H3C S7506频繁重启。
2018-11-05提问
  • 1收藏,1120浏览
2007年采购的一个H3C S7506,搭配一个LS81SRPG,一个20口前兆光线业务板,一个20口前兆电口业务板。
最近老是自动重启。
console口登录,可以收到很多IP分配冲突,类似如下:
ARP/5/DUPIP:IP address 172.17.72.31 collision detected, sourced by f0de-f169-1879 on GigabitEthernet1/0/17 of VLAN720 and c80a-a94f-87fe on GigabitEthernet1/0/17 of VLAN720
按理这个不至于导致系统重启啊
查看诊断信息,显示如下:
-------------------- display Information from reserved memory --------------------
Now you enter a hidden command view for developer's testing, some commands may affect operation by wrong use, please carefully use it with owner's engineer's direction.
 Message from 0xFF9F204:
System reboot time: 2018/11/05 06:17:43
Uptime: 0 week 0 day 0 hour 0 minute 35 second(Swt 1msec)
Called by Task 0x372fe60(SOCK):
 Statck: 0x010f914c()
0x00747c04()
0x0074ecc8()
0x008f158c()
0x005fa944()
0x005fa33c()
0x00622664()
0x0164d83c()
reboot slot 1 Message from 0xFF9F280: System reboot time: 2018/11/05 06:17:43 Uptime: 0 week 0 day 0 hour 0 minute 35 second(Swt 0msec) Called by Task 0x361e5d8(DEV):
查看mainboard switchinfo,得到如下信息:
17:Master Board 0 is inserted at 12:48:00 11/04
18:Master Board 0 is inserted at 15:30:00 11/04
19:Master Board 0 is inserted at 15:37:00 11/04
20:Master Board 0 is inserted at 15:42:00 11/04
21:Master Board 0 is inserted at 16:00:00 11/04
22:Master Board 0 is inserted at 16:06:00 11/04
23:Master Board 0 is inserted at 06:17:00 11/05
可能是什么原因呢??
看到很多IP冲突,今天早上我使用DHCP IP排除,把冲突的IP加了进去,目前暂时没有再重启。
但是DHCP或ARP检测的冲突应该不至于导致系统频繁重启吧??
H3C Comware Platform Software
Comware software, Version 3.10, Release 3135
Copyright (c) 2004-2007 Hangzhou H3C Technologies Co., Ltd. All rights reserved.
H3C S7506 uptime is 0 week, 0 day, 7 hours, 43 minutes
SRPG 0: uptime is 0 weeks,0 days,7 hours,43 minutes H3C S7500 with 1 MPC8245 Processor 256M bytes SDRAM 32768K bytes Flash Memory 512K bytes NVRAM Memory PCB Version : VER.C BootROM Version : 527 CPLD Version : 004 Second CPLD Ver : 005 Software Version : S7506-3135 Patch Version : None LPU 1: uptime is 0 weeks,0 days,7 hours,41 minutes H3C S7500 LPU with 1 MPC8241 Processor 128M bytes SDRAM 0K bytes Flash Memory 0K bytes NVRAM Memory PCB Version : VER.B BootROM Version : 525 CPLD Version : 001 Second CPLD Ver : 001 Software Version : S7506-3135 Patch Version : None LPU 2: uptime is 0 weeks,0 days,7 hours,41 minutes H3C S7500 LPU with 1 MPC8241 Processor 128M bytes SDRAM 0K bytes Flash Memory 0K bytes NVRAM Memory PCB Version : VER.C BootROM Version : 527 CPLD Version : 005 Software Version : S7506-3135 Patch Version : None
粉丝:19人 关注:0人
如果IP地址冲突或者arp上送CPU过多,会导致CPU高或者内存占用过多,比如内存满了就会重启设备,可以display memory看看内存是不是偏高
我也在考虑内存占用的问题,查了一下,目前是 System Total Memory(bytes): 199469952 Total Used Memory(bytes): 96164132 Used Rate: 48% 另外,怎么减少这种冲突呢??靠DHCP Server Ip forbidden总不是个办法啊
zhiliao_uk2Jk 发表时间:2018-11-05
这种只能是从源头上排查掉冲突的地址
时光记忆srp 发表时间:2018-11-05
嗯,实在不行我就给这个VLAN换一个新的地址池,看看哪些计算机占住了IP不释放。
谢谢各位,forbidden掉这些地址以后,冲突明显减少,目前系统运行稳定。没有再重启。 后续准备把频繁发生冲突的端口下面分隔成不同VLAN,看能不能减少冲突。
zhiliao_uk2Jk 发表时间:2018-11-06
V3平台的设备,的确很老了。从你给的信息来看,S7506还做为DHCP Server,为终端分配IP了。建议你看下dis version的信息,这里有设备启动的原因说明,希望能够看出一些思路来。
另外,建议你检查设备的板卡状态(dis device)、温度情况、设备的flash空间等和硬件相关的一些参数。按理说,地址冲突是不会导致设备重启的。
