SR6602-X 地址映射
2017-09-20提问
  • 1收藏,2744浏览
以下是路由配置:
version 5.20, Release 3302
 sysname Router
 domain default enable system
 dns server 211.138.106.7
 telnet server enable
 ip http enable
 password-recovery enable
acl number 3000
 rule 0 permit ip
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$i+Ze7TNGXy27Lwaq2azYFxSYMbHdpkEW
 authorization-attribute level 3
 service-type terminal
 service-type web
local-user h3cadmin
 password cipher $c$3$J9e3KDZK6dBVl2mcyRHMhgzAW7BcsxRCRc8=
 service-type telnet
 service-type web
interface NULL0
interface GigabitEthernet0/0/0
 description to hulianwang
 nat outbound 3000
 ip address 111.53.48.126 255.255.255.240
interface GigabitEthernet0/0/1
 description to FW
 ip address 192.168.102.2 255.255.255.0
interface GigabitEthernet0/0/2
 nat outbound 3000
 nat server protocol tcp global 124.**.215.* 8080 inside 172.16.16.17 8080     映射地址
 nat server protocol tcp global 124.**.215.* 9500 inside 172.16.16.17 9500      映射地址
 ip address 124.**.215.* 255.255.255.240
interface GigabitEthernet0/0/3
interface M-GigabitEthernet0/0/0
nqa entry imclinktopologypleaseignore ping
 type icmp-echo
  destination ip 192.168.102.254
  frequency 270000
 ip route-static 0.0.0.0 0.0.0.0 111.53.48.113
 ip route-static 0.0.0.0 0.0.0.0 124.165.215.1 preference 100
 ip route-static 10.10.10.0 255.255.255.0 192.168.102.1
 ip route-static 172.16.0.0 255.255.0.0 192.168.102.1
 ip route-static 172.17.0.0 255.255.0.0 192.168.102.1
 ip route-static 192.168.100.0 255.255.255.0 192.168.102.1
 ip route-static 192.168.101.0 255.255.255.0 192.168.102.1
 snmp-agent
 snmp-agent local-engineid 800063A2035CDD70BDF014
 snmp-agent community read public
 snmp-agent community write private
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 172.16.0.29 params securityname public v2c
 snmp-agent target-host trap address udp-domain 172.16.16.16 params securityname public v2c
 nqa schedule imclinktopologypleaseignore ping start-time now lifetime 630720000
 load xml-configuration
user-interface con 0
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
<Router>
以下为防火墙配置:
  sysname FW
 firewall packet-filter enable
 firewall packet-filter default permit
 firewall statistic system enable
radius scheme system
 server-type extended
domain system
local-user h3cadmin
 password simple jkga
 service-type telnet
 level 3
interface Aux0
 async mode flow
 ip address 192.168.101.2 255.255.255.0
interface GigabitEthernet0/1
interface GigabitEthernet1/0
interface GigabitEthernet1/1
 ip address 192.168.102.1 255.255.255.0
interface Encrypt2/0
interface NULL0
firewall zone local
 set priority 100
firewall zone trust
 add interface GigabitEthernet0/0
 set priority 85
firewall zone untrust
 add interface GigabitEthernet1/1
 set priority 5
firewall zone DMZ
 set priority 50
firewall interzone local trust
firewall interzone local untrust
firewall interzone local DMZ
firewall interzone trust untrust
firewall interzone trust DMZ
firewall interzone DMZ untrust
hwping-agent enable
hwping imclinktopologypleaseignore ping
 test-type icmp
 destination-ip 192.168.102.254
 frequency 270
 ip route-static 0.0.0.0 0.0.0.0 192.168.102.2 preference 60
 ip route-static 10.10.10.0 255.255.255.0 192.168.101.1 preference 60
 ip route-static 172.16.0.0 255.255.0.0 192.168.101.1 preference 60
 ip route-static 172.17.0.0 255.255.0.0 192.168.101.1 preference 60
 ip route-static 192.168.100.0 255.255.255.0 192.168.101.1 preference 60
 snmp-agent
 snmp-agent local-engineid 000063A27F00000100001B58
return
<FW>
路由器线路:
主网入口  GigabitEthernet0/0/2 124.**.215.*/255.255.255.240
去防火墙  GigabitEthernet0/0/1 192.168.102.2/255.255.255.0
防火墙线路  :
路由器来  GigabitEthernet1/1      192.168.102.1 255.255.255.0
去核心    GigabitEthernet0/0       192.168.101.2 255.255.255.0
Guohao 九段
粉丝:35人 关注:2人
这个是有啥问题啊?nat的配置看起来正常
地址映射不通 外网访问不到映射的地址 是不是防火墙也要进行设置
zhiliao_76486 发表时间:2017-09-20
啥意思?是不通还是有啥问题?把问题现象描述的再详细一点吧
zhiliao_76486 知了小白
可以在66上display nat session 看一下有没有相应会话。另外防火墙上如果有办法抓包或者debug,也可以看下报文有没有正常发送到防火墙上
Guohao 发表时间:2017-09-20
防火墙没有做域间策略吧,你把防火墙跳过试试
风干工程师肉干要不要 发表时间:2017-09-20
