Onestor-R0328 如何更换读写加速盘
  • 0收藏,228浏览
粉丝:0人 关注:3人
一、背景:
     (1) 部署方式:CAS+OneStor部署,其中CAS版本为:V5.0 (E0535P12) ,OneStor-R0328
     (2)集群为四节点。
二、问题现象
     (1)服务器上的加速SSD盘告警。
     (2) 登录OneStor 后,查看详细信息知:服务器读写加速盘故障。cvk02磁盘状态为0/4。在集群视图里发现cvk02为红盘,未得到网络配置信息。
(2)在主机管理里 点击cvk02,告知无法读取磁盘信息。
(3)ssh到cvk02,cvk03等,可以ping通其它设置IP,感觉不是网络问题,因集群一直运行,未进行过变更!
PING 172.17.216.3 (172.17.216.3) 56(84) bytes of data.
64 bytes from 172.17.216.3: icmp_req=1 ttl=64 time=0.031 ms
(4)现在的集群状态已经同步完成
root@cvk02:~# ceph -s
    cluster eb41d8cf-97cc-4420-b5c4-5c5b4e132d9f
     health HEALTH_OK
     monmap e5: 3 mons at {cvk01=172.17.216.2:6789/0,cvk02=172.17.216.3:6789/0,cvk03=172.17.216.4:6789/0}upgrading_flag 0
            election epoch 292, quorum 0,1,2 cvk01,cvk02,cvk03
     osdmap e51044: 16 osds: 12 up, 12 in
      pgmap v163860628: 2048 pgs, 2 pools, 2628 GB data, 670 Kobjects
            7382 GB used, 12713 GB / 20095 GB avail
                2048 active+clean
  client io 1755 KB/s rd, 2275 KB/s wr, 444 op/s rd, 63 op/s wr
root@cvk02:~#
其中监控节点为cvk01,cvk02和cvk03。(cvk02的磁盘异常)
(5)查看osd以及读写加速盘情况,cvk02的写缓分区还在,但读缓存分区丢失,osd.2、osd.5、osd.7、osd.10 down状态。
root@cvk02:~# ceph osd stat
root@cvk02:~# ceph osd tree
ID WEIGHT   TYPE NAME          UP/DOWN REWEIGHT PRIMARY-AFFINITY
-6        0 root maintain
-5 26.23999 root partition1
-7 26.23999     rack rack1
-2  6.56000         host cvk01
 0  1.64000             osd.0       up  1.00000          1.00000
 3  1.64000             osd.3       up  1.00000          1.00000
 9  1.64000             osd.9       up  1.00000          1.00000
 6  1.64000             osd.6       up  1.00000          1.00000
-3  6.56000         host cvk02
 2  1.64000             osd.2     down        0          1.00000
 7  1.64000             osd.7     down        0          1.00000
10  1.64000             osd.10    down        0          1.00000
 5  1.64000             osd.5     down        0          1.00000
-4  6.56000         host cvk03
 1  1.64000             osd.1       up  1.00000          1.00000
 4  1.64000             osd.4       up  1.00000          1.00000
 8  1.64000             osd.8       up  1.00000          1.00000
15  1.64000             osd.15      up  1.00000          1.00000
-8  6.56000         host cvk04
12  1.64000             osd.12      up  1.00000          1.00000
13  1.64000             osd.13      up  1.00000          1.00000
14  1.64000             osd.14      up  1.00000          1.00000
11  1.64000             osd.11      up  1.00000          1.00000
-1        0 root default
root@cvk02:~# lsblk
NAME                                       MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
sdf                                          8:80   0   1.7T  0 disk
└─sdf1                                       8:81   0   1.7T  0 part
sdo                                          8:224  0    14T  0 disk
└─3600507630082018d9800000000000001 (dm-1) 253:1    0    14T  0 mpath /vms/FC_SAN02
sdd                                          8:48   0   1.7T  0 disk
└─sdd1                                       8:49   0   1.7T  0 part
sdm                                          8:192  0   100G  0 disk
└─sdm1                                       8:193  0   100G  0 part
sdu                                         65:64   0     5T  0 disk
└─360000000000000000e000000eb42d8d0 (dm-3) 253:3    0     5T  0 mpath /vms/3FuBen
sdb                                          8:16   0 446.1G  0 disk
├─sdb4                                       8:20   0   100G  0 part     #写缓存盘
├─sdb2                                       8:18   0   100G  0 part
