F100-C-G
2017-10-02提问
  • 1收藏,3100浏览
您好,F100-C-G和MSR830搭建IPSEC VPN,F100-C-G是固定IP,MSR830是动态PPPOE,VPN建立不起来,
F100 debug信息
The policy's acl or ike profile does not match the flow, Name = GE1/0/3, Seqnum = 1
*Sep 30 17:16:45:241 2017 H3C IPSEC/7/EVENT:
MSR830
HD-MSR830>*Jan  1 04:07:29:337 2011 HD-MSR830 IPSEC/7/EVENT:
Sent debug message to all nodes, message type is 0x3.
*Jan  1 04:07:30:497 2011 HD-MSR830 IPSEC/7/EVENT:
Can't find block-flow node.
*Jan  1 04:07:30:497 2011 HD-MSR830 IPSEC/7/PACKET:
Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65536.
*Jan  1 04:07:30:497 2011 HD-MSR830 IPSEC/7/ERROR:
The reason of dropping packet is no available IPsec tunnel.
Sent SA-Acquire message : SP ID = 0
Received negotiatiate SA message from IPsec kernel.
*Jan  1 04:07:30:502 2011 HD-MSR830 IPSEC/7/EVENT:
Sent delete SA message to all nodes, message type is 0x16.
The SA doesn't exist in kernel.
*Jan  1 04:07:35:499 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:35:499 2011 HD-MSR830 IPSEC/7/PACKET:
*Jan  1 04:07:35:499 2011 HD-MSR830 IPSEC/7/ERROR:
*Jan  1 04:07:35:504 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:38:000 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:38:000 2011 HD-MSR830 IPSEC/7/PACKET:
*Jan  1 04:07:38:000 2011 HD-MSR830 IPSEC/7/ERROR:
*Jan  1 04:07:38:005 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:40:499 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:40:499 2011 HD-MSR830 IPSEC/7/PACKET:
*Jan  1 04:07:40:499 2011 HD-MSR830 IPSEC/7/ERROR:
*Jan  1 04:07:40:504 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:41:148 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:41:148 2011 HD-MSR830 IPSEC/7/PACKET:
*Jan  1 04:07:41:148 2011 HD-MSR830 IPSEC/7/ERROR:
*Jan  1 04:07:41:152 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:45:205 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:45:205 2011 HD-MSR830 IPSEC/7/PACKET:
*Jan  1 04:07:45:205 2011 HD-MSR830 IPSEC/7/ERROR:
*Jan  1 04:07:45:211 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:45:497 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:45:497 2011 HD-MSR830 IPSEC/7/PACKET:
*Jan  1 04:07:45:497 2011 HD-MSR830 IPSEC/7/ERROR:
*Jan  1 04:07:45:502 2011 HD-MSR830 IPSEC/7/EVENT:
*Jan  1 04:07:50:499 2011 HD-MSR830 IPSEC/7/EVENT:
粉丝:24人 关注:0人
F100-C-G debug信息The policy's acl or ike profile does not match the flow, Name = GE1/0/3, Seqnum = 1,感兴趣流不对或者ike profile不对
zhiliao_23708 知了小白
<F100>dis cur
 version 7.1.064, Release 9510P03
 sysname H3C
context Admin id 1
ip vpn-instance management
 route-distinguisher 1000000000:1
 vpn-target 1000000000:1 import-extcommunity
 vpn-target 1000000000:1 export-extcommunity
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
nat address-group 1 name NEIWANG
 address X.X.X.X X.X.X.X
 password-recovery enable
vlan 1
vlan 110
vlan 999
interface NULL0
interface Vlan-interface110
 ip address 192.168.110.254 255.255.255.0
interface GigabitEthernet1/0/0
 port link-mode route
 combo enable copper
 ip binding vpn-instance management
 ip address 192.168.0.1 255.255.255.0
 combo enable fiber
 duplex full
 speed 100
 ip address X.X.X.X 255.255.255.252
 nat outbound 3001
 nat server protocol tcp global 111.198.152.49 81 inside 192.168.0.139 8080
 nat server protocol tcp global current-interface 8087 inside 192.168.110.181 8881
 nat server protocol tcp global current-interface 8089 inside 192.168.110.181 11010
 nat server protocol tcp global current-interface 8092 inside 192.168.110.3 3690
