msr5560
2024-04-22提问
  • 0收藏,78浏览
************************************************************************msr5660 telnet
 vty 0 4 au-mode scheme
 ping 通
但是远程报错如下 ****************************************************************************** * Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. All rights reserved.* * Without the owner's prior written consent, * * no decompiling or reverse-engineering shall be allowed. * ****************************************************************************** Login failed. 求助大神,谢谢
粉丝:137人 关注:8人
检查下远程相关的配置吧
粉丝:2人 关注:0人
1.12  MDC典型配置举例
1.12.1  MDC基本配置举例(独立运行模式)
某公司有一台设备Device,现要求将这台设备虚拟成两台独立的设备:MDC AMDC B,分给该公司的AB两个不同部门用作接入公司网络的网关。使得各部门可以独享设备的表项资源,并且可以根据各部门的业务需求分配设备的内存、CPU资源,未分配的使用设备缺省值。
图1-3 MDC基本配置组网图
缺省情况下,本设备的接口处于ADMAdministratively Down)状态,请根据实际需要在对应接口视图下使用undo shutdown命令开启接口。
(1)      创建MDC AMDC B
# 创建MDC A,供部门A使用。
[Device] mdc MDCA
It will take some time to create MDC...
MDC created successfully.
[Device-mdc-2-MDCA] quit
# 创建MDC B,供部门B使用。
[Device] mdc MDCB
[Device-mdc-3-MDCB] quit
# 取消缺省MDC2号业务板的使用权。
[Device] mdc Admin
[Device-mdc-1-Admin] undo location slot 2
The configuration associated with the specified slot of MDC will be lost. Continue? [Y/N]:y
[Device-mdc-1-Admin] quit
# MDC A分配接口Ten-GigabitEthernet2/0/1Ten-GigabitEthernet2/0/24
[Device] mdc MDCA
[Device-mdc-2-MDCA] allocate interface ten-gigabitethernet 2/0/1 to ten-gigabitethernet 2/0/24
Configuration of the interfaces will be lost. Continue? [Y/N]:y
Execute the location slot command in this view to make the configuration take effect.
# 2号业务板的使用权限分配给MDC A
[Device-mdc-2-MDCA] location slot 2
# 配置MDC ACPU权重为5
[Device-mdc-2-MDCA] limit-resource cpu weight 5
# 启动MDC A
[Device-mdc-2-MDCA] mdc start
It will take some time to start MDC...
MDC started successfully.
# MDC B分配接口Ten-GigabitEthernet2/0/25Ten-GigabitEthernet2/0/48
[Device] mdc MDCB
[Device-mdc-3-MDCB] allocate interface ten-gigabitethernet 2/0/25 to ten-gigabitethernet 2/0/48
# 2号业务板的使用权限分配给MDC B
[Device-mdc-3-MDCB] location slot 2
# 配置MDC BCPU权重为5
[Device-mdc-3-MDCB] limit-resource cpu weight 5
# 启动MDC B
[Device-mdc-3-MDCB] mdc start
(2)      登录MDC A,配置MDC A的管理以太网接口。
# 切换到MDC A,并按照提示信息键入组合键Ctrl+D终止MDC的自动配置过程,进入MDC A的命令行界面进行配置。
[Device] switchto mdc MDCA
Automatic configuration is running, press CTRL_D to break or press CTRL_B to
switch back to the default MDC.
