wa4320h
2018-10-04提问
  • 1收藏,1419浏览
<WA4320H-ACN>tftp 192.168.0.1 get wa4300-fat.bin File will be transferred in binary mode Downloading file from remote TFTP server, please wait... Unable to send command to server <WA4320H-ACN> %Apr 26 12:04:50:902 2000 WA4320H-ACN WMSH/6/WMESH_EXIT_ZERO_CFG_STATE: The device has exited zero configuration state. %Apr 26 12:04:55:901 2000 WA4320H-ACN WMSH/6/WMESH_ENTER_ZERO_CFG_STATE: The device has entered zero configuration state. %Apr 26 12:05:36:064 2000 WA4320H-ACN WMSH/6/WMESH_EXIT_ZERO_CFG_STATE: The device has exited zero configuration state. %Apr 26 12:05:41:063 2000 WA4320H-ACN WMSH/6/WMESH_ENTER_ZERO_CFG_STATE: The device has entered zero configuration state. %Apr 26 12:06:21:185 2000 WA4320H-ACN WMSH/6/WMESH_EXIT_ZERO_CFG_STATE: The device has exited zero configuration state. %Apr 26 12:06:26:185 2000 WA4320H-ACN WMSH/6/WMESH_ENTER_ZERO_CFG_STATE: The device has entered zero configuration state.<WA4320H-ACN>tftp 192.168.0.1 get wa4300-fat.bin。   刷fat出现这种情况要怎么处理?
粉丝:17人 关注:2人
前面是空配置;
后面是tftp传版本,传完后需要boot-loader指定一下;
boot-loader file wa430000a_fat.bin main,是这样吗?
zhiliao_H1JSp 发表时间:2018-10-04
对,注意敲一下问号,看名字前面有没有路径;
发表时间:2018-10-04
还是刷不进去,<WA4320H-ACN>boot-loader file wa4300_fat.bin main %Apr 26 12:08:22:200 2000 WA4320H-ACN DEVM/5/BOARD_REBOOT: Board is rebooting on Chassis 0 Slot 1. System is rebooting; can't respond to your command. %Apr 26 12:08:24:295 2000 WA4320H-ACN IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/4 link status is DOWN. %Apr 26 12:08:24:417 20 System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing....................Done! **************************************************************************** * * * H3C WA4320H-ACN BootWare, Version 1.15 * * * **************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Compiled Date : Mar 27 2017 CPU Type : ATHEROS AR9557 CPU L1 Cache : 32KB CPU Clock Speed : 720MHz Memory Type : SDRAM Memory Size : 256MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 128MB PCB Version : Ver.B BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300_fit.bin!........... ................................................ The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ .........................................................Done! System application is starting... User interface con0 is available.
不要放一行看,不行就bootware里导,按如下步骤: 首先需要console线登陆进入设备,进入设备之后 电脑用网线和AP相连,电脑ip地址配置为192.168.0.1 瘦AP切换为胖AP之bootrom菜单TFTP升级步骤 升级有风险,切记不要断电,整个过程记录下来 帐号名:yx800 密码:01230123 (1)从官网下载WAP621的软件版本,将压缩包解压,将里面的文件名称为 WA2600A-CMW520-R1308P11-FAT.bin修改为wa2600a_fat.bin (2)搭建TFTP服务器,将软件版本从服务器上传到设备(下载3CD软件) (3)在AP重启的时候按住ctrl+B进入设备的bootroom菜单 ===========================<EXTEND-BOOTWARE MENU>=========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Clear Super Password | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+C: Display Copyright Ctrl+F: Format File System Enter your choice(0-9): 3 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 5 ==========================<ETHERNET PARAMETER SET>========================== |Note: '.' = Clear field. | | '-' = Go to previous field. | | Ctrl+D = Quit. | ============================================================================ Protocol (FTP or TFTP) : tftp Load File Name :wa2600a_fat.bin Target File Name :wa2600a_fat.bin Server IP Address :192.168.0.1 //电脑主机的 IP Local IP Address :192.168.0.50 Gateway IP Address :0.0.0.0 //注意给电脑手动配置一个与AP同网段的IP地址,保证电脑与AP路由可达,能ping通 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 //此时可以看到TFTP服务器上数据上传的滚动 Loading..................................................................... ............................................................................ ....................................Done! 返回主菜单,查看设备上是否真的已经上传了该软件版本 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 0 ===========================<EXTEND-BOOTWARE MENU>=========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Clear Super Password | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+C: Display Copyright Ctrl+F: Format File System Enter your choice(0-9): 4 ===============================<File CONTROL>=============================== |Note:the operating device is flash | |<1> Display All File(s) | |<2> Set Application File type | |<3> Delete File | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-3): 1 Display all file(s) in flash: 'M' = MAIN 'B' = BACKUP 'S' = SECURE 'N/A' = NOT ASSIGNED ============================================================================ |NO. Size(B) Time Type Name | |1 9124864 Aug/08/2008 20:00:00 M wa2600a_fat.bin | ============================================================================ 上传成功 (4)返回主菜单,将设备进行重启 |Note:the operating device is flash | |<1> Display All File(s) | |<2> Set Application File type | |<3> Delete File | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-3): 0 ===========================<EXTEND-BOOTWARE MENU>=========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Clear Super Password | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+C: Display Copyright Ctrl+F: Format File System Enter your choice(0-9): 0 System is starting...
发表时间:2018-10-04
