h3c s5500-ei交换机802.1x接入思科服务器
2017-09-22提问
  • 1收藏,3066浏览
5500交换机接入思科802.1x服务器,最终用户需要我根据思科交换机命令,来编写H3C 5500交换命令,以实现802.1x的功能。
当前使用的服务器和客户端是思科软件,中间的交换机是H3C 7506E。5500-ei,S3100v2
请问我编写的H3C命令是否与思科给的交换机命令匹配?
思科命令如下:
interface FastEthernet0/31
switchport access vlan 9
switchport mode access
switchport port-security violation protect
no logging event link-status
authentication event fail action next-method
authentication event server dead action authorize vlan 9
authentication event no-response action authorize vlan 150
authentication event server alive action reinitialize
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate 30
authentication violation protect
mab
no snmp trap link-status
dot1x pae authenticator
dot1x timeout quiet-period 1
dot1x timeout tx-period 1
dot1x max-req 1
storm-control broadcast level 10.00
spanning-tree portfast
end
我编写的H3C命令如下:
dot1x quiet-period
dot1x timer quiet-period 10
dot1x timer tx-period 10
dot1x timer reauth-period 7200
dot1x authentication-method eap
radius scheme system
 primary authentication 10.252.136.41
 primary accounting 10.252.136.41
 secondary authentication 10.252.136.42
 secondary accounting 10.252.136.42
 key authentication cipher $c$3$WSSFhKnW+nHQjMNdMY7tWEyx01YrITBGXWL7
 key accounting cipher $c$3$m2bReiywzr/BbB8rAo6CahGheAE6P43G9yrz
 timer response-timeout 5
 user-name-format without-domain
 nas-ip 10.46.1.4
 accounting-on enable
domain system
 authentication default radius-scheme system local
 authorization default radius-scheme system
 accounting default radius-scheme system local
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
 accounting optional
 port link-mode bridge
 port access vlan 9
 stp edged-port enable
 port-security port-mode userlogin
 dot1x re-authenticate
 dot1x guest-vlan 15
 undo dot1x handshake
粉丝:50人 关注:5人
可以找又懂华三,又懂思科的大神看看。
zhiliao_30951 知了小白
我的意思是我所配置H3C的命令,是否合思科的每一条命令都匹配,是否符合思科的实现方式。
因为我没有思科的服务器和客户端软件,无法测试。
所以只能通过这种笨方法来分析,谢谢!
