ike错误
2024-03-28提问
  • 0收藏,158浏览
粉丝:0人 关注:2人
Invalid ID information是什么原因导致,怎么排查,现在ipsec sa起不来
粉丝:112人 关注:8人
无效的ID信息
两端ACL非镜像配置,一般存在三种情况:
  1. 两端ACL无交集;
  2. 两端ACL有交集,但是不是包含关系;
  3. 两端ACL是包含关系,ACL范围大的一方是发起方。
粉丝:232人 关注:0人
1.17.4  身份信息无效导致IPsec SA协商失败
1. 故障现象
(1)     通过display ike sa命令查看当前的IKE SA信息,发现IKE SA协商成功,其状态(Flags字段)为RD。但通过display ipsec sa命令查看当前的IPsec SA时,发现没有协商出相应的IPsec SA。
(2)     打开IKE调试信息开关可以看到以下调试信息:
Notification INVALID_ID_INFORMATION is received.
或者:
Failed to get IPsec policy when renegotiating IPsec SA. Delete IPsec SA.
Construct notification packet: INVALID_ID_INFORMATION.
2. 故障分析
响应方IPsec安全策略配置错误,导致在IKE第二阶段协商时找不到IPsec安全策略,原因可能为如下几点:
(1)     通过display ike sa verbose命令查看IKE一阶段协商中是否找到匹配的IKE profile。若没有找到IKE profile,则会查找全局的IKE参数,因此就要求这种情况下IPsec安全策略中不能引用任何IKE profile,否则协商失败。
通过如下显示信息可以看到,IKE SA在协商过程中没有找到匹配的IKE profile:
<Sysname> display ike sa verbose
   Connection ID: 3
   Outside VPN:
   Inside VPN:
   Profile:
   Transmitting entity: Responder
   Initiator COOKIE: 1bcf453f0a217259
   Responder COOKIE: 5e32a74dfa66a0a4
   Local IP/port: 192.168.222.5/500
   Local ID type: IPV4_ADDR
   Local ID: 192.168.222.5
   Remote IP/port: 192.168.222.71/500
   Remote ID type: IPV4_ADDR
   Remote ID: 192.168.222.71
   Authentication-method: PRE-SHARED-KEY
   Authentication-algorithm: MD5
   Encryption-algorithm: 3DES-CBC
   Life duration(sec): 86400
   Remaining key duration(sec): 85847
   Exchange-mode: Main
   Diffie-Hellman group: Group 1
   NAT traversal: Not detected
   Vendor ID index: 0xa1d
   Vendor ID sequence number: 0x0
但在IPsec策略中引用了IKE profile profile1:
[Sysname] display ipsec policy
IPsec Policy: policy1
  Sequence number: 1
  Mode: ISAKMP
  Description:
  Security data flow: 3000
  Selector mode: aggregation
  Local address: 192.168.222.5
  Remote address: 192.168.222.71
  Transform set:  transform1
  IKE profile: profile1
  SA trigger mode: Auto
  SA duration(time based): 3600 seconds
  SA duration(traffic based): 1843200 kilobytes
  SA soft-duration buffer(time based): 1000 seconds
  SA soft-duration buffer(traffic based): 43200 kilobytes
  SA idle time: 100 seconds
  Responder only: Disabled
(2)     查看IPsec安全策略中引用的ACL配置是否正确。
例如,如发起方ACL流范围为网段到网段:
[Sysname] display acl 3000
Advanced IPv4 ACL 3000, 1 rule,
ACL's step is 5
 rule 0 permit ip source 192.168.222.0 0.0.0.255 destination 192.168.222.0 0.0.0.255
响应方ACL流范围为主机到主机:
ACL's step is 5
 rule 0 permit ip source 192.168.222.71 0 destination 192.168.222.5 0
以上配置中,响应方ACL规则定义的流范围小于发起方ACL规则定义的流范围,这会导致IPsec SA协商失败。
(3)     IPsec 安全策略配置不完整。具体包括:没有配置对端地址、没有配置IPsec提议、IPsec提议配置不完整。
例如,如下IPsec安全策略中没有配置隧道的对端IP地址,因此IPsec安全策略是不完整的:
  Sequence number: 1
  Mode: ISAKMP
  Remote address:
3. 处理过程
(1)     若在IKE第一阶段协商过程中没有找到IKE profile,建议在响应方IPsec安全策略中去掉对IKE profile的引用或者调整IKE profile的配置使之能够与发起端相匹配。
(2)     若响应方ACL规则定义的流范围小于发起方ACL规则定义的流范围,建议修改响应方ACL的流范围大于或等于发起方ACL的流范围。以故障分析(2)中的配置为例,可以将响应方ACL流范围修改为:
Advanced IPv4 ACL 3000, 2 rules,
ACL's step is 5
(3)     将IPsec安全策略配置完整。以故障分析中的(3)中的配置为例,需要在IPsec安全策略中配置隧道的对端IP地址。
Eason 三段
粉丝:2人 关注:0人
看看log和debug排查一下啊,二阶段起不来问题大概率是两边参数或者映射表没匹配
