WX3510H-版本R5471,对接华为NCE认证平台
2024-04-23提问
  • 0收藏,130浏览
现象:
1、dot1x对接没问题
2、portal认证能成功,但是过一会手机会自动弹出认证界面,需要重现输入账号密码的。portal无感知认证功能不行
AC-IP:10.x.y.2
huawei认证服务器地址:10.x.x.110
集中转发
配置:
wlan service-template 2
 ssid Testmobile-h3c
 vlan 506
 user-isolation enable
 client-rate-limit inbound mode static cir 10240
 client-rate-limit outbound mode static cir 10240
 portal enable method direct
 portal domain macportal
 portal bas-ip 10.x.y.2
 portal apply web-server macportal
 portal apply web-server macportal_backup secondary
 portal apply mac-trigger-server macportal
 portal temp-pass period 20 enable
 service-template enable
radius scheme macportal
 primary authentication 10.x.x.110
 primary accounting 10.x.x.110
 accounting-on enable
 key authentication cipher $c$3$vmZmIEVVIvN38LstQ4bLLAkvnAOcQnrU
 key accounting cipher $c$3$DpJ7RXdz/iYr+/QpXc+q8+uvLjUNBvyM
 user-name-format without-domain
 nas-ip 10.x.y.2
domain macportal
 authorization-attribute idle-cut 10 1024
 authentication portal radius-scheme macportal
 authorization portal radius-scheme macportal
 accounting portal radius-scheme macportal
 portal free-rule 0 source ip any destination ip 10.x.x.110 255.255.255.255(huawei 认证服务器地址)
 portal free-rule 1 source ip any destination ip 10.x.x.x 255.255.255.255
 portal free-rule 2 source ip any destination ip 10.xx.x 255.255.255.255
 portal free-rule 20 destination ip any udp 53
 portal free-rule 21 destination ip any tcp 53
 portal free-rule 22 destination ip any tcp 5223
 portal free-rule 24 source ip any destination ip 10.x.x.xx 255.255.255.255(DNS1)
 portal free-rule 25 source ip any destination ip 10.x.x.xx 255.255.255.255(DNS2)
 portal free-rule 30 destination ip any udp 8445
 portal free-rule 31 destination ip any tcp 8445
 portal free-rule 32 destination ip any tcp 19008
 portal safe-redirect enable
 portal safe-redirect method get post
 portal safe-redirect user-agent Android
 portal safe-redirect user-agent xx
 portal safe-redirect user-agent iPhone
portal web-server macportal
 url http://10.x.x.110:8445/portal
 captive-bypass enable
 url-parameter ac-ip value 10.x.y.2
 url-parameter redirect-url original-url
 url-parameter ssid ssid
 url-parameter uaddress source-address
 url-parameter umac source-mac
portal server macportal
 ip 10.x.x.110 key cipher $c$3$9OlFro3mlyn5S+eOO72glAj7aVKXXGLn
 port 50200
portal mac-trigger-server macportal
 ip 10.x.x.110
粉丝:171人 关注:8人
正常对接就可以,认证服务器那面看下掉线原因是什么
 portal temp-pass period 20 enable 这个不需要配置吧 去掉试试
 accounting-on enable 正常也不需要配置 去掉试试
 captive-bypass enable 去掉试试
有没有我们AC和华为NCE认证平台的对接案例
