S3610
2017-10-12提问
  • 1收藏,2441浏览
两台S3610只在interface Vlan-interface1下配置 ip address 192.168.1.X 255.255.255.0,电脑配置通网段IP互PING不通,可以排除网线,电脑原因
两台交换机互ping也不通。
交换机工作环境110KV变电站机房
不知道哪位大神遇到过同样的问题,又是怎么解决的,谢谢!
[H3C]disp ver
H3C Comware Platform Software
Comware Software, Version 5.20, Release 5309
Copyright (c) 2004-2009 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S3610-28P uptime is 0 week, 0 day, 0 hour, 10 minutes
H3C S3610-28P
128M    bytes DRAM
32M     bytes Flash Memory
Config Register points to FLASH
Hardware Version is REV.D
CPLD Version is CPLD 002
Bootrom Version is 206
[SubSlot  0] 24FE Hardware Version is REV.D
[SubSlot  1]  4GE Hardware Version is REV.D
[H3C] disp cu
 version 5.20, Release 5309
 sysname H3C
 domain default enable system
 telnet server enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
interface NULL0
 ip address 192.168.1.2 255.255.255.0
interface Ethernet1/0/1
 port link-mode bridge
interface Ethernet1/0/2
interface Ethernet1/0/3
interface Ethernet1/0/4
interface Ethernet1/0/5
interface Ethernet1/0/6
interface Ethernet1/0/7
interface Ethernet1/0/8
interface Ethernet1/0/9
interface Ethernet1/0/10
interface Ethernet1/0/11
interface Ethernet1/0/12
interface Ethernet1/0/13
interface Ethernet1/0/14
interface Ethernet1/0/15
interface Ethernet1/0/16
interface Ethernet1/0/17
interface Ethernet1/0/18
interface Ethernet1/0/19
interface Ethernet1/0/20
interface Ethernet1/0/21
interface Ethernet1/0/22
interface Ethernet1/0/23
interface Ethernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
user-interface aux 0
user-interface vty 0 4
return
确定电脑的防火墙关闭了吗?
防火墙都关闭了,不是电脑的问题
zhiliao_57522 发表时间:2017-10-12
回复zhiliao_57522:
那看看交换机的几口有没有UP,接口协商的双工速率是多少?有没有出现半双工的情况,强制一下双工速率试试?这个交换机就跟这一个电脑直连吗?
风干工程师肉干要不要 发表时间:2017-10-12
[H3C]disp interface Vlan-interface 1 Vlan-interface1 current state: UP Line protocol current state: UP Description: Vlan-interface1 Interface The Maximum Transmit Unit is 1500 Internet Address is 192.168.1.1/24 Primary IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e2f4-2b01 IPv6 Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e2f4-2b01 [H3C]disp int [H3C]disp interface eth [H3C]disp interface Ethernet 1/0/1 Ethernet1/0/1 current state: UP IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e2f4-2b10 Description: Ethernet1/0/1 Interface Loopback is not set Media type is twisted pair, Port hardware type is 100_BASE_TX 100Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled The Maximum Frame Length is 1552 Broadcast MAX-ratio: 100% Unicast MAX-ratio: 100% Multicast MAX-ratio: 100% PVID: 1 Mdi type: auto Link delay is 0(sec) Port link-type: access Tagged VLAN ID : none Untagged VLAN ID : 1 Port priority: 0 Last 300 seconds input: 1 packets/sec 131 bytes/sec 0% Last 300 seconds output: 0 packets/sec 6 bytes/sec 0% Input (total): - packets, - bytes - broadcasts, - multicasts Input (normal): 107 packets, 13033 bytes 85 broadcasts, 22 multicasts Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, 0 frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): - packets, - bytes - broadcasts, - multicasts, - pauses Output (normal): 6 packets, 642 bytes 0 broadcasts, 6 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions - lost carrier, - no carrier [H3C]disp mac-add No Multicast Mac addresses found. MAC ADDR VLAN ID STATE PORT INDEX AGING TIME(s) 089e-015c-1648 1 LEARNED Ethernet1/0/1 AGING [H3C]disp arp Type: S-Static D-Dynamic IP Address MAC Address VLAN ID Interface Aging Type [H3C]ping 192.168.1.2 PING 192.168.1.2: 56 data bytes, press CTRL_C to break Request time out Request time out Request time out Request time out Request time out --- 192.168.1.2 ping statistics --- 5 packet(s) transmitted 0 packet(s) received 100.00% packet loss [H3C]disp stp Protocol Status :disabled Protocol Std. :IEEE 802.1s Version :3 CIST Bridge-Prio. :32768 MAC address :000f-e2f4-2b00 Max age(s) :20 Forward delay(s) :15 Hello time(s) :2 Max hops :20 [H3C]disp stp ? abnormal-port Display abnormal ports brief Brief information down-port Port infomation of protocol down history Root or alternate port history ignored-vlan VLAN stp ignored information instance Spanning tree instance interface Specify interface region-configuration Region configuration root Display status and configuration of the root bridge tc Port TC count <cr> [H3C]disp stp int [H3C]disp stp interface eth [H3C]disp stp interface Ethernet 1/0/1 Protocol Status :disabled Protocol Std. :IEEE 802.1s Version :3 CIST Bridge-Prio. :32768 MAC address :000f-e2f4-2b00 Max age(s) :20 Forward delay(s) :15 Hello time(s) :2 Max hops :20
目前交换机只联了一个电脑
paul 九段
粉丝:30人 关注:5人
在两侧设备上看下vlan-interface是否up,看下互连接口stp状态,看下是否学习到arp,最后可以再抓包确认下。
故障交换机只接电脑也是ping不通,可以学习到电脑MAC地址
zhiliao_57522 知了小白
[H3C]disp int
 Loopback is not set
 PVID: 1
 Mdi type: auto
 Port priority: 0
[H3C]disp mac-add
[H3C]disp arp
    Request time out
    Request time out
    Request time out
    Request time out
    Request time out
    100.00% packet loss
[H3C]disp stp
 Version            :3
 Max age(s)         :20
 Hello time(s)      :2
 Max hops           :20
[H3C]disp stp ?
  tc                    Port TC count
  <cr>
[H3C]disp stp int
 Version            :3
 Max age(s)         :20
 Hello time(s)      :2
 Max hops           :20
