EWP-UAP380-MSG 如何恢复出厂设置
2024-04-24提问
  • 1收藏,93浏览
EWP-UAP380-MSG 忘记密码,如何恢复出厂设置
粉丝:137人 关注:8人
恢复出厂设置命令
<H3C>reset saved-configuration //清空交换机配置
The saved configuration file will be erased. Are you sure? [Y/N]:y //设备提示保存的配置将会被删除,是否继续。
Configuration file in flash: is being cleared. Please wait ...
MainBoard:
Configuration file is cleared. //配置已被清空
<H3C>reboot //重启交换机
Current configuration may be lost after the reboot, save current configuration? [Y/N]:n //设备提示会在重启后丢失当前配置,是否保存当前配置,选择n
This command will reboot the device. Continue? [Y/N]:y //设备提示设备将会重启,是否继续,选择Y
Now rebooting, please wait...
