MSR2600固件升级后web无法登陆
2018-10-13提问
  • 1收藏,1995浏览
[H3C]display curr # version 5.20, Release 2516P17 # sysname H3C # domain default enable system # dar p2p signature-file flash:/p2p_default.mtd # port-security enable # undo ip http enable # password-recovery enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$40gC1cxf/wIJNa1ufFPJsjKAof+QP5aV authorization-attribute level 3 service-type telnet # cwmp undo cwmp enable # interface Aux0 async mode flow link-protocol ppp # interface Cellular0/0 async mode protocol link-protocol ppp # interface NULL0 # interface GigabitEthernet0/0 port link-mode route ip address 192.168.1.1 255.255.255.0 # interface GigabitEthernet0/1 port link-mode route # interface GigabitEthernet0/2 port link-mode bridge # interface GigabitEthernet0/3 port link-mode bridge # interface GigabitEthernet0/4 port link-mode bridge # interface GigabitEthernet0/5 port link-mode bridge # interface GigabitEthernet0/6 port link-mode bridge # interface GigabitEthernet0/7 port link-mode bridge # interface GigabitEthernet0/8 port link-mode bridge # interface GigabitEthernet0/9 port link-mode bridge # load xml-configuration # load tr069-configuration # user-interface tty 12 user-interface aux 0 user-interface vty 0 4 authentication-mode scheme # return
web无法登陆
粉丝:8人 关注:0人
console口登陆后,可以使用所有的命令,例如使用console线配置web登陆命令:
ip http enable
local-user admin
password simpe admin
service-type web
authorization-attribute level3
好像还是不行
zhiliao_4nl44 发表时间:2018-10-13
<H3C>display current # version 5.20, Release 2516P17 # sysname H3C # domain default enable system # dar p2p signature-file flash:/p2p_default.mtd # port-security enable # password-recovery enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$rrlF4R15f5UJXzDHrssfxG6vDstQBw5M authorization-attribute level 3 service-type telnet service-type web # cwmp undo cwmp enable # interface Aux0 async mode flow link-protocol ppp # interface Cellular0/0 async mode protocol link-protocol ppp # interface NULL0 # interface GigabitEthernet0/0 port link-mode route ip address 192.168.1.1 255.255.255.0 # interface GigabitEthernet0/1 port link-mode route # interface GigabitEthernet0/2 port link-mode bridge # interface GigabitEthernet0/3 port link-mode bridge # interface GigabitEthernet0/4 port link-mode bridge # interface GigabitEthernet0/5 port link-mode bridge # interface GigabitEthernet0/6 port link-mode bridge # interface GigabitEthernet0/7 port link-mode bridge # interface GigabitEthernet0/8 port link-mode bridge # interface GigabitEthernet0/9 port link-mode bridge # load xml-configuration # load tr069-configuration # user-interface tty 12 user-interface aux 0 user-interface vty 0 4 authentication-mode scheme
有串口线吗
V15555006163 发表时间:2018-10-13
你好,我的设备型号是msr2630,我的web也登陆不了
zhiliao_YfA5a 发表时间:2018-10-13
是不是有的设备就不支持web登录
2600-10支持么?winet支持的
联系我
佛手 五段
http服务没有开启,用户服务类型也没有配置http服务
建议多看看轻松配
https://zhiliao.h3c.com/topic/huati/1247
寂东 九段
粉丝:225人 关注:3人
你这款设备是V5平台的,支持web登录,二楼的回答不错,在这个基础上在作如下检查:
ip http enable
local-user admin
service-type web
这样配置后,在检查先两点,
1,是否启用web服务? ip http enable
2,你的GigabitEthernet0/0 口 ip address 192.168.1.1 255.255.255.0是,你的终端是连到这个口下(或者这个口下的交换机)了吗?你的终端设置同网段的ip地址了吗?比如 192.168.1.2  255.255.255.0 ,能ping 通192.168.1.1 吗?检查下这两点
如果按照上边的配置都配置了,终端配置了正确的ip地址并且和G0/0口物理线路通的能ping通,那么就可以web登录了
