SecPath F100-M-SI无法使用SSLVPN,配置如下请大神指教
2024-03-09提问
  • 0收藏,185浏览
配置如下:
 version 5.20, Release 5142P02
 sysname FW
 undo voice vlan mac-address 00e0-bb00-0000
 ike local-name msr
 interzone policy default by-priority
 domain default enable system
 telnet server enable
 ip http acl 2030
 undo alg all
session synchronization enable
 password-recovery enable
acl number 2000 match-order auto
 rule 0 permit
acl number 3009
 rule 1 permit ip source 168.8.100.0 0.0.0.255 destination 168.7.100.0 0.0.0.255
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
pki entity cs3250
  common-name H3C
pki domain cs3250
  certificate request from ca
  certificate request entity cs3250
  crl check disable
pki domain default
  crl check disable
ike proposal 30
 encryption-algorithm 3des-cbc
 dh group2
 sa duration 28800
ike peer 30
 exchange-mode aggressive
 pre-shared-key cipher $c$3$U2Fyb9HqrC0AGIPBlrc0UGLhXptovjQi
 id-type name
 remote-name er
 remote-address msr dynamic
 nat traversal
ipsec transform-set 30
 encapsulation-mode tunnel
 transform esp
 esp authentication-algorithm sha1
 esp encryption-algorithm 3des
ipsec policy 30 10 isakmp
 security acl 3009
 ike-peer 30
 transform-set 30
 sa duration traffic-based 28800
ipsec policy 30 30 isakmp
 security acl 3009
 ike-peer 30
 sa duration traffic-based 1843200
 sa duration time-based 3600
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$dIkdn2OLeJEqHX6PWIDjD1ngwjkvndMfxuvS
 authorization-attribute level 3
 service-type telnet
 service-type web
ssl server-policy access-policy
 pki-domain cs3250
interface NULL0
interface LoopBack0
 ip address 168.8.100.254 255.255.255.255
interface GigabitEthernet0/0
 port link-mode route
 ip address 192.168.0.1 255.255.255.0
 undo dhcp select server global-pool
interface GigabitEthernet0/1
 nat outbound 2000
 nat server protocol udp global 111.17.222.215 82 inside 168.8.100.202 82
 nat server protocol udp global 111.17.222.215 9091 inside 168.8.100.202 9091
 nat server protocol udp global 111.17.222.215 8080 inside 168.8.100.202 8080
 nat server protocol udp global 111.17.222.215 7777 inside 168.8.100.202 7777
 nat server protocol udp global 111.17.222.215 21 inside 168.8.100.202 21
 nat server protocol udp global 111.17.222.215 1082 inside 168.8.100.202 1082
 nat server protocol tcp global 111.17.222.215 82 inside 168.8.100.202 82
 nat server protocol tcp global 111.17.222.215 9091 inside 168.8.100.202 9091
 nat server protocol tcp global 111.17.222.215 8080 inside 168.8.100.202 8080
 nat server protocol tcp global 111.17.222.215 7777 inside 168.8.100.202 7777
 nat server protocol tcp global 111.17.222.215 ftp inside 168.8.100.202 ftp
 nat server protocol tcp global 111.17.222.215 1082 inside 168.8.100.202 1082
 nat server protocol tcp global 111.17.222.215 7776 inside 168.8.100.202 7776
 nat server protocol udp global 111.17.222.215 7776 inside 168.8.100.202 7776
 nat server protocol tcp global 111.17.222.215 8089 inside 168.8.100.202 8089
 nat server protocol udp global 111.17.222.215 8089 inside 168.8.100.202 8089
 nat server protocol udp global 111.17.222.215 4242 inside 168.8.100.209 4242
 nat server protocol tcp global 111.17.222.215 4242 inside 168.8.100.209 4242
 nat server protocol tcp global 111.17.222.215 4243 inside 168.8.100.209 4243
 nat server protocol udp global 111.17.222.215 4243 inside 168.8.100.209 4243
 nat server protocol udp global 111.17.222.215 9191 inside 168.8.100.209 8080
 nat server protocol tcp global 111.17.222.215 9191 inside 168.8.100.209 8080
 nat server protocol udp global 111.17.222.215 4244 inside 168.8.100.209 4244
 nat server protocol tcp global 111.17.222.215 4244 inside 168.8.100.209 4244
 nat server protocol tcp global 111.17.222.215 4245 inside 168.8.100.209 4245
 nat server protocol udp global 111.17.222.215 4245 inside 168.8.100.209 4245
 nat server protocol tcp global 111.17.222.215 9192 inside 168.8.100.210 9191
 nat server protocol udp global 111.17.222.215 7778 inside 10.11.13.15 7778
 nat server protocol tcp global 111.17.222.215 8088 inside 10.11.13.15 8088
 nat server protocol udp global 111.17.222.215 8088 inside 10.11.13.15 8088
 nat server protocol tcp global 111.17.222.215 9090 inside 10.11.13.15 9090
 nat server protocol udp global 111.17.222.215 9090 inside 10.11.13.15 9090
 nat server protocol tcp global 111.17.222.215 7070 inside 10.11.13.15 7070
 nat server protocol udp global 111.17.222.215 7070 inside 10.11.13.15 7070
