路由器忘记密码怎么办
2024-03-25提问
  • 0收藏,183浏览
路由器忘记密码怎么办
粉丝:8人 关注:0人
确认下具体型号吧
附:
MSR或以上高端型号,参考
console登录设备
sys
local-u 用户名
pass s 新密码
#注意空格,最后验证登录后在保存配置
sa f
#保存配置
H3C ER5200G2 路由器
雷 玲 发表时间:2024-03-25
回复雷 玲:
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Home/Routers/00-Public/Videos/Web_Video_Configure_Case/H3C_ER_G2_Web_Video-6W101/17/?CHID=403503
zhiliao_8h148y 发表时间:2024-03-25
回复雷 玲:
https://www.h3c.com/cn/d_202312/1977862_30005_0.htm#_Toc152670256
粉丝:1人 关注:32人
可以通过连接consloe线重启设备进行重置密码;如果上一次操作的时候没有保存过配置的话可能会调配置;
进入bootroom菜单清除Consle密码
通过conlse线crt软件连接并登陆设备,然后把设备断电重启。控制台上会打印如下信息,当出现“press Ctrl+B”时候快速按住“Ctrl+B” 进入botroom菜单
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BotWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
      按住“Ctrl+B”进入如下菜单。选择<6> Skip Current System Configuration跳过当前配置启动,不同设备可能不是数字6
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 6
Flag Set Success.
然后输入0重启设备
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
Press ENTER to get started.
https://zhiliao.h3c.com/Theme/details/49112
粉丝:119人 关注:1人
什么系列、什么型号
