MSG360
  • 0收藏,255浏览
<MSG360>                                                               %Apr 18 16:41:58:016 2024 MSG360 STAMGR/6/STAMGR_CLIENT_ONLINE: Client 9286-aac1-4f30 went online from BSS 943b-b031-eb10 vlan 1 with SSID ???ф on AP 2-dtz Radio ID 2. State changed to Run.
%Apr 18 16:41:58:017 2024 MSG360 STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 9286-aac1-4f30 went offline from BSS 943b-b031-d9b0 with SSID ???ф on AP 7-zbx Radio ID 2. State changed to Unauth. Reason: Successfully roamed to another BSS.
%Apr 18 16:41:58:019 2024 MSG360 STAMGR/6/STAMGR_ROAM_SUCCESS: Client 9286-aac1-4f30 roamed from BSSID 943b-b031-d9b0 on AP 7-zbx Radio ID 2 of AC IP 127.0.0.1 to BSSID 943b-b031-eb10 on AP 2-dtz Radio ID 2 of AC IP 127.0.0.1 successfully.
%Apr 18 16:41:58:020 2024 MSG360 STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 9286-aac1-4f30, IP: 192.168.0.29, -NA-, -NA-, -NA-, Username: -NA-, AP name: 2-dtz, Radio ID: 2, Channel number: 11, SSID: ???ф, BSSID: 943b-b031-eb10.
%Apr 18 16:42:13:089 2024 MSG360 STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 900f-0c86-73db went offline from BSS 943b-b031-dde0 with SSID ???ф on AP 1-dtx Radio ID 1. State changed to Unauth. Reason: Received disassociation frame in Run state: reason code=8
%Apr 18 16:42:13:523 2024 MSG360 STAMGR/6/STAMGR_CLIENT_ONLINE: Client 900f-0c86-73db went online from BSS 943b-b031-dde0 vlan 1 with SSID ???ф on AP 1-dtx Radio ID 1. State changed to Run.
%Apr 18 16:42:13:524 2024 MSG360 STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 900f-0c86-73db, IP: 192.168.0.242, -NA-, -NA-, -NA-, Username: -NA-, AP name: 1-dtx, Radio ID: 1, Channel number: 149, SSID: ???ф, BSSID: 943b-b031-dde0.
 %Apr 18 16:42:15:258 2024 MSG360 NTP/5/NTP_STRATUM_CHANGE: System stratum changed from 3 to 2 after clock update.
%Apr 18 16:42:19:499 2024 MSG360 STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 900f-0c86-73db went offline from BSS 943b-b031-dde0 with SSID ???ф on AP 1-dtx Radio ID 1. State changed to Unauth. Reason: Received disassociation frame in Run state: reason code=8
%Apr 18 16:42:19:649 2024 MSG360 STAMGR/6/STAMGR_CLIENT_ONLINE: Client 900f-0c86-73db went online from BSS 943b-b031-dde0 vlan 1 with SSID ???ф on AP 1-dtx Radio ID 1. State changed to Run.
%Apr 18 16:42:19:650 2024 MSG360 STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 900f-0c86-73db, IP: 192.168.0.242, -NA-, -NA-, -NA-, Username: -NA-, AP name: 1-dtx, Radio ID: 1, Channel number: 149, SSID: ???ф, BSSID: 943b-b031-dde0.
    %Apr 18 16:42:40:198 2024 MSG360 STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 900f-0c86-d4af went offline from BSS 943b-b031-da50 with SSID ???ф on AP 5-xxs Radio ID 2. State changed to Unauth. Reason: Received disassociation frame in Run state: reason code=8
%Apr 18 16:42:40:275 2024 MSG360 STAMGR/6/STAMGR_CLIENT_ONLINE: Client 900f-0c86-d4af went online from BSS 943b-b031-da50 vlan 1 with SSID ???ф on AP 5-xxs Radio ID 2. State changed to Run.
%Apr 18 16:42:40:277 2024 MSG360 STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 900f-0c86-d4af, IP: 192.168.0.79, -NA-, -NA-, -NA-, Username: -NA-, AP name: 5-xxs, Radio ID: 2, Channel number: 11, SSID: ???ф, BSSID: 943b-b031-da50.
MSG 下面是一个路由器
粉丝:211人 关注:1人
这个就是无线终端的加入、漫游、离线的一些日志而已
客户反馈网慢
zhiliao_4J9sjR 发表时间:2024-04-18
网慢,上监控,基于snmp监控主干链路以及出口带宽的利用率
叫我靓仔 发表时间:2024-04-18
需要这么做
配置snmp,纳入zabbix或者imc管理
