S5500 bootrom密码怎样设置
2018-10-22提问
  • 1收藏,1269浏览
夕阳 零段
bootrom密码怎样设置
加电或重启时按ctrl+B,进bootrom,里面有菜单
是bootrom密码设置 不是进入
夕阳 发表时间:2018-10-22
BOOT MENU 1. Download application file to flash 2. Select application file to boot 3. Display all files in flash 4. Delete file from flash 5. Modify bootrom password 6. Enter bootrom upgrade menu 7. Skip current configuration file 8. Set bootrom password recovery 9. Set switch startup mode 0. Reboot 看一下菜单,5是修改。
zhiliao_IC5bv 发表时间:2018-10-22