# MDC A的名称修改为MDCA,以便和其它MDC区别。
[Device] sysname MDCA
# 配置MDC A 的网管口的IP地址、使能Telnet服务等基础配置,供用户远程登录MDC A
[MDCA] interface m-gigabitethernet 0/0/0
[MDCA-M-GigabitEthernet0/0/0] ip address 192.168.1.251 24
[MDCA-M-GigabitEthernet0/0/0] quit
[MDCA] telnet server enable
[MDCA] user-interface vty 0 63
[MDCA-line-vty0-63] authentication-mode none
[MDCA-line-vty0-63] user-role mdc-admin
# MDC A返回缺省MDC
[MDCA-line-vty0-63] return
<MDCA> switchback
[Device]
(3)      登录MDC B,配置MDC B的管理以太网接口。
[Device] switchto mdc MDCB
# MDC B的名称修改为MDCB,以便和其它MDC区别。
[Device] sysname MDCB
# 配置MDC B 的网管口的IP地址、使能Telnet服务等基础配置,供用户远程登录MDC B
[MDCB] interface m-gigabitethernet 0/0/0
[MDCB-M-GigabitEthernet0/0/0] ip address 192.168.2.252 24
[MDCB-M-GigabitEthernet0/0/0] quit
[MDCB] telnet server enable
[MDCB] user-interface vty 0 63
[MDCB-line-vty0-63] authentication-mode none
[MDCB-line-vty0-63] user-role mdc-admin
# MDC B返回缺省MDC
[MDCB-line-vty0-63] return
<MDCB> switchback
[Device]
(1)      查看MDC是否存在并且运转正常。(此时,Device上应该有三台处于正常工作active状态的MDC
<Device> display mdc
ID         Name            Status
1          Admin           active
2          MDCA            active
3          MDCB            active
(2)      模拟部门A的管理用户登录到MDC A,可以查看本设备的当前配置。
C:\> telnet 192.168.1.251
<MDCA> display current-configuration
……配置文件信息略……
1.12.2  MDC基本配置举例IRF模式)
1-4所示,某公司有两台设备已经组成了IRFMasterStandby上各有业务板23,每个业务板有12HGE接口。Master使用IRF端口1StandbyIRF端口2通过两条物理链路相连,MasterIRF端口1绑定了物理接口HundredGigE1/2/0/1HundredGigE1/3/0/1StandbyIRF端口2绑定了物理接口HundredGigE2/2/0/1HundredGigE2/3/0/1
现要求创建两台独立的虚拟设备:MDC AMDC B,分给该公司的AB两个部门用作接入公司网络的网关。使得各部门可以独享设备的表项资源,并且可以根据各部门的业务需求分配设备的内存、CPU资源,HundredGigE1/2/0/7HundredGigE1/2/0/12HundredGigE2/2/0/7HundredGigE2/2/0/12配给MDC AHundredGigE1/3/0/1HundredGigE1/3/0/6HundredGigE2/3/0/1HundredGigE2/3/0/6分配给MDC B
图1-4 IRF+MDC基本配置组网图
3. 配置思路
建议将IRF物理端口放到缺省MDC中,不要分配给非缺省MDC,一来能够确保IRF链路的安全性,IRF物理端口是用来组建IRF的,影响到整个IRF系统的运行。二来可以避免用户配置步骤错误,导致IRF物理端口不能正常工作。
然而,设备上的接口都是按组分配的,如果接口资源有限,用户需要将IRF物理端口所在组的端口分配给非缺省MDC时,必然会将IRF物理端口分配给非缺省MDC
本举例介绍了以上两种场景的配置步骤。其中,MDC A中不包含IRF物理端口,但是需要把IRF物理端口所在业务板(slot 2)的另一个分组的接口分配给MDC AMDC B中包含IRF物理端口(HundredGigE1/3/0/1HundredGigE2/3/0/1)。请根据您的网络规划,参考对应的步骤。
4. 配置步骤
(1)      创建MDC AMDC B。建议先确定MDC可成功创建后,再进行下面的配置。
# 创建MDC A,供部门A使用。
<IRF> system-view
[IRF] mdc MDCA
[IRF-mdc-2-MDCA] quit
# 创建MDC B,供部门B使用。
[IRF] mdc MDCB
[IRF-mdc-3-MDCB] quit
(2)      分别取消HundredGigE1/2/0/1HundredGigE2/2/0/1IRF端口的绑定。如1-4所示有两条IRF链路,配置时请确保一条IRF链路处于UP状态,以免引起IRF分裂。
# 关闭接口HundredGigE1/2/0/1HundredGigE2/2/0/1
[IRF] interface range hundredgige 1/2/0/1 hundredgige 2/2/0/1
[IRF-if-range] shutdown
[IRF-if-range] quit
# 取消HundredGigE1/2/0/1IRF端口1/1的绑定。
[IRF] irf-port 1/1
