[ZZGK-DLG-QBY4F_S5500]dis version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 2220P02
Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S5500-28F-EI uptime is 0 week, 2 days, 12 hours, 28 minutes
ZZGK-DLG-QBY4F_S5500-ui-aux0]?
User-interface view commands:
acl Specify acl filtering
cfd Connectivity fault detection (IEEE 802.1ag)
databits Specify the databits of user terminal interface
display Display current system information
flow-control Specify the flow control mode of user terminal interface
history-command Record history command
idle-timeout Specify the connection idle timeout for login user
mtracert Trace route to multicast source
parity Specify the parity mode of user interface
ping Ping function
quit Exit from current command view
return Exit to User View
save Save current configuration
screen-length Specify the lines displayed on one screen
speed Specify the TX/RX rate of user terminal interface
stopbits Specify the stop bit of user terminal interface
terminal Specify terminal type
tracert Trace route function
undo Cancel current setting
aux视图下无认证方式
(0)
应该是user-interface console 0命令进入console口视图吧?试试user-interface console 0这个命令。
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
没有这个命令,只有这个user-interface ? INTEGER<0-40> First user terminal interface number to be configured aux Aux user terminal interface vty Virtual user terminal interface
2级权限没有设置密码的功能,之后最高权限才可以。。。
