无线网络卡顿怎么调优
2024-03-07提问
  • 0收藏,301浏览
智障 二段
AP name                       :
AP ID                         : 14
AP group name                 : default-group
State                         : Run
Backup type                   : Master
Online time                   : 112 days 0 hours 37 minutes 59 seconds
System uptime                 : 112 days 0 hours 36 minutes 45 seconds
Model                         : WA6320-D
Region code                   : CN
Region code lock              : Disabled
Serial ID                     :
MAC address                   :
IP address                    :
UDP control port number       : 18432
UDP data port number          : 18432
H/W version                   : Ver.A
S/W version                   : R2446P06
Boot version                  : 7.16
USB state                     : N/A
Power level                   : N/A
Power info                    : N/A
Description                   : Not configured
Priority                      : 4
Echo interval                 : 10 seconds
Echo count                    : 3 counts
Keepalive interval            : 10 seconds
Discovery-response wait-time  : 2 seconds
Statistics report interval    : 50 seconds
Fragment size (data)          : 1500
Fragment size (control)       : 1450
MAC type                      : Local MAC & Split MAC
Tunnel mode                   : Local Bridging & 802.3 Frame & Native Frame
CAPWAP data-tunnel status     : Up
Discovery type                : Unknown
Retransmission count          : 3
Retransmission interval       : 5 seconds
Firmware upgrade              : Enabled
Sent control packets          : 11521496
Received control packets      : 11521496
Echo requests                 : 967879
Lost echo responses           : 1
Average echo delay            : 0
Last reboot reason            : Power on
Latest IP address             :
Current AC IP                 :
Tunnel down reason            : N/A
Connection count              : 1
Backup IPv4                   : Not configured
Backup IPv6                   : Not configured
Ctrl-tunnel encryption        : Disabled
Ctrl-tunnel encryption state  : Not encrypted
Data-tunnel encryption        : Disabled
Data-tunnel encryption state  : Not encrypted
LED mode                      : Normal
Remote configuration          : Disabled
EnergySaving Level            : 0
Radio 1:
    Basic BSSID               :
    Admin state               : Up
    Radio type                : 802.11ac
    Antenna type              : internal
    Client dot11ac-only       : Disabled
    Client dot11n-only        : Disabled
    Channel bandwidth         : 20/40/80MHz
    Operating bandwidth       : 20/40/80MHz
    Secondary channel offset  : SCB
    Short GI for 20MHz        : Supported
    Short GI for 40MHz        : Supported
    Short GI for 80MHz        : Supported
    Short GI for 160MHz       : Not supported
    mimo                      : Not Config
    Green-Energy-Management   : Disabled
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Supported
    STBC                      : Supported
    Operational VHT-MCS Set:
        Mandatory             : Not configured
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
        Multicast             : Not configured
    Operational HT MCS Set:
        Supported             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15
    Channel                   : 48(auto)
    Channel usage(%)          : 62
    Max power                 : 20 dBm
    Operational rate:
        Mandatory             : 6, 12, 24 Mbps
        Multicast             : Auto
        Supported             : 9, 18, 36, 48, 54 Mbps
        Disabled              : Not configured
    Distance                  : 1 km
    ANI                       : Enabled
    Fragmentation threshold   : 2346 bytes
    Beacon interval           : 100 TU
    Protection threshold      : 2346 bytes
    Long retry threshold      : 4
    Short retry threshold     : 7
    Maximum rx duration       : 2000 ms
    Noise floor               : -87 dBm
    Protection mode           : cts-to-self
    MU-TxBF                   : Enabled
    SU-TxBF                   : Enabled
    Continuous mode           : N/A
    HT protection mode        : Non-HT mixed
Radio 2:
    Basic BSSID               :
    Admin state               : Up
    Radio type                : 802.11n(2.4GHz)
    Channel bandwidth         : 20MHz
    Operating bandwidth       : 20MHz
    Secondary channel offset  : SCN
    mimo                      : Not Config
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Supported
    STBC                      : Supported
    Channel                   : 11(auto)
    Channel usage(%)          : 35
    Max power                 : 16 dBm
    Preamble type             : Short
    Operational rate:
        Mandatory             : 1, 2, 5.5, 11 Mbps
        Multicast             : Auto
        Supported             : 6, 9, 12, 18, 24, 36, 48, 54 Mbps
    Distance                  : 1 km
    ANI                       : Enabled
    Noise floor               : -101 dBm
    HT protection mode        : No protection
AP name                       :
AP ID                         : 14
State                         : Run
Model                         : WA6320-D
Region code                   : CN
Serial ID                     :
MAC address                   :
IP address                    :
H/W version                   : Ver.A
Boot version                  : 7.16
USB state                     : N/A
Power level                   : N/A
Power info                    : N/A
Priority                      : 4
Latest IP address             :
Current AC IP                 :
LED mode                      : Normal
Radio 1:
    Basic BSSID               :
    Admin state               : Up
    mimo                      : Not Config
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Supported
    STBC                      : Supported
    Channel                   : 48(auto)
    Max power                 : 20 dBm
    Operational rate:
        Multicast             : Auto
    Distance                  : 1 km
    ANI                       : Enabled
    MU-TxBF                   : Enabled
    SU-TxBF                   : Enabled
Radio 2:
    Basic BSSID               :
    Admin state               : Up
    mimo                      : Not Config
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Supported
    STBC                      : Supported
    Channel                   : 11(auto)
    Max power                 : 16 dBm
    Operational rate:
        Multicast             : Auto
    Distance                  : 1 km
    ANI                       : Enabled
粉丝:17人 关注:4人
1. 升级AC和AP到最新版本,开启RRM自动功率和信道调整,优化信道功率来降低同频干扰;
2. 配置基于vlan的二层隔离,降低组网内有线侧产生的组播和广播流量,净化无线空口;
3. 将有线和无线的业务vlan分隔开,避免有线侧的广播组播流量影响业务业务vlan;
4. 对于高密部署的场景,将AP的5G信道从80 M调整为40 M或20 M,调低2.4G功率或关闭2.4G,让终端尽可能连接5G获得更好的使用体验;
5. 对于接入终端数量很多的AP,配置基于AP Radio的限速,建议限速上下行速率不宜过高;
6. 配置802.11v功能辅助引导漫游;
7. 适当配置禁止弱信号接入(RSSI不建议超过20),2.4G禁止低速率。
粉丝:121人 关注:8人
根据优化手册进行优化
4 无线网络通用优化
粉丝:232人 关注:0人
您好,参考
1、升级版本到最新
2、做好无线优化,参考链接
06-WLAN网络调优配置-新华三集团-H3C
