平台的地址是192.168.103.253,现在通过 GE0/0/46 接入了核心7500X。
这个GE0/0/46  配置成:172.32.16.2。后面加了静态路由。原来vlan22可以访问监控平台。
现在的问题是,我新,建了一个VLAN45,这个VLAN无法访问192.168.103.253
因为监控上千个摄像头,IP地址和与办公网冲突,海康不愿意改摄像头的地址,所以配置成这个样子。
port link-mode route
ip address 172.32.16.2 255.255.255.252
 ip route-static 0.0.0.0 0 10.10.10.254
ip route-static 192.168.103.0 24 172.32.16.1interface GigabitEthernet0/0/46
 version 7.1.070, Release 7596P10
ip vpn-instance vpn32
 route-distinguisher 100:3003
 vpn-target 100:303 import-extcommunity
 vpn-target 100:303 export-extcommunity
 forward-path-detection enable
 irf mode normal
 dhcp enable
 lldp global enable
 system-working-mode standard
 xbar load-balance
 password-recovery enable
vlan 1
vlan 2 to 12
vlan 16 to 18
vlan 20 to 22
vlan 25 to 26
vlan 28
vlan 30
vlan 36
vlan 39 to 43
vlan 45
 description 15flor
vlan 50
vlan 90
vlan 100
vlan 103
vlan 2032
ftth
dhcp server ip-pool 15floor
 gateway-list 192.168.45.1
 network 192.168.45.0 mask 255.255.255.0
 dns-list 223.5.5.5 114.114.114.114
interface Bridge-Aggregation1
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 3 8 28 41 to 43
interface Bridge-Aggregation2
interface Bridge-Aggregation11
interface Vlan-interface20
 ip address 192.168.20.1 255.255.255.0
 ip address 192.168.200.1 255.255.255.0 sub
interface Vlan-interface21
 ip address 192.168.21.1 255.255.255.0
 ip address 192.168.210.1 255.255.255.0 sub
interface Vlan-interface22
 ip address 192.168.22.1 255.255.254.0
 ip address 192.168.220.1 255.255.255.0 sub
interface Vlan-interface45
 ip address 192.168.45.1 255.255.255.0
interface Vlan-interface50
 ip address 192.168.50.1 255.255.255.0
interface Vlan-interface90
 ip address 192.168.90.254 255.255.255.0
 scheduler logfile size 16
 info-center loghost 192.168.4.30
acl basic 2001 match-order auto
 rule 0 deny source 172.16.19.19 0
acl number 3032
 rule 10 permit ip source 192.168.22.0 0.0.0.255 destination 192.168.103.0 0.0.0.255
 rule 20 permit ip source 192.168.21.0 0.0.0.255 destination 192.168.103.0 0.0.0.255
 rule 30 permit ip source 192.168.23.0 0.0.0.255 destination 192.168.103.0 0.0.0.255
 rule 100 permit ip
domain system
 domain default enable system
 ip https enable
return
粉丝:3人 关注:0人
监控平台有回vlan45地址段的路由没
zhiliao_bxx0Hq 知了小白
监控平台有回vlan45地址段的路由没
  • 没有,45段是今天刚刚新建的。
原来海康都是192.168.X.X段的,所以不能直接接入办公网,我怀疑是中间用了个172.32.16段做路由。 但是现在我新建的VLAN45网段,是不能访问这个192.168.103.253的。 对了,原来只有22网段可以访问这个监控平台 其他网段,也不能访问。
从核心ping 192.168.103.253,172.32.16.1,172.32.16.2,均正常。
但是从其他VLAN ping不通