├─sdb5                                       8:21   0   100G  0 part
├─sdb1                                       8:17   0    15M  0 part
└─sdb6                                       8:22   0   100G  0 part
sdk                                          8:160  0     6G  0 disk
sds                                         65:32   0   100G  0 disk
└─sds1                                      65:33   0   100G  0 part
sdi                                          8:128  0     6G  0 disk
sdq                                         65:0    0     6G  0 disk
sdg                                          8:96   0    14T  0 disk
└─3600507630082018d9800000000000000 (dm-0) 253:0    0    14T  0 mpath /vms/FC_SAN01
sde                                          8:64   0   1.7T  0 disk
└─sde1                                       8:65   0   1.7T  0 part             #1.7T的读缓存盘没有了
sdn                                          8:208  0    14T  0 disk
sdv                                         65:80   0     5T  0 disk
└─360000000000000000e000000eb43d8d0 (dm-2) 253:2    0     5T  0 mpath /vms/2FuBen
sdc                                          8:32   0   1.7T  0 disk
└─sdc1                                       8:33   0   1.7T  0 part
sdl                                          8:176  0   100G  0 disk
└─sdl1                                       8:177  0   100G  0 part
sdt                                         65:48   0   100G  0 disk
└─sdt1                                      65:49   0   100G  0 part
sda                                          8:0    0 446.1G  0 disk
├─sda4                                       8:4    0  28.6G  0 part
├─sda2                                       8:2    0  74.5G  0 part  /
├─sda5                                       8:5    0 324.3G  0 part  /vms
├─sda3                                       8:3    0  18.6G  0 part  /var/log
└─sda1                                       8:1    0    94M  0 part  /boot/efi
sdj                                          8:144  0     6G  0 disk
sdr                                         65:16   0     6G  0 disk
sdh                                          8:112  0    14T  0 disk
sdp                                          8:240  0     6G  0 disk
三、问题诉求
       因未操作过这类缓存盘的更换,还需要大神给个指点。是直接换盘,还是需要先清理Onestor信息?多谢多谢。
zhiliao_8f7cxH 知了小白
粉丝:0人 关注:3人
本问题已经处理,处理过程如下:
因为服务器使用的是3850X6,与实施的技术文档有差异,无法参考,所以我使用了最激进的方法进行了处理。
(1)在读缓存故障节点剔除下线的OSD。(依据官方文档是不需要的,只需要更换缓存盘后,RAID卡设置好,执行相关替换命令即可,但我们服务器使用的差异性,没有参考执行。)
stop ceph-osd id=<id>
stop osd out osd.<id>
ceph osd crush remove osd.<id>
ceph auth del osd.<id>
ceph osd rm osd.<id>
数据重新平衡后,再执行第(2)步。
(2)从上方信息即知,读缓存盘已经丢失,所以不需要清理相关分区
(3)迁移该节点上的服务器后,更换SSD,设置SSD为RAID0,其它缓存设置与其它节点一致,重启服务器。
(4)在Handy界面上,发现还是异常,其中分区partition1的状态还是红色,告警“少了一个OSD”;主机管理里的cvk02还是无法识别磁盘。
这时,即然还是原来的状态。为啥呢?哦!想起来了,SSD需要处理一下,于是,执行了如下命令:
echo 0 > /sys/block/sdb/queue/rotational    #已经确认过ssd盘的盘符是/dev/sdb 和sdc。
echo 0 > /sys/block/sdc/queue/rotational
执行完成后,再到Handy界面上查看,发现还是原来的故障样子!这是啥问题呢?
既然这样也不行,那么是否可以踢出故障节点,再加回呢。于是执行第(5)步。
(5)在Handy界面的“主机管理”里,选择cvk02,删除主机!告知先处理高可用,所以到“高可用”菜单->编辑,在界面内删除cvk02的信息。点击确定后,等待界面完成(不要刷新页面)。再回到Handy的“主机管理”里,重新删除cvk02主机,等待界面完成。再次查看分区Partition1,已经由告警状态变成了正常绿了。
此时,最怕报错,还好,正常删除。
(6)因为cvk02的网络信息、Key都未动,所以这里不涉及调整。
(7)再次加入cvk02,在Handy界面的“主机管理”->"手动部署",填写主机IP,分区:partition1,机架:rack1和root密码。(这两项信息,是我们集群的,需要注意相关修改),下一步;
(8)选择一个ssd为写缓存盘,一个读缓存盘,再选择数据盘。点击“确认”(若不执行第(4)节里的rotational,这里看不到加速盘,就没有办法执行了。)
(9)经过焦急的等待后,最终把cvk02主机加回了集群。
(10)再次检测分区partition1,显示正常绿。进入ssh 后台查看,ceph -w,集群告警,但已经同步同步数据。
(11)最后一步,再把高可用里的cvk02加回来,到此完成本次的故障处理!
感谢我询问过的大姥!
本次处理只限于本集群,希望能给需求之人一点建议,仅供参考!
