SecPath U200-M 端口不时掉线?
2017-09-14提问
  • 1收藏,1776浏览
粉丝:2人 关注:2人
SecPath U200-M
interface GigabitEthernet0/1  固定外网IP
interface GigabitEthernet0/2 连接公司内网(S5120)
现在问题interface GigabitEthernet0/2不定时掉线,四五分钟后又正常,
有时有日志记录,有时没有
日志:
2017-09-08  10:36  发现掉线
2017-09-08  10:41  正常日志记录:
Sep 8 10:38:56:469 2017     WEB Warning admin logged in from 192.168.1.5
Sep 8 10:38:42:514 2017     WEB Warning admin failed to log in from 192.168.1.5
Sep 8 10:38:28:546 2017     WEB Warning admin failed to log in from 192.168.1.5
Sep 8 10:38:03:654 2017     WEB Warning admin logged out from 192.168.1.5
Sep 8 10:37:57:609 2017     SHELL Warning SSH user admin failed to login from 192.168.2.105 on VTY0.
Sep 8 10:36:32:257 2017     IFNET Warning Line protocol on the interface GigabitEthernet0/2 is UP
Sep 8 10:36:32:257 2017     IFNET Warning GigabitEthernet0/2: link status is UP
Sep 8 10:36:29:757 2017     IFNET Warning Line protocol on the interface GigabitEthernet0/2 is DOWN
Sep 8 10:36:29:757 2017     IFNET Warning GigabitEthernet0/2: link status is DOWN
Sep 8 10:36:23:757 2017     IFNET Warning Line protocol on the interface GigabitEthernet0/2 is UP
Sep 8 10:36:23:757 2017     IFNET Warning GigabitEthernet0/2: link status is UP
Sep 8 10:36:20:757 2017     IFNET Warning Line protocol on the interface GigabitEthernet0/2 is DOWN
Sep 8 10:36:20:757 2017     IFNET Warning GigabitEthernet0/2: link status is DOWN
Sep 8 10:32:50:758 2017     IFNET Warning Line protocol on the interface GigabitEthernet0/2 is UP
Sep 8 10:32:50:758 2017     IFNET Warning GigabitEthernet0/2: link status is UP
Sep 8 10:32:47:758 2017     IFNET Warning Line protocol on the interface GigabitEthernet0/2 is DOWN
Sep 8 10:32:47:757 2017     IFNET Warning GigabitEthernet0/2: link status is DOWN
发生问题时,设备面板端口指示灯正常闪动
处理:网线,两设备端口都换,问题还时有发生,这个情况是什么问题?
my8023 七段
粉丝:15人 关注:0人
替换的网线接别的设备上是否会出现端口也up、down呢。如果没有,可以中间串个设备,看下是不是协商,兼容问题
粉丝:2人 关注:2人
以前接的H3C  S5500的用了两年没有出过问题
8月份才调过来的接的H3C 5120 ,同一家公司的产品,怎么回有兼容问题?
与配置有没有关呢?
你可以先把0/2口的配置和下行交换机的互联端口配置一起发出来
然后可以将你这根网线用测线仪测试一下,或者交换机用这根网线接到PC上长ping测试一下是否正常
问题的难点是四五分钟又好了,就算换线一拨插就好了,出问题是面析灯都正常 U200m: interface GigabitEthernet0/2 port link-mode route description to S5500-28F-G/31-32 nat outbound 3001 nat server protocol tcp global 61.157.98.211 8082 inside 192.168.1.3 8082 5120: # interface GigabitEthernet1/0/45 port access vlan 15 #
蜀天下 发表时间:2017-09-14
进防火墙的WEB界面勾选一下 启用单向流检测 试试
凤凰院凶真 发表时间:2017-09-14
"启用单向流检测" 怎么设置,会能什么效果
蜀天下 发表时间:2017-09-14
