H3C S5800-60C-PWR 无法进入系统
2024-03-08提问
  • 0收藏,205浏览
xyy 零段
系统启动过程如下,解压完系统后,无法启动系统,已重刷系统,依然无法启动,求大佬帮忙看下是啥问题
Press Ctrl+D to access BASIC BOOT MENU
Press Ctrl+T to start heavy memory test
*                    H3C S5800-60C-PWR BOOTROM, Version 220                    *
Copyright (c) 2004-2012 Hangzhou H3C Technologies Co., Ltd.
Creation Date   : Dec 20 2012,15:36:45
CPU Clock Speed : 750MHz
Memory Size     : 1024MB
Flash Size      : 512MB
CPLD Version    : 003/003
PCB Version     : Ver.C
Mac Address     : 741F4A28AD0A
Press Ctrl-B to enter Extended Boot menu...0
Starting to get the main application
file--flash:/s5800_5820x-cmw520-r1808p12.bin!...................................
The main application file is self-decompressing.................................
....................................Done!
The application file is self-decompressing......................................
Done!
System is starting...
Call function: bcm_stk_my_modid_set ulunitid=1,usmymod=6, return value is -3
Exception
Exception Number:          0x03
Exception Name:            TLB miss exception (store)
Exception Instruction:     0x82A9F040
Exception Slot:            0
Exception Task:            N/A (TID: -1)
Exception Stack Base:      0xffffffff
Exception Stack Top:       0x8247fcc0
Exception Time:            2000-04-26  12:00:12
Exception Tick:            0x0(CPU Tick High) 0x41cb5a54(CPU Tick Low)
Register contents:
Reg:     zero, Val = 0x00000000 ; Reg:       at, Val = 0x5000dc80 ;
Reg:       v0, Val = 0x00000000 ; Reg:       v1, Val = 0x86aca0d4 ;
Reg:       a0, Val = 0x00000001 ; Reg:       a1, Val = 0x00000000 ;
Reg:       a2, Val = 0x00000000 ; Reg:       a3, Val = 0x0000ffff ;
Reg:       t0, Val = 0x00000000 ; Reg:       t1, Val = 0x0000045c ;
Reg:       t2, Val = 0x86c1b3a0 ; Reg:       t3, Val = 0x00000036 ;
Reg:       t4, Val = 0x00000001 ; Reg:       t5, Val = 0x00000002 ;
Reg:       t6, Val = 0x00015180 ; Reg:       t7, Val = 0x8247fbd0 ;
Reg:       s0, Val = 0x1b72fa8e ; Reg:       s1, Val = 0x00000037 ;
Reg:       s2, Val = 0x00000036 ; Reg:       s3, Val = 0x0000006c ;
Reg:       s4, Val = 0x00000008 ; Reg:       s5, Val = 0x86c1b3a4 ;
Reg:       s6, Val = 0x00000000 ; Reg:       s7, Val = 0x00000000 ;
Reg:       t8, Val = 0x860db4cc ; Reg:       t9, Val = 0x8223580c ;
Reg:       k0, Val = 0x000013aa ; Reg:       k1, Val = 0x85a45773 ;
Reg:       gp, Val = 0x82258000 ; Reg:       sp, Val = 0x8247fcc0 ;
Reg:       s8, Val = 0x00000000 ; Reg:       ra, Val = 0x8299a384 ;
Reg:       pc, Val = 0x82a9f040 ; Reg:       sr, Val = 0x5000dc83 ;
Reg:    cause, Val = 0x0080000c ; Reg:    cntxt, Val = 0x00000000 ;
Reg:    fpcsr, Val = 0x82a9f040 ; Reg:    badva, Val = 0x00000002 ;
Reg: reserve0, Val = 0x00000036 ; Reg: reserve1, Val = 0x0000006c ;
Reg: reserve2, Val = 0x00000008 ; Reg: reserve3, Val = 0x86c1b3a4 ;
 Call stack:
 82a9f040
 8299a384
 8299b3f0
 8299e09c
 825984a4
 8260b4bc
 825c6f18
 8476b95c
 82500be0
 82231680
 82231608
 ffffffff
 ffffffff
 ffffffff
 ffffffff
 ffffffff
 ffffffff
 ffffffff
 ffffffff
粉丝:3人 关注:0人
一般都是FLASH芯片损坏!
FLASH卡读写正常,芯片损坏不影响读写吗?
xyy 发表时间:2024-03-08
回复xyy:
你能启动版本文件,固件又是重新刷新的。说明固件的问题肯定是没有的。肯定是某个芯片坏了,或者芯片里面的程序坏掉了。你能刷的是机器的固件,芯片的固件你是没办法刷的。基本上可以判定是板子上的某个零件坏了。这个是属于硬件坏,具体哪个坏需要专业的拆出来帮你检查
zhiliao_OHxO2E 发表时间:2024-03-08
粉丝:119人 关注:1人
  1. 您的交换机型号是 H3C S5800-60C-PWR,其BootROM版本为 220
  2. 启动过程中,交换机首先加载了BootROM,然后尝试获取主应用程序文件。
  3. 主应用程序文件位于 flash:/s5800_5820x-cmw520-r1808p12.bin
现在,让我们一步步检查可能的问题:
  1. 检查文件完整性:确保主应用程序文件存在且完整。您可以通过重新下载或验证文件来解决此问题。
  2. 检查文件路径:确认文件路径是否正确。如果路径错误,交换机无法找到主应用程序文件。
  3. 检查文件版本兼容性:确保主应用程序文件与您的交换机型号和硬件版本兼容。如果不兼容,您需要下载适用于您的设备的正确版本。
  4. 检查文件是否被损坏:如果文件已损坏,您需要重新下载或使用其他可靠的文件。
如果您已经重刷了系统并且问题仍然存在,建议您联系H3C技术支持,以获取更详细的故障排除指导。
系统是从其他同型号正常运行的机器是下载下来的,肯定没有问题,文件路径肯定也没问题,要不他肯定无法加载系统并解压
xyy 发表时间:2024-03-08
