防火墙F1060堆叠配置BFD MAD后CPU负载达67%
2018-09-29提问
  • 1收藏,2154浏览
最新版的华三模拟器中,两台F1060防火墙配置好堆叠,检查正常后,再配置BDF MAD,一连线CPU负荷就飚升67%,删除连线CPU就恢复正常。除了堆叠和BFD MAD,其它任何配置都没做,也没连接任何其它设备(所以排除环路,用交换机配置也是同样的问题)。
防火墙的配置过程如下:
FW-A堆叠
irf member 1 priority 32
interface range Gi1/0/22 to Gi1/0/23
 shutdown
irf-port 1/2
 port group interface GigabitEthernet1/0/22
 port group interface GigabitEthernet1/0/23
save //保存配置
irf-port-configuration active
FW-B堆叠
irf member 1 renumber 2       //IRF编号改为2,改完要保存重启
save --> quit --> reboot
interface range Gi2/0/22 to Gi2/0/23
 shutdown
irf-port 2/1
 port group interface GigabitEthernet2/0/22
 port group interface GigabitEthernet2/0/23
save //保存配置
连接好线,等竞选完毕。
MAD检测
 port link-mode bridge
interface GigabitEthernet2/0/1
vlan 4091 //vlan唯一
 description BFD MAD
 port GigabitEthernet1/0/1 GigabitEthernet2/0/1
interfacevlan-interface4094
 mad bfd enable
 mad ip address 172.16.255.1 255.255.255.252 member 1
 mad ip address 172.16.255.2 255.255.255.252 member 2
 undo stp enable
 undo stp enable
dis cpu 结果如下:
Slot 1 CPU 0 CPU usage:
     65% in last 5 seconds
     64% in last 1 minute
     65% in last 5 minutes
 Slot 2 CPU 0 CPU usage:
     68% in last 5 seconds
     67% in last 1 minute
dis bfd session
 Total Session Num: 1 Up Session Num: 0 Init Mode: Active
 97/0    172.16.1.1   172.16.1.2 Down 0ms        Vlan4094
狗剩 八段
粉丝:41人 关注:1人
用聚合口做
那是另外一种配置方案,并不能解决本方案的问题。本方案的问题在哪里呢?
zhiliao_t3PFa 发表时间:2018-09-30