 nat server protocol tcp global current-interface 8093 inside 192.168.110.3 22
 nat server protocol tcp global current-interface 8094 inside 192.168.110.5 3389
 nat server protocol tcp global current-interface 8095 inside 192.168.110.5 8080
 nat server protocol tcp global current-interface 8096 inside 192.168.110.5 1433
 nat server protocol tcp global current-interface 8097 inside 192.168.110.181 8088
 nat server protocol tcp global current-interface 8098 inside 192.168.110.181 81
 ipsec apply policy GE1/0/3
interface GigabitEthernet1/0/6
 ip address 192.168.254.1 255.255.255.0
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
 ip address 192.168.15.1 255.255.255.0
interface GigabitEthernet1/0/4
 port link-mode bridge
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 999
interface GigabitEthernet1/0/5
 port access vlan 110
object-policy ip Local-Trust
 rule 0 pass
object-policy ip Local-Untrust
 rule 0 pass
object-policy ip Trust-Local
 rule 0 pass
object-policy ip Trust-Untrust
 rule 0 pass
object-policy ip Untrust-Local
 rule 0 pass
object-policy ip Untrust-Trust
 rule 0 pass
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/6
 import interface GigabitEthernet1/0/11
 import interface GigabitEthernet1/0/4 vlan 999
security-zone name DMZ
 import interface Vlan-interface110
 import interface GigabitEthernet1/0/5 vlan 110
security-zone name Untrust
 import interface GigabitEthernet1/0/3
security-zone name Management
 import interface GigabitEthernet1/0/0
 import interface GigabitEthernet1/0/2
zone-pair security source Local destination Trust
 object-policy apply ip Local-Trust
zone-pair security source Local destination Untrust
 object-policy apply ip Local-Untrust
zone-pair security source Trust destination Local
 object-policy apply ip Trust-Local
zone-pair security source Trust destination Untrust
 object-policy apply ip Trust-Untrust
zone-pair security source Untrust destination Local
 object-policy apply ip Untrust-Local
zone-pair security source Untrust destination Trust
 object-policy apply ip Untrust-Trust
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class vty
line aux 0
line con 0
 authentication-mode scheme
line vty 0 63
 ip route-static 0.0.0.0 0 61.50.125.213
 ip route-static 192.168.0.0 16 192.168.254.2
 ssh server enable
acl advanced 3000
 rule 0 permit ip source 192.168.0.0 0.0.255.255 destination 172.16.12.0 0.0.0.255
acl advanced 3001
 rule 0 deny ip source 192.168.0.0 0.0.255.255 destination 172.16.12.0 0.0.0.255
 rule 1 permit ip
domain system
 aaa session-limit ftp 16
 aaa session-limit telnet 16
 aaa session-limit ssh 16
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$UbIhNnPevyKUwfpm$LqR3+yg1IjNct39MkOR0H0iQXLkYB3jMqM4vbAeoXOhbabIIFnjJPEGR00YiYA1Sz4LiY3FmEdru2fOLMb1shQ==
 service-type ssh terminal https
 authorization-attribute user-role level-3
ipsec transform-set dhcc
 esp encryption-algorithm 3des-cbc
 esp authentication-algorithm md5
ipsec transform-set GE1/0/3_IPv4_1
ipsec policy-template GE1/0/3 1
 security acl 3000
 local-address X.X.X.X
 ike-profile GE1/0/3_IPv4_1
ipsec policy GE1/0/3 1 isakmp template GE1/0/3
 ike identity fqdn dhcc
ike profile dhcc
 keychain dhcc
 exchange-mode aggressive
 local-identity fqdn dhcc
 match remote identity fqdn dhcc-hd
 proposal 1
ike profile GE1/0/3_IPv4_1
 keychain GE1/0/3_IPv4_1
 proposal 65535
ike proposal 1
ike proposal 65535
 description GE1/0/3_IPv4_1
ike keychain dhcc
 pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $c$3$Pb6M5BkKWRwMq8MxuQgCviUBDDDLekafUw==
ike keychain GE1/0/3_IPv4_1
 pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $c$3$M/KW5EXlGkeDNg2mmq/5cTnAlhRt2JU8tQ==
 ip https enable
return
<H3C>
<H3C>dis ike sa
    Connection-ID   Remote                Flag         DOI
    4               61.135.136.94         RD           IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
<F100>dis ipsec sa
[BEGIN] 2017/9/30 17:25:17
<HD-MSR830>dis cur
 version 7.1.064, Release 0605P05
 sysname HD-MSR830
 telnet server enable
 dialer-group 1 rule ip permit
 ip load-sharing mode per-flow src-ip global
 dhcp enable
 dhcp server always-broadcast
 dns proxy enable
vlan 1
dhcp server ip-pool lan1
 gateway-list 172.16.12.1
 network 172.16.12.0 mask 255.255.255.0
 address range 172.16.12.2 172.16.12.254
 dns-list 202.106.0.20 202.106.46.151
controller Cellular0/0
interface Aux0
interface Dialer0
 ppp chap password cipher $c$3$Yoh2gX8T+WU0/saXEA7Uj0SJhnZCVVxzz2o/
 ppp chap user qs010311
 ppp ipcp dns admit-any
 ppp ipcp dns request
 ppp pap local-user qs010311 password cipher $c$3$rezTBdx9L1jKIBuapGShibAj441fI88Pvq0+
 dialer bundle enable
 dialer-group 1
 dialer timer idle 0
 dialer timer autodial 5
 ip address ppp-negotiate
 nat outbound 3001
 ipsec apply policy dhcc-hd
interface Dialer1
interface Dialer2
interface Dialer3
interface Dialer4
interface Dialer5
interface Dialer6
interface Dialer7
interface Dialer8
interface Dialer1023
interface Virtual-Template0
interface NULL0
 ip address 172.16.12.1 255.255.255.0
 tcp mss 1280
interface GigabitEthernet0/0
 description Single_Line1
 combo enable copper
 pppoe-client dial-bundle-number 0
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
line class aux
line class console
line class tty
line class vty
line aux 0
 authentication-mode none
line con 0
line vty 0 63
 ip route-static 0.0.0.0 0 Dialer0
acl advanced 3000
 rule 0 permit ip source 172.16.12.0 0.0.0.255 destination 192.168.0.0 0.0.255.255
acl advanced 3001
 rule 0 deny ip source 172.16.12.0 0.0.0.255 destination 192.168.0.0 0.0.255.255
 rule 1 permit ip
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
 password hash $h$6$X99HB388dmkmxJ2v$nkZTin5R9tbXK00IqoZH+WSPAH425neOc0OFg+EKCV4CbcGyPVhv91CyRch7nzP8RonTj09mcQrOn1sNP6x2Fw==
 service-type telnet http
ipsec transform-set dhcc-hd
ipsec policy dhcc-hd 1 isakmp
 security acl 3000
 remote-address X.X.X.X
 ike-profile dhcc-hd
ipsec policy hdcc-hd 1 isakmp
 ike identity fqdn dhcc-hd
ike profile dhcc-hd
 keychain dhcc-hd
 local-identity fqdn dhcc-hd
 match remote identity address X.X.X.X 255.255.255.255
 proposal 1
ike proposal 1
ike keychain dhcc-hd
 pre-shared-key address X.X.X.X 255.255.255.255 key cipher $c$3$OIPi2GpTwKTcqEGKZchvGisi6OnF95KrWQ==
 ip http enable
wlan global-configuration
 control-address disable
wlan ap-group default-group
 cloud-management server domain oasis.h3c.com
return
<HD-MSR830>
<HD-MSR830>
<HD-MSR830>dis ike sa
    3               X.X.X.X         RD           IPsec
Flags:
<HD-MSR830>dis ipsec sa
[END] 2017/9/30 17:25:39
# ipsec policy-template GE1/0/3 1 transform-set GE1/0/3_IPv4_1 security acl 3000 //删除,模板方式总部不用写acl,两端都reset ipsec sa、reset ike sa,只能在分支发起ipsec,触发形成隧道 local-address X.X.X.X ike-profile GE1/0/3_IPv4_1
暮逍遥 发表时间:2017-10-02
回复暮逍遥:
谢谢,回头试一下!
zhiliao_23708 发表时间:2017-10-02
回复暮逍遥:
有个问题我问一下,那我总部要访问分支服务器是不是不能主动访问?
回复zhiliao_23708:
总部模板侧不能触发ipsec,只有分部先触发形成ipsec隧道,总部才能访问分部
暮逍遥 发表时间:2017-10-02
回复暮逍遥:
谢谢!还有一个问题,我在总部有一些服务器,用公网地址加端口号,作了一对一映射,为什么在之前华为的路由器上能访问9undo firewall session link-state check tcp),在H3C的上面却不行,是不是也得undo firewall session link-state check tcp?
还是起不来!
zhiliao_23708 发表时间:2017-10-08
