我想问下10年前的s7506e 支持irf么,是否能通过升级固定到第二代、第三代irf
2024-04-19提问
  • 0收藏,114浏览
我想问下10年前的s7506e 支持irf么,是否能通过升级固定到第二代、第三代irf ,还是要购买升级主控板一类的
粉丝:44人 关注:1人
10年前的应该是V5 或者是更早的版本了,不能支持IRF。
ptime is 41 weeks,6 days,10 hours,29 minutes H3C S7506E MPU(M) with 1 BCM1125H Processor BOARD TYPE: LSQ1SRPB DRAM: 512M bytes FLASH: 64M bytes NVRAM: 512K bytes PCB 1 Version: VER.B PCB 2 Version: VER.B Bootrom Version: 303 CPLD 1 Version: 006 CPLD 2 Version: 006 Release Version: H3C S7506E-6616P05 Patch Version : None Slot 1 Without Board LPU 2: Uptime is 41 weeks,6 days,10 hours,24 minutes H3C S7506E LPU with 1 BCM1122 Processor [ComNet-7506-01]irf [ComNet-7506-01]irf-port [ComNet-7506-01]irf [ComNet-7506-01]irf-port ? INTEGER<1-2> Port number [ComNet-7506-01]irf-port 我觉得应该是支持的,但是我不知道他是哪个版本,是不是能通过升级到高版本上
zhiliao_nEO7c 发表时间:2024-04-19
回复zhiliao_nEO7c:
dis ver 我看一下
zhiliao_h907dg 发表时间:2024-04-19
MPU(M) 0: Uptime is 41 weeks,6 days,10 hours,42 minutes H3C S7506E MPU(M) with 1 BCM1125H Processor BOARD TYPE: LSQ1SRPB DRAM: 512M bytes FLASH: 64M bytes NVRAM: 512K bytes PCB 1 Version: VER.B PCB 2 Version: VER.B Bootrom Version: 303 CPLD 1 Version: 006 CPLD 2 Version: 006 Release Version: H3C S7506E-6616P05 Patch Version : None Slot 1 Without Board LPU 2: Uptime is 41 weeks,6 days,10 hours,37 minutes H3C S7506E LPU with 1 BCM1122 Processor BOARD TYPE: LSQ1GP48SC DRAM: 512M bytes FLASH: 0M bytes NVRAM: 0K bytes PCB 1 Version: VER.C Bootware Version: 306 CPLD 1 Version: 004 CPLD 2 Version: 004 Release Version: H3C S7506E-6616P05 Patch Version : None LPU 3: Uptime is 41 weeks,6 days,10 hours,38 minutes H3C S7506E LPU with 1 BCM1122 Processor BOARD TYPE: LSQ1GP48SC DRAM: 512M bytes FLASH: 0M bytes NVRAM: 0K bytes PCB 1 Version: VER.C Bootware Version: 306 CPLD 1 Version: 004 CPLD 2 Version: 004 Release Version: H3C S7506E-6616P05 Patch Version : None
回复zhiliao_nEO7c:
MPU(M) 0: Uptime is 41 weeks,6 days,10 上面还有信息,你在发一下
H3C Comware Platform Software Comware Software, Version 5.20, Release 6616P05 Copyright (c) 2004-2011 Hangzhou H3C Tech. Co., Ltd. All rights reserved. H3C S7506E uptime is 41 weeks, 6 days, 10 hours, 53 minutes
回复zhiliao_nEO7c:
Version 5.20, Release 6616P05 V5 版本的 ,肯定是不一行了,用vrrp 吧。灭别的方法了
不能升级么
回复zhiliao_nEO7c:
升级也不能跨版本从V5 升级到V7
粉丝:94人 关注:0人
具体要看硬件
粉丝:137人 关注:8人
看具体版本了