 nat server protocol udp global 111.17.222.215 88 inside 10.11.13.15 88
 nat server protocol udp global 111.17.222.215 89 inside 10.11.13.15 89
 nat server protocol tcp global 111.17.222.215 5222 inside 10.11.13.15 5222
 nat server protocol udp global 111.17.222.215 5222 inside 10.11.13.15 5222
 nat server protocol tcp global 111.17.222.215 7778 inside 10.11.13.15 7778
 nat server protocol tcp global 111.17.222.215 88 inside 10.11.13.15 88
 nat server protocol tcp global 111.17.222.215 89 inside 10.11.13.15 89
 nat server protocol tcp global 111.17.222.215 11002 inside 10.11.13.220 11002
 nat server protocol udp global 111.17.222.215 11002 inside 10.11.13.220 11002
 nat server protocol tcp global 111.17.222.215 11003 inside 10.11.13.220 11003
 nat server protocol udp global 111.17.222.215 11003 inside 10.11.13.220 11003
 nat server protocol tcp global 111.17.222.215 10003 inside 10.11.13.220 10003
 nat server protocol udp global 111.17.222.215 10003 inside 10.11.13.220 10003
 nat server protocol tcp global 111.17.222.215 10004 inside 10.11.13.220 10004
 nat server protocol udp global 111.17.222.215 10004 inside 10.11.13.220 10004
 nat server protocol tcp global 111.17.222.215 10005 inside 10.11.13.220 10005
 nat server protocol udp global 111.17.222.215 10005 inside 10.11.13.220 10005
 nat server protocol tcp global 111.17.222.215 10006 inside 10.11.13.220 10006
 nat server protocol udp global 111.17.222.215 10006 inside 10.11.13.220 10006
 nat server protocol tcp global 111.17.222.215 10007 inside 10.11.13.220 10007
 nat server protocol udp global 111.17.222.215 10007 inside 10.11.13.220 10007
 nat server protocol tcp global 111.17.222.215 8787 inside 10.11.13.222 8787
 nat server protocol udp global 111.17.222.215 8787 inside 10.11.13.222 8787
 nat server protocol tcp global 111.17.222.215 18080 inside 10.11.13.222 18080
 nat server protocol udp global 111.17.222.215 18080 inside 10.11.13.222 18080
 nat server protocol tcp global 111.17.222.215 8081 inside 10.11.13.208 8081
 nat server protocol udp global 111.17.222.215 8081 inside 10.11.13.208 8081
 nat server protocol tcp global 111.17.222.215 8091 inside 10.11.13.208 8091
 nat server protocol udp global 111.17.222.215 8091 inside 10.11.13.208 8091
 nat server protocol tcp global 111.17.222.215 8090 inside 10.11.13.208 8090
 nat server protocol udp global 111.17.222.215 8090 inside 10.11.13.208 8090
 nat server protocol tcp global 111.17.222.215 8083 inside 10.11.32.50 8083
 nat server protocol udp global 111.17.222.215 8083 inside 10.11.32.50 8083
 nat server protocol tcp global 111.17.222.215 8084 inside 10.11.32.50 8084
 nat server protocol udp global 111.17.222.215 8084 inside 10.11.32.50 8084
 ip address 111.17.222.215 255.255.255.240
 ipsec policy 30
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
 nat outbound 2000
 nat server protocol tcp global 111.17.222.215 4244 inside 168.8.100.210 4244
 nat server protocol udp global 111.17.222.215 4244 inside 168.8.100.210 4244
 ip address 10.28.1.2 255.255.255.252
 ipsec policy 30
vd Root id 1
zone name Management id 0
 priority 100
 import interface GigabitEthernet0/0
zone name Local id 1
 priority 100
zone name Trust id 2
 priority 85
 import interface GigabitEthernet0/5
zone name DMZ id 3
 priority 50
zone name Untrust id 4
 priority 5
 import interface GigabitEthernet0/1
switchto vd Root
 ip virtual-reassembly
 zone name DMZ id 3
 interzone source Local destination Untrust
 interzone source Trust destination Untrust
  rule 0 permit
   source-ip any_address
   destination-ip any_address
   service any_service
   rule enable
 interzone source Untrust destination Local
  rule 0 deny
   service telnet
   rule enable
 interzone source Untrust destination Trust
  rule 0 permit
   service any_service
   rule enable
 content-filtering url-hostname-entry 1
  url-hostname fix-string mail.163.com
 content-filtering email-address-entry 2
  email-address mail@qq.com
 ssl-vpn server-policy access-policy port 64443
 ssl-vpn enable
 ip route-static 0.0.0.0 0.0.0.0 111.17.222.209
 ip route-static 10.11.0.0 255.255.0.0 10.28.1.1
 ip route-static 168.8.100.0 255.255.255.0 10.28.1.1
 ip route-static 192.168.1.0 255.255.255.0 10.28.1.1
 dhcp enable
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
return
粉丝:6人 关注:1人
5.20的墙都停维护了,之前朋友打400续保然后免费换了个新的7.20的
Xcheng 九段
粉丝:122人 关注:3人
sslvpn配置不全,无法判断。
建议仔细检查配置和设备状态,可通过debug或dis等命令进一步分析确认下并处理
另外此系列产品已停止技术支持,建议考虑采购新设备替换
或联系采购渠道H3C认证代理商沟通相关事宜。
