华三ac+wx3010H-L-PWR
2024-03-28提问
  • 0收藏,110浏览
Ac怎么在命令行恢复出厂设置
粉丝:130人 关注:8人
参考
命令行恢复出厂设置
reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:Y  //确定删除保存的配置文件
reboot
 Start to check configuration with next startup configuration file, please wait.........DONE!
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:N  //不保存配置
This command will reboot the device. Continue? [Y/N]:Y   //继续重启
