WX2510H-PWR+WA6338-FIT POE供电不足?
2024-04-23提问
  • 1收藏,128浏览
WX2510H-PWR管理器4个POE接口满接4台WA6338-FIT PA之前都用的好好的,现在时不时出现连上无线要等一两分钟才有网络,会不会是AC控制器POE供电不足导致
# interface Vlan-interface100 ip address 172.168.100.1 255.255.255.0 # interface GigabitEthernet1/0/5 port link-mode route ip address 192.168.2.254 255.255.255.0 undo dhcp select server dhcp snooping trust # interface GigabitEthernet1/0/1 port link-mode bridge port access vlan 100 poe enable dhcp snooping trust # interface GigabitEthernet1/0/2 port link-mode bridge port access vlan 100 poe enable dhcp snooping trust # interface GigabitEthernet1/0/3 port link-mode bridge port access vlan 100 poe enable dhcp snooping trust # interface GigabitEthernet1/0/4 port link-mode bridge port access vlan 100 poe enable dhcp snooping trust # wlan virtual-ap-group default-virtualapgroup # wlan ap 8061-6c57-34f0 model WA6338 serial-id 219801A2DQ822CE000NZ vlan 1 radio 1 channel 36 max-power 16 channel band-width 80 service-template ceshi2 service-template test radio 2 channel 149 channel band-width 80 service-template ceshi2 service-template test radio 3 channel 1 max-power 15 channel band-width 20 service-template h3c-g-9bfe18 gigabitethernet 1 smartrate-ethernet 1 # wlan ap 8061-6c57-3e80 model WA6338 serial-id 219801A2DQ822CE000QM vlan 1 radio 1 channel 52 channel band-width 80 service-template ceshi2 service-template test radio 2 channel 161 channel band-width 80 service-template ceshi2 service-template test radio 3 channel 6 max-power 15 channel band-width 20 service-template h3c-g-9bfe18 gigabitethernet 1 smartrate-ethernet 1 # wlan ap 8061-6c57-59e0 model WA6338 serial-id 219801A2DQ822CE000WB vlan 1 radio 1 channel 36 channel band-width 80 service-template ceshi2 service-template test radio 2 channel 161 channel band-width 80 service-template ceshi2 service-template test radio 3 channel 11 max-power 15 channel band-width 20 service-template h3c-g-9bfe18 gigabitethernet 1 smartrate-ethernet 1 # wlan ap 8061-6c57-6e80 model WA6338 serial-id 219801A2DQ822CE000ZW vlan 1 radio 1 channel 52 channel band-width 80 service-template ceshi2 service-template test radio 2 channel 161 channel band-width 80 service-template ceshi2 service-template test radio 3 channel 1 max-power 15 channel band-width 20 service-template h3c-g-9bfe18 gigabitethernet 1 smartrate-ethernet 1
粉丝:137人 关注:8人
供电不足可能ap状态也不稳定,看下ap上下线的记录
还没试过登录AP呢 输入地址就可以登录吧
UglyDuckling 发表时间:2024-04-23
回复UglyDuckling:
ac上看有没有掉线
zhiliao_sEUyB 发表时间:2024-04-23
粉丝:23人 关注:0人
AP能上线、终端能上网,说明配置应该没问题,你看下AC日志有没有相关提示
好像没有,
