防火墙映射会不会宕机
2024-04-18提问
  • 0收藏,179浏览
粉丝:0人 关注:2人
f1000-920-ai防火墙nat映射过多20多条会不会造成宕机啊,已经宕机了5次了,重启以后就恢复正常了。
<H3C>more startup.cfg
 version 7.1.064, Release 9345P2416
 sysname H3C
context Admin id 1
 telnet server enable
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 ip pool aaa 100.19.0.2 100.19.0.20
 ip pool aaa gateway 100.19.0.1
 dhcp enable
 lldp global enable
 password-recovery enable
vlan 1
object-group ip address 172.168.0.20
 security-zone Trust
 0 network host address 172.168.0.20
object-group ip address 172.168.1.201
 security-zone Trust
 0 network host address 172.168.1.201
controller Cellular1/0/0
interface Virtual-Template1
 ppp authentication-mode chap domain system
 remote address pool aaa
interface NULL0
interface GigabitEthernet1/0/0
 port link-mode route
 ip address 192.168.0.1 255.255.255.0
 ip address 222.185.248.10 255.255.255.248
 nat outbound 3001
 nat server protocol tcp global 222.185.248.10 9800 inside 172.168.1.201 9800 rule ServerRule_7
 nat server protocol tcp global 222.185.248.10 9801 inside 172.168.1.201 9801 rule ServerRule_8
 nat server protocol tcp global 222.185.248.10 9821 inside 172.168.1.201 9821 rule ServerRule_9
 nat server protocol tcp global 222.185.248.10 9822 inside 172.168.1.201 9822 rule ServerRule_10
 nat server protocol tcp global 222.185.248.10 9823 inside 172.168.1.201 9823 rule ServerRule_11
 nat server protocol tcp global 222.185.248.10 9824 inside 172.168.1.201 9824 rule ServerRule_12
 nat server protocol tcp global 222.185.248.10 9825 inside 172.168.1.201 9825 rule ServerRule_13
 nat server protocol tcp global 222.185.248.10 9831 inside 172.168.1.201 9831 rule ServerRule_14
 nat server protocol tcp global 222.185.248.10 9832 inside 172.168.1.201 9832 rule ServerRule_15
 nat server protocol tcp global 222.185.248.10 9833 inside 172.168.1.201 9833 rule ServerRule_16
 nat server protocol tcp global 222.185.248.10 9834 inside 172.168.1.201 9834 rule ServerRule_17
 nat server protocol tcp global 222.185.248.10 9835 inside 172.168.1.201 9835 rule ServerRule_20
 nat server protocol tcp global 222.185.248.10 18443 inside 10.10.10.6 18443 rule ServerRule_19
 nat server protocol tcp global 222.185.248.10 18888 inside 10.10.10.1 18888 rule ServerRule_18
 nat server protocol tcp global 222.185.248.10 20080 inside 172.168.0.20 20080 rule ServerRule_6
 nat server protocol tcp global 222.185.248.10 20081 inside 172.168.0.20 20081 rule ServerRule_5
 nat server protocol tcp global 222.185.248.10 50001 inside 172.168.0.20 50001 rule ServerRule_4
 nat server protocol tcp global 222.185.248.10 51001 inside 172.168.0.20 51001 rule ServerRule_3
 nat server protocol tcp global 222.185.248.10 65500 inside 172.168.0.20 65500 rule ServerRule_2
 gateway 222.185.248.9
interface GigabitEthernet1/0/4
 ip address 10.10.10.254 255.255.255.0
 nat hairpin enable
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/4
security-zone name DMZ
security-zone name Untrust
 import interface GigabitEthernet1/0/2
security-zone name Management
 import interface GigabitEthernet1/0/0
zone-pair security source Untrust destination Trust
 packet-filter 3001
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 authentication-mode scheme
 user-role network-admin
line class vty
line aux 0
line con 0
line vty 0 63
 ip route-static 0.0.0.0 0 222.185.248.9
 ip route-static 10.10.10.0 24 10.10.10.1
 ip route-static 172.168.0.0 21 10.10.10.1
 ip route-static 172.168.10.0 24 10.10.10.1
 ip route-static 172.168.11.0 24 10.10.10.1
 ssh server enable
acl advanced 3000
 rule 0 permit ip
acl advanced 3001
 rule 0 permit ip
domain system
 authentication ppp local
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$SULkYgwszTYLk2wQ$8SGSZDhKCtpsAj7Gulul8RcC9y6x/7EmiVfe5mco+NYfp5ROjB2+FsKDs2f6mE3TNg6GNfgCZEMA97lqFqCLuA==
 service-type ssh telnet terminal http https
 authorization-attribute user-role level-3
 password-control length 4
 password-control composition type-number 1 type-length 1
 undo password-control complexity user-name check
local-user system class network
 password cipher $c$3$2wzN75pw6zeKKZHEWJF0qWT5j+cGmeL5qQ==
 service-type ppp
 session statistics enable
 ipsec logging negotiation enable
l2tp-group 1 mode lns
 allow l2tp virtual-template 1
 undo tunnel authentication
 tunnel name LNS
 l2tp enable
 ike logging negotiation enable
 ip http enable
 ip https enable
 webui log enable
inspect block-source parameter-profile ips_block_default_parameter
inspect block-source parameter-profile url_block_default_parameter
inspect logging parameter-profile av_logging_default_parameter
inspect logging parameter-profile ips_logging_default_parameter
 loadbalance isp file flash:/lbispinfo_v1.5.tp
security-policy ip
 rule 0 name l-t,u
  action pass
  logging enable
  counting enable
  source-zone Local
  destination-zone Trust
  destination-zone Untrust
 rule 1 name t,u-l
  action pass
  counting enable
  source-zone Trust
  source-zone Untrust
  destination-zone Local
 rule 2 name t-u
  action pass
  logging enable
  counting enable
  source-zone Trust
 rule 3 name 1
  action pass
  counting enable
  source-zone Untrust
  destination-ip 172.168.0.20
  destination-ip 172.168.1.201
 rule 4 name 2
  action pass
  source-zone Trust
ips logging parameter-profile ips_logging_default_parameter
anti-virus logging parameter-profile av_logging_default_parameter
return
5 个回答
粉丝:144人 关注:0人
您好,和映射没关系
dis version看一下重启日志
粉丝:7人 关注:19人
20条映射影响不大;
可以升到最先版本看下,
https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Security/FW/Comware_V7/H3C_SecPath_F1000-AK180_F1000-AK130/
还需要看下是否加了IPS和AV等授权,这是2G内存的防火墙不建议加授权,对内存影响非常大,内存占用率高容易宕机。
粉丝:8人 关注:0人
单从NAT性能看不太可能出现问题的
建议打400热线或收集更多日志和组网细节进一步定位分析吧
粉丝:119人 关注:1人
才二十几个映射就宕机了?可以考虑升级版本,升级版本问题依旧,反馈400
Admin 二段
粉丝:5人 关注:0人
看日志分析吧 如果是内存满载 导致的话 可能是配置存在问题