[IRF-irf-port1/1] undo port group interface HundredGigE1/2/0/1
[IRF-irf-port1/1] quit
# 取消HundredGigE2/2/0/1IRF端口2/2的绑定。
[IRF] irf-port 2/2
[IRF-irf-port2/2] undo port group interface HundredGigE2/2/0/1
[IRF-irf-port2/2] quit
(3)      取消缺省MDC对成员设备12号业务板和成员设备22号业务板的使用权。
[IRF] mdc Admin
[IRF-mdc-1-Admin] undo location chassis 1 slot 2
[IRF-mdc-1-Admin] undo location chassis 2 slot 2
[IRF-mdc-1-Admin] quit
(4)      配置并启动MDC A
# MDC A分配接口HundredGigE1/2/0/7HundredGigE1/2/0/12HundredGigE2/2/0/7HundredGigE2/2/0/12。(该业务板上每6个接口为一组,这6个接口必须同时分配)
[IRF] mdc MDCA
[IRF-mdc-2-MDCA] allocate interface hundredgige 1/2/0/7 to hundredgige 1/2/0/12
[IRF-mdc-2-MDCA] allocate interface hundredgige 2/2/0/7 to hundredgige 2/2/0/12
# 将成员设备12号业务板和成员设备22号业务板的使用权限分配给MDC A
[IRF-mdc-2-MDCA] location chassis 1 slot 2
[IRF-mdc-2-MDCA] location chassis 2 slot 2
# 配置MDC ACPU权重为5
[IRF-mdc-2-MDCA] limit-resource cpu weight 5
# 启动MDC A
[IRF-mdc-2-MDCA] mdc start
(5)      恢复缺省MDC对成员设备12号业务板和成员设备22号业务板的使用权限。
[IRF] mdc Admin
[IRF-mdc-1-Admin] location chassis 1 slot 2
[IRF-mdc-1-Admin] location chassis 2 slot 2
(6)      恢复缺省MDCHundredGigE1/2/0/1HundredGigE2/2/0/1IRF端口绑定。
# HundredGigE1/2/0/1IRF端口1/1的绑定。
[IRF] irf-port 1/1
[IRF-irf-port1/1] port group interface hundredgige1/2/0/1
# HundredGigE2/2/0/1IRF端口2/2的绑定。
[IRF] irf-port 2/2
[IRF-irf-port2/2] port group interface hundredgige2/2/0/1
# 打开接口HundredGigE1/2/0/1HundredGigE2/2/0/1
[IRF-if-range] undo shutdown
[IRF-if-range] quit
(7)      配置MDC A网管口的IP地址、使能Telnet服务。
[IRF] switchto mdc MDCA
<IRF> system-view
[IRF] sysname MDCA
# 配置MDC A的网管口的IP地址、使能Telnet服务等基础配置,供用户远程登录MDC A
[MDCA] display interface m-gigabitethernet brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
M-GE1/0/0/0          DOWN DOWN     --
M-GE1/0/0/1          DOWN DOWN     --
M-GE1/0/0/2          UP   UP       --
M-GE1/0/0/3          DOWN DOWN     --
[MDCA] interface m-gigabitethernet 1/0/0/2
[MDCA-M-GigabitEthernet1/0/0/2] ip address 192.168.2.251 24
[MDCA-M-GigabitEthernet1/0/0/2] quit
# MDC A返回缺省MDC
<MDCA> switchback
[IRF]
(8)      分别取消HundredGigE1/3/0/1HundredGigE2/3/0/1IRF端口的绑定。如1-4所示有两条IRF链路,配置时请确保一条IRF链路处于UP状态,以免引起IRF分裂。
# 关闭接口HundredGigE1/3/0/1HundredGigE2/3/0/1
[IRF] interface range hundredgige 1/3/0/1 hundredgige 2/3/0/1
[IRF-if-range] quit
# 取消HundredGigE1/3/0/1IRF端口1/1的绑定。
[IRF] irf-port 1/1
[IRF-irf-port1/1] undo port group interface HundredGigE1/3/0/1
# 取消HundredGigE2/3/0/1IRF端口2/2的绑定。
[IRF] irf-port 2/2
[IRF-irf-port2/2] undo port group interface HundredGigE2/3/0/1
(9)      取消缺省MDC对成员设备13号业务板和成员设备23号业务板的使用权。
[IRF] mdc Admin
[IRF-mdc-1-Admin] undo location chassis 1 slot 3
