S5800
2024-04-09提问
  • 0收藏,149浏览
凌轩 四段
交换机告警以下内容,没有风扇指示灯
各位大佬看看具体是什么原因导致的。
%Apr 26 13:49:34:939 2000 H3C DEVM/2/BOARD_STATE_FAULT: Board state changes to FAULT on Chassis 0 Slot 1, type is unknown.
#Apr 26 13:49:51:559 2000 H3C ENTITY/4/FAN DIRECTION NOTPREFERRED:
 Trap 1.3.6.1.4.1.25506.2.6.2.0.31<hh3cEntityExtFanDirectionNotPreferred>: Entity ID is 126, entity extend ID is 126, entity name is FAN 1
#Apr 26 13:49:51:829 2000 H3C ENTITY/4/FAN DIRECTION NOTPREFERRED:
 Trap 1.3.6.1.4.1.25506.2.6.2.0.31<hh3cEntityExtFanDirectionNotPreferred>: Entity ID is 127, entity extend ID is 127, entity name is FAN 2
%Apr 26 13:49:52:090 2000 H3C DEVM/4/DEV_FANDIRECTION_NOTPREFERRED:
 Fan 3 airflow direction is not preferred on slot 2, please check it.
%Apr 26 13:49:52:264 2000 H3C DEVM/4/DEV_FANDIRECTION_NOTPREFERRED:
 Fan 4 airflow direction is not preferred on slot 2, please check it.
粉丝:8人 关注:0人
dis fan检查下风扇状态吧
Slot 1  FAN 1 State : FanDirectionFault Wind Direction :Port-to-Power Prefer Wind Direction :Power-to-Port  FAN 2 State : FanDirectionFault Wind Direction :Port-to-Power Prefer Wind Direction :Power-to-Port  Slot 2  FAN 1 State : FanDirectionFault Wind Direction :Port-to-Power Prefer Wind Direction :Power-to-Port  FAN 2 State : FanDirectionFault Wind Direction :Port-to-Power Prefer Wind Direction :Power-to-Port
凌轩 发表时间:2024-04-09
回复凌轩:
风扇期望配置不对,检查下配置吧
zhiliao_8h148y 发表时间:2024-04-09
怎么检查,有具体的命令嘛
凌轩 发表时间:2024-04-09
回复凌轩:
调整命令: fan prefer-direction slot slot-number { power-to-port | port-to-power }
配 port-to-power嘛
凌轩 发表时间:2024-04-09
粉丝:152人 关注:0人
您好,板卡不识别了。可以拔插测试或者替换槽位测试一下,有可能是板卡故障。
换了,还是不行
凌轩 发表时间:2024-04-09
粉丝:171人 关注:8人
风扇有问题,看下风扇状态
没有风扇指示灯,有风
凌轩 发表时间:2024-04-09
