MSR36-20 在HCLZ中查看广域网接口serial1/0时没有显示时钟方式等信息
2018-11-12提问
  • 1收藏,891浏览
零段
display interface Serial 1/0
Serial1/0 Current state: UP Line protocol state: UP
Description: Serial1/0 Interface Bandwidth: 64 kbps
Maximum transmission unit: 1500 Hold timer: 10 seconds, retry times: 5
 Internet address: 10.1.1.1/24 (primary) Link layer protocol: PPP LCP: opened, IPCP: opened
 Last link flapping: 0 hours 0 minutes 35 seconds
 Last clearing of counters: Never Current system time:2018-11-12 21:51:32
 Last time when physical state changed to up:2018-11-12 21:50:57
Last time when physical state changed to down:2018-11-12 21:48:10
粉丝:8人 关注:1人
正常应该会显示的,你做了什么特殊的配置么。还是说有more的时候没按空格
<Sysname> display interface serial 2/1/0
Serial2/1/0
Current state: UP
Description: Serial2/1/0 Interface
Bandwidth: 64kbps
Hold timer:10 seconds, retry times: 5
Internet Address: 9.9.9.6/24 Primary
LCP: opened
Last link flapping: 6 hours 39 minutes 25 seconds
Current system time:2017-12-14 10:00:37
Last time when physical state changed to up:-
Last time when physical state changed to down:2017-12-14 09:47:16
Physical layer: synchronous, Baudrate: 64000 bps
Interface: DCE
Cable type: V35
Clock mode: DCECLK1
Last 300 seconds input rate: 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Last 300 seconds output rate: 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Input:
  6668 packets, 80414 bytes
  0 broadcasts, 0 multicasts
  0 errors, 0 runts, 0 giants
  0 crc, 0 align errors, 0 overruns
  0 aborts, 0 no buffers, 1 frame errors
Output:
  6670 packets, 80446 bytes
  0 errors, 0 underruns, 0 collisions
  0 deferred
DCD: UP, DTR: UP, DSR: UP, RTS: UP, CTS: UP
完全没有动啥,都是新建立。 那有啥命令是直接查看时钟方式的呢?谢谢您的回复
发表时间:2018-11-12
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。 <Sysname> display clock 15:11:00.211 Z5 Fri 03/16/2015 Time Zone : Z5 add 05:00:00 Summer Time : PDT 06:00:00 08/01 06:00:00 09/01 01:00:00 你可以自己查询,命令官网都有的 http://www.h3c.com/cn/Service/Document_Software/Document_Center/Routers/Catalog/MSR/MSR_810/Command/Command_Manual/H3C_MSR_CR(V7)-R0707P03-6W300/99/
咸蛋黄 发表时间:2018-11-12
哈哈 谢谢 我就是想找到我为什么会少了那一部分信息的原因。官网有看过。
发表时间:2018-11-12
回复:
你按空格试了没,好多人会忘记按
咸蛋黄 发表时间:2018-11-12
对了,你是不是在模拟器上试的啊,模拟器上是显示不全的
咸蛋黄 发表时间:2018-11-12
回复咸蛋黄:
是的是的 在HCL模拟器上实验的,显示信息就只有这么多。原来是这样啊
发表时间:2018-11-12
回复:
哈哈,那就好,设备我没见过这种显示一半的
咸蛋黄 发表时间:2018-11-12
回复咸蛋黄:
感谢感谢
发表时间:2018-11-12