[IRF-mdc-1-Admin] undo location chassis 2 slot 3
(10)   配置并启动MDC B
# MDC B分配接口HundredGigE1/3/0/1HundredGigE1/3/0/6HundredGigE2/3/0/1HundredGigE2/3/0/6。(该业务板上每6个接口为一组,这6个接口必须同时分配)
[IRF] mdc MDCB
[IRF-mdc-3-MDCB] allocate interface hundredgige 1/3/0/1 to hundredgige 1/3/0/6
[IRF-mdc-3-MDCB] allocate interface hundredgige 2/3/0/1 to hundredgige 2/3/0/6
# 将成员设备13号业务板和成员设备23号业务板的使用权限分配给MDC B
[IRF-mdc-3-MDCB] location chassis 1 slot 3
[IRF-mdc-3-MDCB] location chassis 2 slot 3
# 配置MDC BCPU权重为5
[IRF-mdc-3-MDCB] limit-resource cpu weight 5
# 启动MDC B
[IRF-mdc-3-MDCB] mdc start
(11)   MDC B中的HundredGigE1/3/0/1HundredGigE2/3/0/1配置为IRF物理端口,和IRF端口绑定。
# 切换到MDC B,并按照提示信息键入组合键Ctrl+D终止MDC的自动配置过程,进入MDC B的命令行界面进行配置。
[IRF] switchto mdc MDCB
<IRF> system-view
[IRF] sysname MDCB
[MDCB] interface range hundredgige 1/3/0/1 hundredgige 2/3/0/1
[MDCB-if-range] shutdown
[MDCB-if-range] quit
[MDCB] quit
# MDC B返回缺省MDC
<MDCB> switchback
[IRF]
# 显示MDC B的编号。
[IRF] display mdc
ID         Name            Status
1          Admin           active
2          MDCA            active
3          MDCB            active
# MDC B(编号为3)中的HundredGigE1/3/0/1IRF端口1/1绑定。
[IRF] irf-port 1/1
[IRF-irf-port1/1] port group mdc 3 interface hundredgige 1/3/0/1
# MDC B(编号为3)中的HundredGigE2/3/0/1IRF端口2/2绑定。
[IRF] irf-port 2/2
[IRF-irf-port2/2] port group mdc 3 interface hundredgige 2/3/0/1
# 切换到MDC B
<MDCB> system-view
# 打开接口HundredGigE1/3/0/1HundredGigE2/3/0/1
[MDCB-if-range] undo shutdown
(12)   配置MDC B网管口的IP地址、使能Telnet服务。
# 配置MDC B的网管口的IP地址、使能Telnet服务等基础配置,供用户远程登录MDC B
[MDCB] display interface m-gigabitethernet brief
[MDCB] interface m-gigabitethernet 1/0/0/2
[MDCB-M-GigabitEthernet1/0/0/2] ip address 192.168.1.252 24
[MDCB-M-GigabitEthernet1/0/0/2] quit
# MDC B返回缺省MDC
<MDCB> switchback
[IRF]
5. 验证配置
(1)      查看MDC是否存在并且运转正常。(此时,IRF上应该有三台处于正常工作active状态的MDC
[IRF] display mdc
ID         Name            Status
1          Admin           active
2          MDCA            active
3          MDCB            active
(2)      显示IRF链路信息,将看到两条IRF链路均处于UP状态。其中一条链路处于缺省MDC中,另一条链路处于MDC B中。
[IRF] display irf link
Member 1
 IRF Port    Interface                           Status
 1           HundredGigE1/2/0/1(MDC1)            UP
             HundredGigE1/3/0/1(MDC3)            UP
 2           disable                             --
Member 2
 1           disable                             --
 2           HundredGigE2/2/0/1(MDC1)            UP
             HundredGigE2/3/0/1(MDC3)            UP
(3)      模拟部门A的管理用户登录到MDC A,可以查看本设备的当前配置。
显示信息略……。
02-MDC配置
粉丝:44人 关注:1人
1、有可能是telnet 在线用户数达到了最大,其他的用户就登录不上去了,通过console清楚一下在线远程用户
2、检查是否有IP地址冲突
