WX3500E
2018-10-09提问
  • 1收藏,1403浏览
要一份v5本地802.1x的配置案例
粉丝:15人 关注:0人
v5无线AC配置本地1x认证配置:
1、AC需要导入证书
[H3C]pki domain 520
[WX5540E]pki import-certificate ca domain 520 pem filename 2003_server.cer
The trusted CA's finger print is:
    MD5  fingerprint:7EFC 890E 3E04 543F 940A E5FF C79A EAD9
    SHA1 fingerprint:AD8F 99DC CBBE 768E 69CE C10B 8C90 1A27 51BC FBA5
Is the finger print correct?(Y/N):y
Import CA certificate successfully.
[WX5540E]pki import-certificate local domain 520 p12 filename 2003_local.pfx
Please input challenge password:1         //删除证书public-key local destroy rsa
Import local certificate successfully.
Import key pair successfully.
详细配置:
#使能端口安全
 port-security enable
#配置EAPdot1x认证方式
 dot1x authentication-method eap
#创建PKI实体
pki entity 520
  common-name 520
organization 520
#创建PKI认证域,调用PKI实体520,关闭CRL检测功能
pki domain 520
  certificate request from ca
  certificate request entity 520
crl check disable
domain 522
 authentication lan-access local
 authorization lan-access local
 accounting lan-access local
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
wlan service-template 105 crypto
 ssid 1x-bendi
 bind WLAN-ESS 105
 cipher-suite tkip
 security-ie wpa  //配置在AP发送信标和探查响应帧时携带WPA IE信息
 service-template enable
ssl server-policy 520    //配置SSL服务策略520
 pki-domain 520   //调用PKI认证域520
 ciphersuite rsa_rc4_128_sha
 handshake timeout 180
 close-mode wait
 session  cachesize 1000
#创建配置EAP认证摘要
eap-profile 520
 ssl-server-policy 520   //调用SSL服务策略
 method peap-mschapv2  //配置EAP认证方法
interface WLAN-ESS105
 port access vlan 12 //配置用户VLAN12
 port-security port-mode userlogin-secure-ext   //配置端口安全模式为userlogin-secureExt
 port-security tx-key-type 11key   //使能11KEY类型的密钥协商功能
 undo dot1x handshake  //关闭802.1x在线用户握手功能
dot1x mandatory-domain 522
wlan ap room2 model WA2620i-AGN id 1
 serial-id 219801A0CMC146000765
 radio 1
  radio enable
 radio 2
  channel 6
  bandwidth-guarantee enable
  radio enable
#本地dot1x认证调用EAP认证摘要
 local-server authentication eap-profile 520
local-user wlan     //创建本地认证用户
 password cipher $c$3$1gbICZB/srvSuh6DkJ7kPwoKauZibeY=
 service-type lan-access
