路由表有相关的条目,fib没有
2024-04-25提问
  • 0收藏,109浏览
fib表缺了路由表里面的172.18条目
<firewall backup>dis ip routing-table
Destinations : 37       Routes : 38
Destination/Mask   Proto   Pre Cost        NextHop         Interface
0.0.0.0/32         Direct  0   0           127.0.0.1       InLoop0
10.70.0.0/24       O_INTRA 10  102         10.70.202.2     Vlan202
10.70.0.254/32     O_INTRA 10  102         10.70.202.2     Vlan202
10.70.1.0/24       O_ASE1  150 121         10.70.202.2     Vlan202
10.70.2.0/24       O_ASE1  150 121         10.70.202.2     Vlan202
10.70.3.0/24       O_ASE1  150 121         10.70.202.2     Vlan202
10.70.4.0/24       O_ASE1  150 121         10.70.202.2     Vlan202
10.70.5.0/24       O_ASE1  150 121         10.70.202.2     Vlan202
10.70.6.0/24       O_ASE1  150 121         10.70.202.2     Vlan202
10.70.7.0/24       O_ASE1  150 121         10.70.202.2     Vlan202
10.70.8.0/24       O_ASE1  150 121         10.70.202.2     Vlan202
10.70.9.0/24       O_ASE1  150 121         10.70.202.2     Vlan202
10.70.10.0/24      O_ASE1  150 121         10.70.202.2     Vlan202
10.70.11.0/24      O_ASE1  150 121         10.70.202.2     Vlan202
10.70.12.0/24      O_ASE1  150 121         10.70.202.2     Vlan202
10.70.13.0/24      O_ASE1  150 121         10.70.202.2     Vlan202
10.70.15.0/24      O_ASE1  150 121         10.70.202.2     Vlan202
10.70.202.0/24     Direct  0   0           10.70.202.1     Vlan202
10.70.202.0/32     Direct  0   0           10.70.202.1     Vlan202
10.70.202.1/32     Direct  0   0           127.0.0.1       InLoop0
10.70.202.255/32   Direct  0   0           10.70.202.1     Vlan202
10.70.203.0/24     O_INTRA 10  101         10.70.202.2     Vlan202
10.70.204.0/24     O_INTRA 10  103         10.70.202.2     Vlan202
10.70.207.0/24     O_INTRA 10  2           10.70.202.2     Vlan202
                                           10.70.202.3     Vlan202
10.80.100.0/24     O_ASE1  150 121         10.70.202.2     Vlan202
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
127.0.0.1/32       Direct  0   0           127.0.0.1       InLoop0
127.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
172.18.0.0/16      Static  60  0           172.18.21.5     Vlan21
172.18.21.0/24     Direct  0   0           172.18.21.6     Vlan21
172.18.21.0/32     Direct  0   0           172.18.21.6     Vlan21
172.18.21.6/32     Direct  0   0           127.0.0.1       InLoop0
172.18.21.255/32   Direct  0   0           172.18.21.6     Vlan21
224.0.0.0/4        Direct  0   0           0.0.0.0         NULL0
224.0.0.0/24       Direct  0   0           0.0.0.0         NULL0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
<firewall backup>ping 10.70.10.1
Ping 10.70.10.1 (10.70.10.1): 56 data bytes, press CTRL+C to break
Request time out
Request time out
Request time out
--- Ping statistics for 10.70.10.1 ---
4 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
<firewall backup>%Jan  1 01:56:59:977 2013 firewall backup PING/6/PING_STATISTICS: Ping statistics for 10.70.10.1: 4 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss.
<firewall backup>
<firewall backup>dis fib
Destination count: 40 FIB entry count: 41
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
10.70.0.0/24       10.70.202.2     UDG      Vlan202                  Null
10.70.0.254/32     10.70.202.2     UDGH     Vlan202                  Null
10.70.1.0/24       10.70.202.2     UDG      Vlan202                  Null
10.70.2.0/24       10.70.202.2     UDG      Vlan202                  Null
10.70.3.0/24       10.70.202.2     UDG      Vlan202                  Null
10.70.4.0/24       10.70.202.2     UDG      Vlan202                  Null
10.70.5.0/24       10.70.202.2     UDG      Vlan202                  Null
10.70.6.0/24       10.70.202.2     UDG      Vlan202                  Null
10.70.7.0/24       10.70.202.2     UDG      Vlan202                  Null
10.70.8.0/24       10.70.202.2     UDG      Vlan202                  Null
10.70.9.0/24       10.70.202.2     UDG      Vlan202                  Null
10.70.10.0/24      10.70.202.2     UDG      Vlan202                  Null
10.70.11.0/24      10.70.202.2     UDG      Vlan202                  Null
10.70.12.0/24      10.70.202.2     UDG      Vlan202                  Null
粉丝:137人 关注:8人
在计算机网络中,路由表和转发信息库(Forwarding Information Base,简称FIB)是两个重要的数据结构,它们都用于指导数据包在网络中的转发。虽然它们有相似之处,但在功能和实现上存在一些差异。
路由表是一个包含网络可达性信息的表格,它通常存储在路由器或其他网络设备中。路由表由路由协议(如BGP、OSPF等)动态生成或管理员手动配置,用于决定数据包如何从一个网络转发到另一个网络。路由表中的每个条目通常包含目标网络地址、子网掩码、下一跳地址以及度量值等信息。
转发信息库(FIB)是路由器或其他网络设备用于快速查找数据包转发路径的数据结构。它是路由表的一个简化版本,通常用于硬件转发,以提高数据包转发的效率。FIB中的条目通常基于路由表生成,但可能不包含路由表中的所有详细信息。FIB的主要目的是为数据包查找提供一个快速、有效的查找机制。
现在,针对你提到的问题“路由表有相关的条目,但FIB没有”,这可能是由于以下原因造成的:
  1. 同步延迟:在某些情况下,路由表的更新可能没有及时同步到FIB中。这可能是由于软件或硬件的性能问题、同步机制的设计问题或其他因素导致的。
  2. 策略路由:在某些复杂的网络环境中,可能会使用策略路由来根据特定的条件(如源地址、目标地址、应用层信息等)来转发数据包。在这种情况下,即使路由表中有相关的条目,但由于策略路由的干预,这些条目可能不会被添加到FIB中。
  3. 路由过滤:网络设备可能会根据某些过滤规则来过滤路由表中的条目,以防止不安全的或不必要的路由信息被添加到FIB中。这可能导致某些路由表条目在FIB中不存在。
为了解决这个问题,你可以尝试以下步骤:
  1. 检查同步机制:确保路由表的更新能够及时同步到FIB中。你可以查看设备的配置和日志,了解同步机制的工作状态。
  2. 检查策略路由和过滤规则:查看是否有任何策略路由或过滤规则可能导致某些路由表条目不被添加到FIB中。如果有,你可以调整这些规则以满足你的需求。
  3. 重启设备或重新加载配置:有时,重启设备或重新加载配置可以解决同步问题或清除潜在的缓存问题。但请注意,这可能会导致短暂的网络中断,因此请在合适的时间进行此操作。
