防火墙F5030 D忘记密码后跳过cosole失败
2024-03-07提问
  • 0收藏,245浏览
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9): 8
Clear Image Password Success!
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 1
Loading the main image files...
Loading file flash:/f5080mpu-cmw710-system-R9608P24.bin.....................
................................Done.
Loading file flash:/f5080mpu-cmw710-boot-R9608P24.bin........Done.
Image file flash:/f5080mpu-cmw710-boot-R9608P24.bin is self-decompressing...
..Done.
System image is starting...
Cryptographic algorithms tests passed.
Line con1/1 is available.
Press ENTER to get started.
login:
login:
login:
粉丝:29人 关注:2人
设备本身开启了密码恢复功能password-recovery enable(系统默认开启)
1、电脑连接console到设备,然后设备拔掉电源,重新加电,在设备重启过程中根据提示或者不停按键“ctrl+B”进入bootware界面,查看界面显示
2、在bootware界面,选择“8”-skip authentication for console password
3、之后选择"0" boot system重启设备,可通过console可以直接无密码登陆后台
4、在后台输入以下命令,修改admin的密码为Admin@123456
<device>system
[device]undo password-control enable
[device]local-user admin class manage  ----进入admin帐户视图
[device]local-user-manage-admin]password simple Admin@123456   ----修改密码
[device]local-user-manage-admin]service-type ssh terminal https
[device]password-control enable
[device]save force
4 个回答
粉丝:2人 关注:0人
按8之后应该按0
粉丝:137人 关注:8人
默认用户名密码admin
Xcheng 九段
粉丝:122人 关注:3人
你这操作不对吧,现场是IRF组网?
如果涉及请在主设备第一个console口操作
建议先确认下细节情况进一步处理下
z6Kl9 九段
粉丝:67人 关注:2人
按8之后按0
