s7506R
2018-10-10提问
  • 1收藏,1363浏览
两台S7506做核心汇聚,开启协议有VRRP和rrpp
S7506-1上VLAN40-44接口地址为主用,备用在S7506-2
S7506-1VLAN50-54接口地址为备用,主用在S7506-2
问题1,备用S7506-2上VLAN40-44的虚拟VRRP状态一直在不停的在备用和主用之间切换,此时7506-1上主用状态没变化,出现业务不通,7506-1上RRPP状态也提示在变化(VLAN50-54一直稳定),找不出原因
粉丝:56人 关注:4人
看现象应该是S2交换机接说S1发送的VRRP心跳报文存在问题,有时候能收到,有时候不能收到。从而出现备主切换的情况,你可以抓包看看心跳包文的交互情况。
你好,我现在的处理办法是,将RRPP环从中间断开,目前看VRRP的主备状态正常
zhiliao_57522 发表时间:2018-10-10
方便留个电话或QQ么?我把配置和出问题时的日志发给你看下
%Oct 9 07:59:36 2018 XXXX-H3C7506R-02 VRRP/5/MasterChange: Vlan-interface42 | Virtual Router 142 : BACKUP --> MASTER reason: Fail receiving VRRP advertisement message in 3 times Advertisement_Interval %Oct 9 07:59:36 2018 XXXX-H3C7506R-02 VRRP/5/MasterChange: Vlan-interface42 | Virtual Router 42 : BACKUP --> MASTER reason: Fail receiving VRRP advertisement message in 3 times Advertisement_Interval %Oct 9 07:59:36 2018 XXXX-H3C7506R-02 VRRP/5/MasterChange: Vlan-interface40 | Virtual Router 140 : BACKUP --> MASTER reason: Fail receiving VRRP advertisement message in 3 times Advertisement_Interval %Oct 9 07:59:37 2018 XXXX-H3C7506R-02 VRRP/5/MasterChange: Vlan-interface44 | Virtual Router 44 : BACKUP --> MASTER reason: Fail receiving VRRP advertisement message in 3 times Advertisement_Interval %Oct 9 07:59:37 2018 XXXX-H3C7506R-02 VRRP/5/MasterChange: Vlan-interface44 | Virtual Router 44 : MASTER --> BACKUP reason: Received VRRP packet %Oct 9 07:59:38 2018 XXXX-H3C7506R-02 VRRP/5/MasterChange: Vlan-interface42 | Virtual Router 42 : MASTER --> BACKUP reason: Received VRRP packet %Oct 9 07:59:38 2018 XXXX-H3C7506R-02 VRRP/5/MasterChange: Vlan-interface40 | Virtual Router 140 : MASTER --> BACKUP reason: Received VRRP packet %Oct 9 07:59:38 2018 XXXX-H3C7506R-02 VRRP/5/MasterChange: Vlan-interface43 | Virtual Router 43 : BACKUP --> MASTER reason: Fail receiving VRRP advertisement message in 3 times Advertisement_Interval %Oct 9 07:59:39 2018 XXXX-H3C7506R-02 VRRP/5/MasterChange: Vlan-interface43 | Virtual Router 43 : MASTER --> BACKUP reason: Received VRRP packet
