配置telnet后,无法sys,感觉权限不对,但我写的3是最大权限了
local-user admin
password cipher
authorization-attribute level 3
authorization-attribute user-role security-audit
service-type telnet terminal
[QC]user-interface vty 0 4
[QC-ui-vty0-4]dis th
user-interface aux 0
authentication-mode scheme
user privilege level 3
protocol inbound telnet
user-interface vty 5 15
Password:
<QC>sy
% Unrecognized command found at '^' position.
<QC>?
User view commands:
cd Change current directory
copy Copy from one file to another
delete Delete a file
dir List files on a file system
display Display current system information
format Format the device
info-center Specify information center configuration information
mkdir Create a new directory
more Display the contents of a file
move Move the file
pwd Display current working directory
quit Exit from current command view
rename Rename a file or directory
rmdir Remove an existing directory
security-logfile Specify security log file configuration
sftp Establish one SFTP connection
undelete Recover a deleted file
[QC]display version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 2112P04
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.
H3C S3600V2-28F-EI uptime is 0 week, 1 day, 4 hours, 49 minutes
H3C S3600V2-28F-EI with 1 Processor
256M bytes SDRAM
2M bytes Nor Flash Memory
128M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is Ver.A
CPLDA Version is 001, CPLDB Version is 001
BootRom Version is 133
[SubSlot 0] 24 100FX SFP+4SFP+2Combo GE Hardware Version is Ver.A
(0)
?下看看 有没有15
(0)
打了呀
authorization-attribute user-role 后面改一下
没有,这个是v5的,v7好像才有15,看另外一个评论已经解决了
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
删不掉
创建了一个新的账户,把这个authorization-attribute user-role security-audit加到新的账户上,然后在admin上删掉‘authorization-attribute user-role security-audit’,这个就行了
是的,这个是审计权限,不能存在的
